On 4/11/2019 at 2:04 AM, KORTES said:
Jack-pins.
I found the technology of making jack-pins  in the report of Uriy Kimborovich (bim), that he  used for his schooner “Izmail”, for what I’m very grateful to him. I made a simple device out of the materials I had.
Material - pear tree. Firstly I prepared the bars of the desired diameter, and so as not to waste too much material (for the support fixture in the collet) I was carving from a long rod, as the length of the coordinate table would allow me.
This is a very interesting way of turning small, thin pieces. I have not seen this before. Very clever!
Kortes - lovely sweep to the tiller - everything looking beautifully crafted.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Kortes - Lovely little stove. I like the chimney fitted.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I’ve made the carronades.
The method isn’t too technological, but since I needed only to of them I decided to use it. The barrels are turned using a lathe, all the other parts are ‘filed’ of brass using the rat-file and broaching files. All the parts have been soldered together and after blackening the solder had to be painted.
You must be a perfectionist Alexander, because your work is indeed perfect.  Your re-working of the stove displays your pride of craftsmanship.  All these details - tiller, stove, pumps and carronades are all very finely made.  Nice.
Gary
Completed Scratch Builds
Always a pleasure to catch up on your exquisite work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
