FINISHED - Ferrari 250 GT California Spyder by CDW - Italeri 1:24 Scale
CDW
With a model like this, I like to modify the kit parts just a bit to give it a personal twist.
Here, I've taken the molded front and rear struts and cut off the top retainers with my razor saw; next I file and sand away the molded on coil spring details; last I wrap soft wire around the strut to make my own coil springs before gluing the retainers back on top.
I like the look after everything is painted more than the molded on look.
Link to comment
Share on other sites
I recall some older kits that supplied springs........that was short lived.   great idea for the extra detail file :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Here we have the partially assembled chassis with the engine dry-fitted. Brown flocking has been applied to the floorboards to simulate carpet. The seats and door panels will be a light leather color. The door panels will require some custom work to obtain a higher level of accuracy. What Italeri did was to share the same interior (and other) components between the 250 GTO and the 250 California Spyder. What's accurate for the 250 GTO door panels are not accurate for the California Spyder. While at it, will add some aftermarket photo etch inner door handles, window cranks, and rear view mirror for better accuracy.
She's coming along slowly but surely. I've got several irons in the fire right now and less time to devote to model building. Got a big trip coming up in the next 10 days and really looking forward to it.
Link to comment
Some really nice detail there - the engine has come up so well.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Link to comment
look'in really good...never tried the carpet thing :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for the comments, Denis.
Simulating the carpet is real easy to do. You need the correct color flocking, some watered down white glue, and a strainer to sift the flocking. Get your flooring painted the color you want and after it's dry, brush on a good coat of watered-down white glue where you want carpet. While the white glue mixture is still wet, sift the flocking on top of the white glue, then shake away the excess (flocking). That's it. As easy as that. Just make sure to sift the flocking and not just drop a lump of it down. The results will not be the same and would create a big mess. You can get all colors of flocking on Ebay for a couple of dollars per bag. A bag of it will do a LOT of models. You'll probably never use it all unless you build dozens of models.
Link to comment
revell and Aurora put out animal models back in the day.........likely used the same type of flocking.  it's a nice touch  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Oh yes, I'll bet you could really bring an animal model to life with flock.
I just ordered five more different colors in the 1/2 ounce bags for $2.25 each. 1/2 ounce doesn't sound like much, but it's a lot of this stuff because it's so light and fluffy, almost like dust. On their web, you see woodworkers using it a lot for lining the inside of jewelry boxes, drawers, and things like that. I wonder how durable it would be for that sort of use? Must be decent because it's used a lot.
Link to comment
You obviously didn't see my Perri the squirrel model. I built it and didn't paint it but went straight to the flocking. It ended up looking like the most moth eaten critter you ever saw! It was more like the Zombie squirrel from Hell! :(
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
I've seen them around.........especially the older Aurora kits :)   I've never done one,  but I would agree that the flocking needs to be sifted onto the model.   I have a project coming up that has four horses.........don't think I'm gonna try it for fear of ruining them.
I don't recall seeing any Zombie Squirrels on the Walking Dead  ;)  :D
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Lou said he built his models, then without painting them, went straight to flocking. That alone is going to cause issues with the color of the finished job. The surface needs to first be painted the color (or close to it) of the flocking you're going to use. Second, no matter how tempting it might be, you don't touch the flocking until it's thoroughly dry. Touching it before it dries will cause serious issues. If you use white glue as the adhesive for the flocking, you could easily wash it off with water if you didn't like the results. In my view, it's a low risk/no risk proposition.
Link to comment
Not a lot of progress, but something is better than nothing.
Got my hands on the set of Tamiya polishing compounds with a set of their applicators. Really great stuff as usual from Tamiya. Don't know where you would find anything better for models, it comes with coarse, fine and polishing (extra fine) tubes of compounds. Really makes short work of putting a super shine on your model paint job or for polishing clear plastic. I highly recommend it.
I'll be making some radiator hose next, then paint and build the remainder of the chassis assembly. Most likely won't have time to finish this project before we leave for a vacation.
Link to comment
looks great!........very  well done! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thats a cool looking mil.
OC.
Current builds
Completed works.
Link to comment
OC.
Thanks dude. I'm flying out of here in a few more hours...got my bags all packed and thinking about whether there's something I have forgotten to take.
I pack light anyway. My wife and daughter are another story...they pack like...everything. It will cost me when we check in our baggage. 😵
Link to comment
All the best on your journey  have fun - stay safe.
OC.
Current builds
Completed works.
Link to comment
have fun and good luck! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I know you are gone already Craig.
Somehow new posts don't always show up for me for a day or two after they are posted. But just in case you are looking in I hope you are having a good time and building lots of memories. I hope you remembered to pack your camera and can share a little with us stuck-at-homes when you get back.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Great area with beautiful scenery. Thanks for sharing.
I bet getting to see the Albacore was a plus! Did you get to do the walk through?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Love the pictures.  Beautiful trip you're having.  I'm thinking that little engine might be yard engine for moving cars around.
Link to comment
Nice views up in the mountains. And even better with the clarity. We get morning fogs in the Smokies, hence that name. The mist hanging in the trees looks like smoke.
Track gauge(space between the rails) looks to be standard spacing of 4'8". Most logging roads tended to build at 3 foot gauge, quicker to lay that track and cheaper to build. They'd use tree trunks for ties, since they didn't expect them to last more than the time it took to harvest the wood. Like Mark said, it's a yard engine or "goat".  Not big/heavy enough to haul more than a small handful of cars on flat track.
Ken
Started: MS Bounty Longboat,
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
