HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
your suppose to make it so no  one can see under there!  :D  :D   my rule of thumb.......anyway.   once the deck is fully populated,  you'll never see under there......I've tried on my builds....it's an eye strain to be sure.   a whisk of fresh paint usually hides it well. ;)   nice progress!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nenad,
I would think that the rear entrance would have to be about the same as the front.  The back entrance is "new"?  I know very little about the CS to answer correctly.  I'm just surprised there's no pictures of this.  I Googled but didn't see anything that would help.
Nenad,
Thank you for your input, Mark
I mean "new" comparing to state presented in C-plans
I think that entrances are not the same, and that the front entrance is higher. Simply reason. Front entrance have two doors ( left and right) and entering to any door , you are still on deck platform, and stairs comes later. It make no sense to step sideways to stairs immediately when you step through the door. So, when you enter and you are still on platform, entrance must have height for human body. On the other side, you can see on photos, at rear entrance, you directly step to stairs to go down
Also top angles of side decorative moldings are not same shape, which also points to different height
Edited by Nenad
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
" ... Chim chim-in-ey, chim chim-in-ey , Chim chim cher-ee! ..."
One more nice detail, discovered during analyze of photos I colected
Now you see it !!!!
Now you don`t  !!!!
Also this disappeared !!!
Edited by Nenad
In progress:
Content of log :
Past build:
For a "Scratch" Build, something that I would be very maybe afraid of, your work is awesome chap!!
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Thx for nice word, Harry
Nothing to be afraid of. Anyway even as a kit builder, you have to cut, fit and adjust parts, sometimes to replace, and there is not a big step to scratch. Also more interesting - for me :);)
Edited by Nenad
In progress:
Content of log :
Past build:
Very glad to see you again, Bob. I hope you cleared away life issues around you, and to see your post and progress soon !!!!
You are quite right. interesting question is ( considering my "artistic" approach) to add or not chimney etc etc. We`ll see when time comes
For now, dead-eye analytic is over, I chose where to put 4mm and where 3mm dead eyes, and mass-production can start
Edited by Nenad
In progress:
Content of log :
Past build:
Very nice Nenad,
I like that deadeye Chart, giving the overview of what sizes and quantities go where ?
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Thanks Nils. I am dummy and can not remember, so I have to make a note.
Mass production starts with (4+2) x 2 =12 dead eyes 4mm dia for aft deck row which go directly to aft deck, without down structure
This is phase No 1. - shape/redril holes, sand a bit, mount Cu telephony wire, solder ends, center hole position
Follow shapeing , fiting, glueing painting and cementing
This will be more interesting with smaller ones tomorrow. Now I go to fright myself with Jurassic Park 1 , 125th time watching :)
Edited by Nenad
In progress:
Content of log :
Past build:
Looking good.
Just make sure to plan for threading the lanyards.
Once the deadeyes are installed, there is a railing in front of the holes.. :-/
Make sure you can get to them. I had to rip a couple of mine out and redo because there was not enough room to work.
I found it easier to thread the lanyards to the top deadeye without tightening before installing.
(Most of them, I had to thread in place with masts and shrouds in the way, and I found that much harder)
/Peter
Hi Nenad,
The alterations to the aft deck house were done under  the Portuguese when she was owned by J. Ferreira and Co. Longridge's book has her with this configuration. Her original front was removed and replaced with a taller entrance with doors on both sides.  Also the rear entrance was added.  I'm not suprised that they didn't restrore the original entrance.  It wouldn't have been good for visitors - only one entrance/exit and not very tall, you would have had to keep the booby hatch portion open so people wouldn't hit their heads and I'm sure that it wasn't as water tight during rain as the solid top with side doors.
My Mantua model plans have the current hatches for the aft deck house.
Here are images from the plans
Using known measurements versus the plan and using ratios, it appears that the height of the forward structure from deck to the top is approximately 6 - 6.5 feet high and approximately 3 - 3.5 feet wide.  The aft structure is approximately 5 - 5.5 feet high from deck to top and approximately 2.5 feet wide.
I'll check Longridge's book and see if he provides a better description of dimensions
Hope this helps
Marc
Edited by keelhauled
Now you see it !!!!
Now you don`t  !!!!
That chimney moves around some!  When it does appear in your photo it isn't in the same position as it is in woodget's photo and campbell's plans!
Isn't the part on the deck in the see me photo the bottom of the poop rail where the buckets fit.  If so they must have removed it and had it just sitting there while they were working -maybe?
Nenad,
Longridge provides more info.
The forward companion way is 3 feet 9 inches wide and 6 feet 6 inches high.  It extends aft for 4 feet 6 inches.
I can't find where he provides measurements for the aft companion way.
Very usefull informations Marc. Thank you very much!!! I'll use them when I return to AI from workshop
A bit of progress
Whole down line of dead eyes for aft deck made.
Interesting. With redrilling holes, sanding, shapeing and twisting Cu wire and soldering as neccessary steps per piece, it goes faster than I hope
In mean time, life just do not know what is enough. My mother in law (80) gets seriously ill.( probably cancer, tests are running jet). She lost his husband two years ago, my late Admiral was her only child, and her death two months ago, hits old lady very hard. I left as her son in law, and as I very respect and love old lady, I must and want to take care of her until the end. And kids are here. Fortunately, her flat is 5 min of slow walking from our house. Begining of court seasson at september 1st and this situation may slow down my work on CS
Edited by Nenad
In progress:
Content of log :
Past build:
Nice deadeyes, Nenad.    Life happens and gets in the way of the shipbuilding.  And that is probably the way it should be.  The "not good" part is the sadness that happens.  Take care of yourself also.
Hi Nenad
I'm sorry to hear that once again, you and your family are facing challenging times. Life is not fair at the best of times, and you have certainly been hit hard.
Please take care and be comforted in the knowledge that your MSW friends are thinking of you.
Patrick
All my hopes for a quick and easy recovery for your Mother-In-Law Nenad.  Family always comes first, and "Her Majesty" will be there waiting.
GEORGE
Sorry to hear about your mother in law.   I'm glad that your mother in law has you to help take care of her.  I've been very fortunate to have loved ones help me when I needed it and I'm glad when I can help my family when they need me.  It's just one of the wonderful aspects of having a family.
As you take care of everyone else, don't forget to take care of yourself.  You've had a hard year and need to stay healthy as well. Make sure you take time to lower your stress.
All the best to you and your family!
By the way the work on the ship looks great!
Marc
Adding my thoughts and best wishes for a full recovery for your mother in law.
Your CS looks wonderful and will wait patiently.
Cheers,
Nigel.
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
Hello my friend, let me add my best wishes for your dear mother in law and hope that she'll recover soon.  You too must take care of yourself and reduce the stress level your in at this time.
All the best from Piet,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Keep your head up and keep a smile on your face, my Friend.
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
It is really wonderful to have all of you here and around, particularly when hard times are here to come
Dead-eyes for aft deck painted and ready to mount
Hell work to paint Cu wire around in such a scale
Edited by Nenad
In progress:
Content of log :
Past build:
Nice painting job Nenad.  Having really good eyes and a very tiny brush is always helpful.  :)
GEORGE
your doing some great progress on her Majesty :) ........even under the saddest of circumstances.  take care my friend....I'm thinking of you  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
