30E50012-D2A8-498A-ABC8-921B69907910.thumb.jpeg.042415a11537d4fedc254db29a2cce64.jpegNext build, a series of British ships I think, is the HMS Kent from 1942, one of the 4 such ships of this period (the modern Frigate HMS Kent will be next).
There is a dedicated PE set for some of the other County class ships but not Kent so some jury rigging will be needed plus extras etc
my plan is to weather her heavily as she was doing the Murmansk escorts at this time.
Jamie from Sovereign Hobbies has pretty much the most accurate paint scheme which I will use.
Greg
So the PE is from everywhere, plus spares, and I’m using the Micromaster.co.nz 3D upgrades. (I’m still awaiting the last three guns for Strasbourg which will be a couple of days to paint up so I can park her).
the only thing not readily available are splinter mattresses which I’ll scratch build I think.
luckily Joy Yard realises that by the 1940’s the Wooden focsle was replayed by meta and provide that with the deck set.
Greg
It looks like there is going to be more Micro Master in this build than there will be Trumpeter! Are those Profile Morskie plans? I have his plans for the Exeter and almost all of the ABDA ships of 1941, and along with the books he has, are very nice.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Yes I have heard that he misses some things even though all of the plans I have gotten from him seem meticulously detailed. But I am no authority on most of them as the only ship of the group I am referring to that I have personally researched in great detail is the Houston and there is very little available on her in the 1941/2 configuration/color. I would love to get a 1/350 HMAS Perth as a companion build, but that is even harder than getting the Houston, it would have to be scratch built!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Another interesting subject to model Greg.  Despite the heavy dependence on after-market parts to dress her up, the hull itself seems like if is fairly well defined for her armour panels and the like?
cheers
Pat
The Hull is quite nice but will need some work to make her look real. The camouflage pattern will be pretty dominant and therein lies the challenge of oil canning at different colours. The deck was also painted over so that’s going to need work as well. Most kits these days are starting to replace a lot of the finer details with their own PE, but this is no where as complex as the Fletcher or Spruance was to build.
Greg
Your scratch catapult is amazing
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
I agree with schooner, your catapult is fantastic. Does not look scratch at all.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
You are at your usual leisurly pace. It seems I'm in the nick of time to get into the build!
Your catapult looks real good. I wonder if you could have replaced all the PE with the spares you have laying around from previous builds ...
Carl
Have a look at HMS Belfast pictures, she's about the same period. Those ships do not have any clearly visble oilcanning, only the quick build from thin material US ships had that effect in WWII
Have you thought about Mr Surfacer 500 in rattle can? saves spraying a lot of layers ...
Carl
She has some pretty good lines, so I’ve now cut in the plates. I’m going to oil can her below the waterline ( because I can really), the RN had a serious shortage of enamel for their paints and o it the boot strap was good quality as that was the highest exposure area at the waterline. I have to finish my last guns for the Strasbourg this week.
Greg
