Thanks Rusty for the info.  I have a small sample and after seeing your use of it, I'm thinking this wood could be very useful.
Thanks David. I get all of my wood from Jeff Hayes at Hobby Mill. :)
http://www.hobbymillusa.com/
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I was able to get the fenders made and installed. With the moldings in place that would
require cutting notches into the fenders and getting them to fit the curve of the hull too.
Hmmm seemed a little difficult to me. Then I remembered Chuck (thanks again!) had
us cut the molding away and just slide the fenders in place. Then I just had to sand
them to fit to the hulls contour.
Fit was good and it took a fraction of the time and no waste, oh ok I messed one up
and threw it in the scrap heap, but to me that is no waste! :D
Rusty
Thanks Paddy, Grant.
Ben, There was so much I learned doing the Confederacy and I still look back at
the practicum every once in a while.
Here I’ve started making the entry step. I first cut the angle for the bottom portion
and then made a second cut forming the tread lip.
They were then cut to length and the sides trimmed to match using a xacto knife and files.
Now I just have to finish making them, 18 total are needed.
Rusty
Looking great as usual, Rusty. Pretty soon, with all the progress on Triton, you're going to have to turn your attention to your other two projects.
Bob
You're right Bob. With less available modeling time during the summer
I've been giving the Triton the majority of that time. :)
Rusty
this may be a slly question, but what is Par Marfin please? I have tried to 'Google it' without succes.
regards,
Rob (Oxfordshire UK)
Hi Rob all I can say is :wacko:  :blush:  :blink:  :o . Typing was never one of my strong points.
I went back and hopefully made all the corrections. :)
Rusty
Well all of the steps have been made and attached to the hull. The back of
each step had to be sanded to fit so the tread was level. I did them one at a time
so I didn’t mix them up. To keep the steps in an even row I clipped a ruler
to the hull and used it as a stop.
Then while I was working on the Triton the Admiral called to me and wanted
me topside. Being the good mate I jumped to, set the cross section down and
went to see what was up. Upon returning to the shop I looked at my work bench,
and mind you I have a mastiff that can put her head on my desk with all four feet
on the ground and regularly does, and almost had heart failure…………...
:omg:
I tipped toed over, gently picked her up and placed her squarely back away
from the edge. Needless to say I didn’t do anything more that night. I figured
I had used up every bit of luck I had and only bad things could happen! :D
Rusty
Very nice job on the steps.Put this one away in my notes for further reference for when I get to them
1. Place ruler for stop for steps
2. Always place build AWAY from the edge of the table  :(
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Very nice Rusty. Good tip with the ruler - thanks for that. And a lucky escape too.......... :)
Edited by gjdale
Thank you all for you kind words. The ruler was what was at hand
but any flexible straight edge will do.
Ok the nerves have settled a bit. I guess I can start working again.
I've wandered back to the gun carriages. I cut them out of Bloodwood.
Just because I had some and wanted a little color variation. :blink:
Rusty
Looking good Rusty, I lost all my MSW stuff (downloads etc. that is) after the the big crash + my own sytem had a 'melt-down'.  So now it's back to 'square one' for me.  I'm hoping to make a start on the Englsh Pinnace kit soon, it arrived in the mail a couple of days ago. :)
All the best,
Rob (UK)
Thanks Paddy
Hi Rob Yes the great crash of 2013 did touch us all. I learned I hadn’t saved as much
of my work as I though I had and having a system melt down to boot would have
been terrible. Well we all just start over where ever we can.
Good luck with the Pinnace. It’s a wonderful kit. :)
Rusty
Rusty,
the gun carriage components are looking very nice. Were the sides shaped individualy, or did you shape a block then cut the sides from it?
Regards,
Grant.
Thanks Grant.
They were done individually as I did not have a block big enough. I set the
table saw blade for each cut level and the cut 5 blanks progressing from
lowest cut to highest. The extra one was for an oops moment. :o
Rusty
Re the "oops moment", this project has taught me to always make several more of everything that is required. The times I didn't, meant having to set up heights and jigs etc., all over again. It's a valuable lesson. Good to see you're on top of it.
Regards,
Grant.
Hi Grant, Oh I've had so many oops moments and there wasn't always an extra piece made. :huh:
Well I've assembled the carriages and painted the barrels.
Sorry Ben but I stopped at ten coats of paint. :o
Next it’s time to do some iron work and soldering!
Rusty
The guns look terrific with that bloodwood, Rusty.  Don't let 'he of the 20 coats' give you any grief.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Thanks Augie, Ben and Bob.
Hey if you add the two together I came up with 20 coats! :D
Rusty
