I picked this up just before our second lockdown.
Being a plane from the WW2 Pacific Campaign I couldn't resist.
I'm doing it straight out of the box, with no aftermarket. 20201216_103455.thumb.jpg.e7f24cfd77d4fc28be389e52e8f41890.jpg
So far I've only just began painting the parts that can be done whilst still on the sprues.
I'll get some photos when I start gluing it together.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Ah, good ! I get the best seat this time . 😉🙂🍿🍺
Jack
Current buildUS Constellation
Im also here Edward  - wont be long before the rest of the clan turn up.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Now I know I said no aftermarket.... well, just been doing a bit of googling  and the Aries cockpit looks too good not to have😬😇😊 .
Welcome gentlemen, I imagine the popcorn is on its way, Enjoy!!
Current builds;
Completed:
One machine coming up.
Jack
I love the Corsair, and Baa Baa Blacksheep was one of my favorite shows as a kid (even wrote a letter of protest to NBC when they announced its cancellation -- received a glossy, Robert Conrad-autographed B&W print of the cast as a thank-you gift). The few available card models of the F4U aren't particularly detailed. I'm waiting for Halinski to publish one, then I will be all over it.
Current builds: Brigantine Phoenix, Vought SB2U Vindicator
Whistling Death was the nickname given this aircraft by Japanese Marines, It was based upon their experience and admiration for the job this AC could do in an air-ground delivery role... (trust me, they REALLY understood) In my opinion one of the five best aircraft in the world coming out of WWII....
I'm in....
Hey Chris, GPM does a reasonable Corsair..... (not quite Halinski, but very close)
Quote:
Something about building these old kits it's called .............nostalgia! I have two Hurries on the desk getting decaled one is the the ole Monogram about 66-72 abouts.I have one done and two to go all Africa and Sicily will be looking in if you don't mind. ;) Kevin
Thanks to everyone who clicked or commented.
The aries cockpit was delivered today 🙂🙃20210514_204519.thumb.jpg.7ef31c2e8bd3eb3255b3c5b0bb5321a7.jpg
this will be my first foray into aftermarket add ons. It's also a first for PE as well.
 I'll probably be a bit slow putting  this together, and there'll be a bit of alterations to the kit fuselage to get it to fit as can be seen on the box it is primarily for the Trumpeter kit of this plane 😬
Cheers
Current builds;
Completed:
You're very welcome Kevin, although I may struggle to match your standard of finish 🙂😉
Current builds;
Completed:
If it is your first with PE, a couple of suggestions, if I may (this is what I do):
- Cut the parts from the fret with a sharp blade on top of a very thin cardboard which is on top of a hard surface (a glass tile), keep a finger on the part to be cut, because often they fly away entering in a spacetime wormhole you did not suspect you had in your room.
- File the edge with a diamond file, do not try to cut away the residual fret attachment.
- If the part get deformed, try to flatten it by rolling a round rod (the aluminium handle of a cutter knife) on top of a glass surface.
- Sand slightly with a very fine sand paper the surfaces to be glued.
- If you need to fold a part, do it on a glass surface, pressing a blade along the folding line and lifting the part to be folded with another blade. Doing this under a magnifier lens helps a lot.
- A good sharp pointed tweezers will help a lot to handle and position the parts.
- Do not rush, as soon you get tired or bored, stop the work and come back to it later!
Good luck,
Dan.
Thanks Dan, I  shall be putting your method and suggestions in action later 😉
Current builds;
Completed:
AH At last someone is getting around to the  Ensign Eliminating Bent Wing Bird. That after market cockpit looks awesome!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
My el cheapo tweezers have a bad habit of initiating that phenomenon.  🙄
Thanks Lou,  welcome to the show, and I had to look the Ensign reference up, interesting reading!😉
Current builds;
Completed:
Yes, USN didn't appreciate the Corsair and dumped it on the USMC. The higher landing speed needed experienced flyers coming aboard USS Boat.
Ken
Started: MS Bounty Longboat,
Think I already mentioned it  - my late farther used  to work on the British Navy version  on a land based  station, he used to say they were over powerd  due to that massive engine in such a light frame.
OC.
Current builds
Completed works.
I don't think there were too many combat pilots that would have agreed with him. There is no such thing as over powered, too maneuverable, or too tough in combat. I don't think I have ever heard of an F4U being referred to as having a light frame.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Today I entered the realm of PE and I'm so glad its at 1:32 as even at this scale it's tiny!
The seat belt is trying me🤯 but of the dozen or so parts fitted only one has took flight, ok its jumped out the tweezers 3 times, found twice, but last reported somewhere among the other MIA bits and bobs😠😤😫.
So things have been put away and a full scale search and rescue is on the cards.
Photos and more progress in the next update.
Thanks to all for bearing with me😉
Cheers
Current builds;
Completed:
Is it an air-sea search/rescue, or land only?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Land only, but the mountain rescue will probably have to be involved due to the nature of the terrain 😉
Current builds;
Completed:
You need a good sniffer dog  to find them....
OC.
Current builds
Completed works.
I think he may have been referring to their ground handling  - I'm sure he told me some of the Erk's had to hang of the rear tail  to keep the nose because of the more powerful engine  - he did tell me about some of the mods to UK FAA  versions  like the clipped wing  (by Eight Inches each side)  for carrier hanger clearance when folded, also something about  them bouncing  on the deck when landing  - needing the shocks to be softened  - and the seat being lifted up  for better view through the Bubble canopy  Brit versions had.
OC.
Current builds
Completed works.
I can see how far behind I am in this forum!..........sweet project I see here  ;)   pulling up a seat too!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi all, after four days the search has been called off, the bench was cleared, everything from the vicinity was shook or tapped over dark blue towel, I even tried the women's tights on the vacuum,  all to no avail😔. Hopefully I may be able to mock something similar up from some thin copper wire flattened ( the piece in question was an 'L' shaped buckle type thing for the seat belt), once the cockpit is all together it'd be hard to see anyway.
just a couple of photos.
It's going slowly, but steady🥵 I just have to remember to breathe😉20210516_220728.thumb.jpg.63a0b30d08b9ca015bb388bc9888f5b6.jpg
I appreciate you all calling by and the likes.
Cheers
Current builds;
Completed:
Looking good from here. Sorry about the MIA part.
Jack
