Martin,
thanks very much for your wishes. I`m also looking very optimisticly into the new year and counting with many inspirative builds and ideas to come.....
I have here found a lovely kit bashing inspiration for the scale 1:64 "HMS Fly", resp. "Swan Class" Builders, I like very much, in a Dutch forum, and wich I find should be shared wih others.....
https://modelbrouwers.nl/phpBB3/viewtopic.php?f=4&t=37813&sid=9530e1c699673b50aa456ed7ee788939&start=20
Wishing you all the best and a smooth and happy entry to 2016
Your freind, Nils
Current builds
-Lightship Elbe 1
Completed
Name for standplate and start of display case
the standplate gets two identical nameplates, depending which side will be turned to front later on. The glass display case will be L x W x H , 90 x 26 x 75 cm,
The wooden base and the framework will be stained in cherry tone, before the parts are mounted. The ordered glass panes and the reinforcement metal corners I am holding already
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Update display case.....
Nils
Baseplated stained in cherry tone
The framework, also to be stained,  is positioned with round 3,5 mm diam. pins  in 6 places, that are centered in bushings. the pins are screwed into the baseplate, not shown here. The grooves for taking up the glass are 4mm wide and appr. 4mm deep
corner- and side bushing carriers (here dummy), mounted and soldered
corner with reinforcement metal fittings
Current builds
-Lightship Elbe 1
Completed
nice start on the case Nils........the color looks so warm  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nils, Are you using safety glass for you case? Do you prefer glass over say plastic?  Do you build in some sort of venting for the case to breathe.
Someday I will need to build some cases to keep the eightlegged riggers from adding additional lines.
Edited by steamschooner
Zipper hydroplane(Miss Mabel ) finished
John Cudahy  Scratch build 1/4" scale Steam Tug
1914 Steam Tug Scratch build from HAMMS plans
1820 Pinky  "Eagle" Scratch build from; American Ships Their Plans and History
Thank you Denis,
all my cases to date are made in this way, the tone fits everywhere (room, furniture, sideboard, etc...)
Nils
Current builds
-Lightship Elbe 1
Completed
lovely Steve, ....."the eightlegged riggers".... adding additional lines,.....
I prefer and am using regular window glass, 4mm,  for it`s continious clearness, it`s stiffness, easy cleaning and less tendency to static loading (dust).
The disadvantage is the weight of glass compared to plexiglass, but if the display case rests on a sideboard or well fastened shelf afterwards the weight is not a knockout criteria. Regarding to the venting, there will be no extra openings, in fact I tried to avoid any gaps or openings, for keeping out smallest dust-particles. I`ve practiced this with good success for years already. A set of precise cut and deburred glass panes costs me appr. 50-70 Euro, depending on the size from my local glasser`s shop. Guess that plexiglass will be appr. the same costs. When putting the "bonnet" part down over the model to rest on the display case base, and have the pins slip into position it takes two adult persons to do this slowly and carefully.
Nils
Current builds
-Lightship Elbe 1
Completed
Base with positioning pins and top cover (glassed) done, now the sides need to be framed and fitted....
all wood is stained in cherry tone
Nils
the top cover has excatly the same outer dimensions as the base frame
here the brass pins can be seen in place (in 6 places)
Current builds
-Lightship Elbe 1
Completed
A beautiful case for a beautiful ship.  What could be better?
Bob
Current build:  SS_ Mariefred
Thank you very much Bob and Anthony,
Your kind comments are much appreciated....
looks like the case is coming together quite right, the glasser did a good job when  cutting  the glass, so I could do the wooden framework with quite narrow tolerances. Guess that the sides can be fitted tomorrow and perhaps also the metal corners. The ship on it`s stand will rest on the case baseplate, and be fixed with small strips of double-side adhesive tape to avoid shifting inside the case.
The case is tailor-suited to fit on a wardrobe in my hobby room, so that the view from at least 3 sides will be granted
Nils
Current builds
-Lightship Elbe 1
Completed
Display case,.... the final....
today the display case has been completed, and sowith the project is done
Nils
the preliminary "grip" on the upper large glass side is fixed to the wall cupboard and is a useful third "hand" when mounting
put the model in it`s place already whilst mounting sides and top
pictures taken through the glass never auto-focus correct (sorry for pic quality)
I use these screws rather that sink head screws because of the better strength and handling
Current builds
-Lightship Elbe 1
Completed
Ein klasse Abschluss Nils :) Super!
Gruss,
Dirk
Danke für die netten Worte Dirk,
will be switching to the KWdG model, but have to clean up my work shop areas first
Nils
Current builds
-Lightship Elbe 1
Completed
Super, super, super Nils!
:stunned: :stunned: :stunned:  :im Not Worthy: :im Not Worthy:  :stunned: :stunned: :stunned:
(By the way - do you already save money for a forklift? In astonishingly short time , I'm sure, you will have finished your KWdG and most probably will need one then to move around that model and it's case.) ;)
Marvelous - first class work!
Thank you very much for your appreciative word Mark,
this model (in scratch build) has found quite a large interest by followers of the log.
Thanks again to you, and all that made their kind comments, suggestions, appreciations, expressed their "likes", I would be very happy if I was able to provide the one or other inspiration to my 1:64 scale fellow "Swan Class" builders.
Nils
Current builds
-Lightship Elbe 1
Completed
That`s a very fine compliment Peter,
many thanks to you, Slowly there are some more "Swan Class" gun sloops, next to yours completed, and coming in the near end phase, trust there will be a real fleet with MSW one day....
You`re right with the imagination of forklift moving of those cases. The KWdG Hull is looking at me all the time, and saying..... I`ll need an appr. 1500 mm long dust protection case one day, what are you going to do about it ?.....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi, Nils, Beautifully done, incredible workmanship
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Patrick and Pete,
thanks to both of you so much for your nice words and compliments, very much appreciated, glad you like the model
Nils
Current builds
-Lightship Elbe 1
Completed
Atta boy Nils.  Job done, and done really well.  It's not surprising you had such a big following for this build.  Yes, the model is great, but a big part of doing HMS Pegasus was how interactive you were with all those who took interest in your project.  The sheer number of comments and the richness of the posts and replies says a lot on how much you are respected by the group.  Your build log was wonderful.  Thanks so much for sharing.
Tom
Tom
Tom,
thank you very much for your nice compliment, it is very encouraging..... :)  :)
Nils
Current builds
-Lightship Elbe 1
Completed
Nils -- Why am I not surprised that your display case shows a high skill in framing?  Your work has been, and will continue to be, a real inspiration to all of us remaining Swanners.
Congratulations on your completion, Nils.  And like everyone else, I'll be looking forward to more of your craftsmanship on KWdG.
Bravo!
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Martin,
I thank you very much for your congrats and your nice words. This build was a nice experience to go through, I think the rigging part was the most challenging....
Hope to see your next progress on the "HMS Fly" soon.
Here`s a shot of my work area, all cleaned up again, its surrounded with ship models, my little maritime  "museum", ready to go for continuing the KWdG (under plastic, in the moment) stapled over the "Gorch Fock"
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful Museum Nils, Looking forward to the HMS Fly
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi Nils, many will be jealous of such room, you have a beautiful collection of wonderful models - and that's an understatement :-)  Could you show some more pictures of your other models.
Cheers,
Jason
In the shipyard:
thanks to - Pete - Jason - B.E. - Crackers,
for looking in and for your kind comments....
Pete,
my hobby- and workroom is in the cellar of our home, equiped with heating and conected bathroom (was foreseen as a guest room when the house was built)
The HMS Fly I meant, is the one Martin is captain of....
Jason,
Thanks I know, lucky me, for the room....., If you like, the other models can be viewed by clicking on the links in my signiture, it takes you to the build logs, go to the last the individual last posts there for final pics...
All models pictures are also in the gallery for completed scratch built ships, only the "Bohuslän" steamer is in the kit-built gallery for completed ships
B.E.
every time I have completed a model I find no suitable place in the other floors of our home, so the last solution is to hope there will be a place in my hobby room. Trust the space is exhausted now
Crackers,
yes , by the time and unwillingly my hobby-room becomes a bit "museum character", but I like to have the models in view when sitting at my desc, and my wife kindly lets me arrange the interior as I desire
Nils
Current builds
-Lightship Elbe 1
Completed
Congratulations Nils, I am amazed by the number and speed that you accomplish all these beautiful models. It is good that you put them into the glass cases to protect them.
Michael
Thanks Michael,
I had the Pegasus standing on the shelf with rigging and sails for weeks and months whilst I started the KWdG, and did`nt recognise the meantime dust settlement on the model. So I know what frustrating effort it would take to clean a unprotected model standing over a longer time...
Nils
Current builds
-Lightship Elbe 1
Completed
quite a bevy of boats you have there!   there is no understatement of the quality that you've put into them.   "peg" looks great in her new house.
congratz on the finish,  and thank for allowing us the pleasure of seeing your talent and skill  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
