The resin pour happened this morning. I mixed one batch which hardly covered the "sea" base so without thinking I mixed up another batch of the same size; I was nervous about letting the first batch start curing and create a visible interface. I also only had the one size mixing cups at hand and it seems that accuracy in measuring resin and hardener is critical. Once I had poured the second batch I realised I had overdone things and it was too deep. The "tide" line is submerged and the weight of the resin has caused the masking tape dam to bulge which might give me problems with the fit in the display case. I had a few minor leaks past the tape (again due to too much resin but thankfully I had put some scrap card underneath which caught it all. I should have planned the pour in a little more detail and had some smaller cups ready to do small batches if necessary. The learning process continues.
On the positive side I like the resin. It is very low odour, it is glass clear and it did not entrain a lot of bubbles, The few that were present after pouring were seen off with a few passes of a mini butane torch. It is supposed to cure in 24 hours so it will be interesting to check tomorrow morning.
Possibly because of the extra resin I seem to have go a very nice sense of depth and I really like the reflection of the mountains in the still fjord water. I was going to add some movement to the water surface but I am not so sure now.
1143327019_RIMG0237(1280x720).jpg.feb7ac4d154aeb92a8ed4caf9476f59e.jpg727332918_RIMG0239(1280x720).jpg.4ac89aeaeb3b2836526b8b5bb683c987.jpg
So the cats are banned from the area until this is fully tack free. Their long and light hairs get everywhere and I'm too proud of the resin surface to risk hairs or worse paw prints.
Thanks for looking
Alan
This is looking Excellent Alan  - so worth all the effort  you are putting in to it, the extra works turns a  nice model into a story.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thanks for the kind words OC. I'm really enjoying working on a new aspect of the hobby. I would like to make more dioramas but space is a major consideration.
I was very happy this morning to remove the dust cover and check the resin and find it it glassy, tack free and hard. I removed the tape and cleaned up the rim that formed at the dam with a a sharp knife.
I put the diorama to one side to fully cure (72 hours) before the next step but I couldn't resist seeing how HMS Penelope would look on the water
It looks promising.
I also checked the resin anchor chain against the foredeck and it may be a tad big (but the same size as the flat PE chain) so I think I will paint it and look at it again but it may well be useable
Thanks for looking in.
Alan
Looking good Alan. The reflection of the Cliffs in the water looks very realistic.  Nice job !  👍
Jack
Current buildUS Constellation
On 7/12/2021 at 4:48 PM, king derelict said:
paint and plonk
Hopefully you will get the credit when this term spreads like wildfire throughout the world and becomes legend!:D
Your diorama is coming along nicely.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
The resin fully hardened and I'm very happy with that part of the diorama. The effect of depth came out nicely. I had to sand back the front of the diorama because of the bulge in the dam caused by the weight of the resin but it now fits well into the display case.
I added a rim of gloss Mod podge along the coast and blew it around with the airbrush to get some random ripples. Its not very visible but it breaks up the transition to the lighter colours of the shallow water.
Penelope will now be added and I'm look at working with the anchor chains to finalise the build.
Thanks
Alan2132297622_RIMG0277(1280x720).jpg.954f299cd8b4e191b554e45c587372e0.jpg1277387095_RIMG0279(1280x720).jpg.5a32ee61024cada0725ef24841641405.jpg
9 hours ago, Landlubber Mike said:
That's really amazing, very nice job!  I love the reflection, super cool!
Thanks for the kind comment Mike. The resin pour is an irreversible step and I had read stories of it failing to fully cure and remaining tacky. I tried to be exact with the mixing quantities and luckily the house temperature is right at the resins ideal cure temperature of 76F
Alan
9 hours ago, CDW said:
That resin looks so much like water, it's as if you could literally jump inside. Beautiful work, Alan.
Thanks for the very encouraging comments Craig I'm glad you like it. I think the water effect and the PE catapult on Penelope are the parts of my build that I am most pleased about. I'm now tempted to try another diorama with another model
Alan
I agree with the rest  - its looking Superb.
OC.
Current builds
Completed works.
Fantastic rendition on the water Alan. Your reflection into the water is an extra astounding effect that came out perfectly. Congratulations.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I painted the resin anchor chain (great help from RGL - Gregg - dark blue with dry brushed brown and a rust wash) and installed it on the foredeck. It is a little oversize but it is so much better than the flat PE and it is about the same size. I fitted the anchor chain into the hawse holes and down to the water where a little gloss Mod Podge was used to simulate a little water movement.
The edges of the diorama were painted matt black and after the photos were taken the display case lid was installed.
Thank you all for the support and tips, likes and kind comments. This is the biggest model I have attempted and I learned a lot.
Thanks
Alan
A beautiful model and presentation.   Very impressive.
Very very nice mate.
OC.
Current builds
Completed works.
22 hours ago, CDW said:
You've done a beautiful job on this project Alan. Have thoroughly enjoyed following the build and have learned a lot from watching. Can't wait to see what you do next!
Thanks for the great comments Craig. I'm still learning a lot as i progress though the builds. The diorama was fun and I would like to do more but they take up room. I need to get a display cabinet or something instead of using individual cases
I hope I can live up to expectations with the Geisenau. It looks like another very detailed Flyhawk kit.
Thanks
Alan
