HMS Winchelsea 1764 by glbarlow - 1:48
My Chapter 10 posts were too long, I won’t take the time to do that much again.
The quarterdeck is pretty much the last “big” thing to do, starting with planking and ending with rails. It’s been such a journey from the first framing, through months of planking and the many detailed components assemblies since. Not sure I want it to end.
To keep it short, here are just four final photos of the quarterdeck.
Edited by glbarlow
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Share on other sites
What's next, Glenn?
Ron
Director, Nautical Research Guild
Current Build: Godspeed 2, (Wyoming, 6-masted Schooner)
Completed Builds: HMS Grecian, HMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Link to comment
Just now, hollowneck said:
What's next, Glenn?
Still at least 6 months to go, but that’s a good question. I don’t know yet.
Regards,
Glenn
Link to comment
Very nicely done Glenn. Always enjoy your updates!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Thank you Rusty.  I think I made this one too long, I’ll be more concise from here on.
Regards,
Glenn
Link to comment
First Quarter deck cannon complete and posed next to its main deck companion.
Seven more to go
Regards,
Glenn
Link to comment
Quarterdeck Cannon
No lengthy explanations, the quarterdeck cannon were made just as the main deck guns detailed in an earlier post.
The carriages were freed of char and air brushed.
One difference from the main guns are the cannon; before being air brushed with Ironwood Black I elected to replace the thin resin trunnions with 19 gauge wire by drilling through the guns using my mill. Or perhaps I should say the decision was made for me with at least three of the guns already having the plastic ones broken off while still in the bag. No doubt carelessness on my part.
The production line is ready.
The completed guns sitting (not glued, that comes later) on the q-deck. I always build one extra … just in case.
On to Chapter 11.
Regards,
Glenn
Link to comment
Outstanding high standards Glenn. Every picture an inspiration.
I have high ideals, which of course is not the same as high standards, but I would be beyond joyous if able to match those standards you are displaying.
I am learning my trade on Cheerful but 2025 will be Winchelsea year and along with Chuck’s monographs I shall be having your build log with me as escort.
Thank you
Paul
Link to comment
Thank you for the kind words. Glad my log will be of some help. Both Cheerful and now Winchelsea are great build, lots of challenges and lots of fun - with a little frustration here and there.
Regards,
Glenn
Link to comment
Glenn,
As always, your work looks superb.  I like the idea of airbrushing the cannons.  As I approach that stage with my Cheerful build's cannonades/cannons, I think I may do the same.  It seems a bit tedious to hand paint them all!
Erik
Link to comment
Thanks for the comment Eric. My cannons are a two step process. First airbrushing with Admiralty Paints Ironworks Black (I love the stuff, a rich matte black), airbrushing both the carriages and the guns produces a much more even finish, especially on the barrels. Then a four different brush application of Doc OBrien’s Rusty Brown weathering powder (which I also more lightly apply to the cap squares to bring it all together. Don't know why but the combination turns the cannons into a nice gun metal gray, credit goes to Chuck for the Rusty Brown, not an obvious choice.
Enjoying your work on Cheerful as well.
Regards,
Glenn
Link to comment
I really should get some weather power - your cannons (as well as everything else) look awesome. I have to stop looking before I convince myself that I need an airbrush as well.
You have done a remarkable job with your Winchelsea!
Link to comment
13 hours ago, VTHokiEE said:
some weather power
Thanks for the nice comments.
The weathering powder rally does make a big difference, especially on metal and wood meant to be metal, like my stove. Air brushing too makes for a nicer look on things like cannon carriages.  I had no idea how to use one, but with guidance from here on the forum I sorted it out.  Amazon has some nice, reasonably priced setups.  My advice, don’t go too cheap.  A good brush and an actual compressor is worth the extra money. The only down side is the brush takes about as long to clean as it does to paint, for me anyway.
Regards,
Glenn
Link to comment
Boarding Ladder
I have a friend making me a display stand, he’s an artist with “big wood.” I can’t wait to set Winchelsea on her final home.
I had to turn her over to get the final fitting on the three cradles she’ll sit on - something I should have done much sooner. So of course something broke. Fun it was clearing, cleaning, repainting, 18/0 and 10/0 spotter and shader brushes, and reinstalling this piece, or pieces as they became, (especially the tiny metal braces on the inner edges) with everything around it complete and completely in the way. A lot of patience and slow going, In the end all is ok again.
I made some decisions installing the boarding ladder. First was to remove the complete molding rather than try and cut into it.
I also elected to scrape a pattern similar to the moulding. Then by sanding a 67.5 angle on each side and a reverse 67.5 on the re-cut to fit separated molding I could create an integrated look for the anchor step. Anchor step because I would space the rest based on the fit of this step within the moulding.  I used a round file and 400 grit to round the pattern into the side of each step after scraping them from a length of boxwood strip. I kinda like the result.
I printed the frieze pattern on tissue paper, a first for me. I just didn’t like the outcome of wrapping the top step, partially because I couldn’t get a clean look on the sides, admittedly I didn’t try very hard. While the wrapped step looks great I preferred a natural look atop the frieze. I split the distance between the top and second step for spacing. I lined all the steps up with the right edge of the port, it being perpendicular to the actual water line (the photo isn’t straight on so the perspective is off).
Mini-me had a new view of the ship standing here on the ladder. He's to scale so I like the perspective he provides to size and space. The plans show 6 steps with the last one on the black strake. I measured out how that would work on my particular hull, the spacing would have looked awkward with the top two steps fitted as they needed to be. So I reduced the spacing for the remaining four steps for a consistent look.
But I worked it out.  After measuring, cutting and re-cutting multiple test spacers (2.23mm wound up to be the right gap) to allow a seventh step sitting in the middle of the black strake.
Ahh symmetry … and some drama. Determining the jigs by measuring and remeasuring and making the steps was fun. Removing the moulding without taking the frieze with it, and with  a #11 blade scratching into the multiple coats of WOP to create a bondable surface for the glue provided a few deep breath moments. I used CA, applied with a straight pin onto the step with just enough to adhere without spillover onto the hull.
It all turned out ok. Thanks for stopping by.
Edited by glbarlow
Regards,
Glenn
Link to comment
Glenn, the boarding ladder came out beautifully.  And no one would have know about the slight mishap when turning her over if you hadn't mentioned it.  A testament to your work and attention to detail!
Kenny
Current Builds:   HMS Winchelsea   MS US Frigate Confederacy
Link to comment
Great work Glenn. It always freaked me out when we either had to cut or remove the molding. As aways you did a perfect job!
Rusty
Link to comment
Thank you. At least that piece got a fresh coat of paint.
Regards,
Glenn
Link to comment
15 hours ago, scrubbyj427 said:
Beautiful work
Thank you JJ, as long as we’re having fun right.
Thanks Rusty. Accurate description, and I have so many upcoming opportunities to get freaked out.
Regards,
Glenn
Link to comment
Fenders and Chesstrees
Keeping with shorter posts: Added the fenders and chesstrees to the hull.
Each consist of a center and two outer layers glued together providing a nice dimensional look. After removing char the center piece is tapered from top to bottom and the outer edge slightly rounded before the two very thin are added (amazing to have layered wood on this thin a sheet of wood). With great trepidation I removed the center moulding. Then came a lot of careful shaping to conform these to my particular hull - both patience and time are required following the firm rule of  while you can remove wood, you can’t put it back.
I tried printing the frieze on tissue paper, really I tried. While successful the color and texture just weren’t a good match for me, probably the wrong tissue paper or I need more practice doing it. I was however successful using the original paper printed frieze. Ample use of the same glue stick used for the hull softens the paper and allowed me to get a match. With Chuck’s suggested tooth pick approach I was able to guide the paper into the groove created by the three pieces.
I also rounded out the sheave on the chess tree before applying the outer pieces along with a little 7mm lead pencil.
I’ve still not mounted the waist cannon, but set them for the photo. The addition of the fenders, chess tree, and ladder really bring the hull alive.  My one regret is while the boxwood for the ladder match, the AYC for the fenders are way whiter than the hull despited several coats of WOP. I kinda wish they had been boxwood as well to match the moulding.
I note however, at this point the hull planking is near three years old. I am confident in time the fenders and chess tree, like the hull, will mellow and blend in.
I’m moving onto the waists platforms and will finish chapter 11 with the channels. Thanks for stopping by.
Edited by glbarlow
Regards,
Glenn
Link to comment
7 hours ago, jfhealey said:
Especially folding the friezes around the chesstrees
Thanks, lining them up is a sticky challenge but worked out ok.
Regards,
Glenn
Link to comment
