    Well here we go - after a long hiatus (and a half dozen or so planes, trains, & automobiles) I'm back in the shipyard with the HMS Pegasus.  I won't spend any time on the history, etc - since Victory's Pegasus is pretty prominent throughout the forum. However, I will add a little background why she's my current project.  I have four adult children (3 girls and boy) and three ships to go around.  So I let the youngest pick out what she she wanted to be built for her. Nice choice kiddo.
     As with my previous builds, I tend to mix somewhere between 70% accuracy and 30% artistic licensed - which will be the case with the Pegasus as well. Meanwhile, I'll be leaning pretty heavily on Blue Ensign's build (which I believe sets a benchmark for Pegasus..es... Pegasi? in terms of accuracy) as well as Danny Vadas' spectacular work on the Vulture.  As always - I thank you all in advance for your encouragement and support.  It's good to be back.
   Here's the typical start to the build.  I've gone ahead and added the rabbet even though the plans say it's unnecessary.  As I've perused other builds, it looks like it's probably going to come in handy.
C58F090E-180D-4440-9F29-5A068AE80B10.jpeg C95497FD-1C34-4FEA-9E00-FB4CFE7445B3.jpeg
Edited by Moonbug
 Mounting and letting the frame dry gave me an opportunity to plan out my deck framing strategy. I'm using 4 plank stagger based on Mondfeld's book, as well as Danny's planking example on the lower deck of the Vulture.  Since I tend to get easily confused - I like to draw out the lines on the false deck so I stay consistent.  I'm planning out 90m planks based on the scale, then I color code the stagger.
    I have a fair amount of Swiss Pear left over from the Confederacy build, and jus loved the way it looked. It smooths out so beautifully and just adds a touch of class in my opinion. So I'll be using it on Peg as well.
    As far as planking itself - I'm going to run a 1/8" centerline Kinplank, then mirror each side with 1/16" planks that run the length of the deck. It's much easier to plank the length, then simulate the end butts with a few taps of a razor blade.
        The trenails are always a bit of an issue and very much a personal choice in terms of methodology. This time, I'm going to mark them with a thumb tack - double nails on the butts, and a single nail across the beams based on the size of the planks. Planks less than 10" were singled and not double nailed. Numbering the end of each plank allows me to lay them out and cut/mark all of them before I glue them down to the deck.
    I'll finish simulating the trenails by laying down some of my old school scene glue (from my train village building days) and filling it with fine sawdust.  I've always made a habit of collecting and saving the sawdust as it can serve a variety of purposes, including making a convenient filler.
Edited by Moonbug
The Pegasus is such a beautiful ship. I'll be following along and look forward to seeing your progress.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Thanks Bob & BE, much appreciated.
  Contrary to the plans (and consistent with other Pegasus builds here), I found it much easier to plank the lower deck after it was mounted to the frame. I followed the pattern I laid out on the false deck, keeping in mind I had to cut and shift the planks as I got near the edges.  I briefly mulled over the idea of creating a waterway/gutter along the sides, but ultimately ditched the idea for the lower deck as it's a fair amount of work that isn't likely to be seen and would prove challenging based on how the frames are put together.  Perhaps for the upper deck.
Peg_015.thumb.jpg.113ba2e6da867a5dad7303381e047e73.jpg Peg_016.thumb.jpg.a5edb75cf113dd131aa0dff1545feeb2.jpg
   After the deck was fully planked I gave it a light sanding w/ 200 then 400 grit, then gave it a very light layer of wipe on poly to check and see how the trenails would pull out.
   Peg_017.thumb.jpg.5cf4226d0307c6394c8bbb363838301d.jpg  Peg_018.thumb.jpg.d4afeb72e4962348adc7142943662c2c.jpg
      The lighting on the photos isn't great - but I'm pretty happy with how this turned out.  A little crooked on some of my butt marks, but that was part of the reason for experimenting on the lower deck - I'll refine the technique for the upper decks and hopefully have a cleaner look. Overall, I still love the color and feel of the Swiss Pear even though it's obviously not an accurate representation of the decking of the time. I really think it's going to make the deck fixtures and accessories pop.
    Planking the hull is always the most difficult aspect of a build for me. Not only is it tedious, but it's a challenging and precise endeavour that tolerates few mistakes. Which isn't great because quite honestly - I never really got the hang of it - even after go through all the wonderful tutorials available here.
    To this end - I'm a pretty big fan of anything I can do to facilitate the process for myself.  That means filling the spaces between bulwarks with balsa wood so that I have more solid footing with which to form and mount the planks. I started out by marking and sanding down the bearding line, then filling the spaces with chunks fo balsa.
Peg_019.thumb.jpg.0c859a64877d792d5dde5781b9e2f3be.jpg Peg_020.thumb.jpg.0061bb989b5dc8a48449a856d1f81e29.jpg
    As most of you know, there's just a lot of carving, cutting, and sanding until you get a smooth consistent surface.  Inconsistencies are filled in with wood filler, then more sanding. This is always one of the messiest parts of the build (probably next to sanding the hull itself), and I kind of wish I'd taken a couple of photos of the hobby room and garage during the process.
Peg_022.thumb.jpg.5161546357305c51eae80833e123b63d.jpg Peg_023.thumb.jpg.5eb139077e2164a2d6dfb25641b538c8.jpg
    Once I got a surface I'm happy with, I remounted the keel. I've always had some difficulty with a keel staying in place with just glue (regardless of the type of glue used - especially as the model is moved around and put in and out of a vise) so in recent builds I've developed a technique where I drill a small hole all the way down through the keel into the hull, then use straight pins as mounting nails in addition to wood glue.  This seems to work pretty well, and is an important strengthener.
Peg_024.thumb.jpg.09e9c439992a1cd804d2c5eaafcbda59.jpg Peg_025.thumb.jpg.88cde96946fcce725e417d9851cb070e.jpg
    This last photo is just a fun little sidebar - I don't even remember where I got this soft styrofoam tubes, but they work perfectly to protect the deck when I have to have the ship upside down to work on the hull. An example of using whatever's handy during these builds.
I'm in the same boat with you, Bug. I've come to the conclusion, that no matter how much you read and study about planking, the only way to get good at it is to utilize some of the outstanding examples in the build logs here and then learn from your mistakes as you go along. I envy those folks who have mastered the process.
Bob Garcia
Current Builds:
     So.... this is what happens when you're not paying attention and you knock a little can of wood filler off the shelf onto the deck.  Doh.
    The little repair did give me the opportunity to smooth out the deck a little more and give it a good couple more runs with some 400 & 600 grit.
Peg_028.thumb.jpg.c4ceb7bc39a515d00d8bc3acffe52b50.jpg Peg_029.thumb.jpg.607df9e8d9464741c3a39a132e3d20a5.jpg
    After that bit of a distraction, I moved on the bow of the ship.  one of the things I wasn't thrilled about was the extra 'meat' at the front. I realize a couple things here of course - A - it provides extra support for the upper deck and B - there won't be much to see. None-the-less, I wanted a little more accurate representation of the bowsprit.  Also, I figured it would help me out when it's time to mount the pesky gunport patterns. So, I shaved off the extra materials, put together new bitts to extend the bowsprit.  I'll add a couple more details later (probably manger boards, etc).
Peg_033.thumb.jpg.53840e75cb98ba04497a6e3eaff3f8da.jpg Peg_035.thumb.jpg.3214b73df77729146fb25cc83da3dc67.jpg
Peg_036.thumb.jpg.acca4d3a55a2ae94bd3b1aced5b2beb5.jpg Peg_037.thumb.jpg.ec3d4f562daa506a46c039539b4ed3f8.jpg
Peg_038.thumb.jpg.2fb39008445554b184b5b171b1e9d361.jpg Peg_034.thumb.jpg.18417df6b22df3cbf6380cc8922aed33.jpg
    I test fit the upper deck here just to see how it'd look.
Edited by Moonbug
     Aligning the gun ports always seems like a pretty simple process when I see it on other builds, but always ends up being a little sketchy. Obviously a crucial process and sets the stage for the rest of the planking from wales on down. The pre-fabricated gun port templates with the peg line up pretty well, but of course there's some shifting and bending along the bulwarks.  I soaked them in water for a couple hours to loosen them up, then clamped them to the sides of the ship - careful to line up the ridges with the bulwark posts that extend up through the deck. Then I left them there overnight to dry in that fixed position.
    Then, I glued them along the sides using PVA (wood) glue along the posts and outside the deck and add nails into the bulwarks and posts.  I used a little bit of CA (super glue) on the inner posts just to hold the gun ports in place.  But these posts will be removed later.
Peg_040.thumb.jpg.112952cb4d45b62d1471a8cc665a6651.jpg Peg_041.thumb.jpg.c140f7acf3dcd9f099d528436f62dec2.jpg
  The pre-fab template comes in to pieces that link together toward the stern. This is kinda funky because there's really nothing holding them together and very little space with which to adhere them. So, I added a flat piece of wood behind the seam to bolster the joint.  I'm hoping it's thin enough that it won't interfere with planking - otherwise I'll remove it and let the wales hold it in place as it's planked.
Peg_042.thumb.jpg.c76b103f50206897f85eed9c973eb921.jpg Peg_043.thumb.jpg.3d2b2af28e1bb20addd8ec83a28a3bc8.jpg
    When the hull is planked, so shall the gun ports - so some imperfections will be covered. But, needless to say the smoother the job here, the easier it'll be to have a smoothly planked hull later.
   For me, the deck fixtures are always one of my most enjoyable aspects on which to work. I feel as though putting in a little (or sometimes a lot) of extra time on these pieces really enhances the overall build as they often stand out to the viewer.  Although the deck fixtures included with the Peg are pretty decent, they still represent an opportunity to add some realism.
   The grates are pretty straight forward, and the grate pieces that come in the kit were easy to work with. I did pull out my own walnut pieces for the coamings to get a little more shape to them. Otherwise putting the grates together is relatively standard.  Personally, I like to group the number of grate linings that I need then cut them with a jeweler's saw so I have them as even as possible.  This is a delicate process because the little 'nubs' have a tendency to snap off pretty easily.
Peg_046.thumb.jpg.e618c742208c5a1aeccd81941cac5809.jpg Peg_047.thumb.jpg.f207cf789a205517ac2c04e9f033e4ed.jpg
Peg_048.thumb.jpg.80b85024cdaf606caeeebe9b99f3ac20.jpg Peg_049.thumb.jpg.120ef59bb4a4c56273ec9ef7bff43699.jpg
   My mast partners are pretty basic and made by gluing a few pieces of boxwood together, shaping the edges, sanding out the hole, and then mounting them to the deck. The oddly shaped little fella is the step for the Capstan as illustrated in the FFM.
Peg_050.thumb.jpg.434d4520456755c6bd56194b699919cc.jpg Peg_051.thumb.jpg.3ce377884f4578acfb7a5464f7a61caf.jpg
Peg_045.thumb.jpg.e2edf4de828eca499fe510a20380cfdc.jpg Peg_052.thumb.jpg.667d5ae247fc180d47e0f473f97ceb06.jpg
Peg_053.thumb.jpg.32b07b456558800a906a527f474453ae.jpg Peg_054.thumb.jpg.87cbc2c880e449cf52e8f53bd5ce9f94.jpg
   Admittedly, I have a bit of an unhealthy fascination with Capstans. While the Capstan parts that come with the Peg are alright, I really wanted to get this one right. So - I did what any rational builder would do - I consulted not only Antscherl, but Dan Vadas' Capstan build for his Vulture.
    I used the Victory kit capstan as a scale guide, and some leftover boxwood strips to build out the parts. Following Dan's process, I channeled out the slots in two halves of the top then worked them together. I had to rig up a way to get it into the lathe, but that allowed me to even out the circle and also carve out a channel for the ebony parts.
Peg_055.thumb.jpg.e903fffc84547707d14b39cf52769f84.jpg Peg_056.thumb.jpg.6865c18c9c8fad3e9c0b7c7e0d684747.jpg
Peg_057.thumb.jpg.32c392efc544e5e8b186b4b09b148b35.jpg Peg_058.thumb.jpg.2809db9fc15d7af15af26610fbe00899.jpg
   I don't have much in the way of equipment in my shipyard (other than my nifty Proxxon lathe), so I had to use some alternate tactics than Dan, including much use of pin files, x-acto, razor blades, and my handy dentist picks and tools. I also don't have any ebony or super dark wood in my stash, so I used ebony wood filler. I loaded it into the channel, then scrapped it flat and even with a razor blade. This particular wood putty doesn't dry solid, so sanding it requires at least 600 - 1000 grit paper and a VERY light touch or it just smears.  I topped it all off with drilled holes and cut off pins.
Peg_059.thumb.jpg.29870494a75c5f27368ff67404676297.jpg Peg_060.thumb.jpg.d415b783548f7f44b60488ce41a2e221.jpg
    The 'body' of the capstan is relatively standard stuff - I had to do each of the whelps individually without machinery. I split a couple of boxwood planks and glued them together, then filed out the shapes of the whelps. From there, it's gluing them to the base, filling in the gaps and sanding it all down. Clearly I'm going to have to do some work with the framing to get this guy to fit, as well as connect the two capstans.  More to come on that.
Peg_061.thumb.jpg.c924378bb044daab41e0813be9fbd7ab.jpg Peg_062.thumb.jpg.61fb21268c0a243d375761ae3d299762.jpg
Peg_064.thumb.jpg.b6612f1d8620634daee5ea277977442f.jpg Peg_063.thumb.jpg.5ca0f5df00e8fa5862134a239ebb6d24.jpg
   The bottom capstan was relatively experimental, so I shored up my process for the upper capstan.  I used the same basic process as the bottom for the drumhead, and I put the whole thing back in the lathe to even out the diameter and carve out the channel for the ebony.  Lest you think this all went smoothly - my first attempt at the upper capstan turned out pretty crappy.  Too wide of an ebony circle , kinda thin, and overall just kinda crappy looking.
    So I gave it another shot using three sections of boxwood instead of two, carving out the capstan bar holes from the middle piece. This extra thickness gave me some wiggle room when it came to shaping the drumhead. I sacrificed one of my chisels to get the right sized notch for the ebony ring then used the same wood putty filler and smoothing the whole thing out.
Peg_067.thumb.jpg.d083760a606ad25d6c5ca229c493cb3c.jpg Peg_066.thumb.jpg.aa7e74f11d8ee79f4b36e32afe10e2cf.jpg
   Finally, after adding the whelps and filler pieces, I connected the two capstans for mounting later.
Good to see you back at it, Bug.  Looks good and you're moving fast it seems.  :)
Thanks Mark - honestly, I'd spent so much time out of the hobby room dealing with work and life crisis, I'd forgotten how much I enjoyed the quiet time in the shipyard.  So I may be obsessing a bit.
Also - if it seems as though I'm overly focused on deck fittings to avoid planking the hull...  that is also correct.  😛
it was so good to hear from you again....I had to see what you were up to :)   good to see you've come back to the table.......you've certainly picked up where you left off!  I hear you on the planking.........being accustomed to cloning hulls,  I can attest to the fact that no two hulls will ever be the same..even if it's the same style hull.    I have no doubt you'll do fine  ;)   I've been in the same boat lately........everything else ....except ships {the admiral is getting mad at me} ........kits from at least a couple Christmas's ago,  and I haven't touched them :blush:
good to see your back........she's looking very good :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
   Managed a little bit of work in the shipyard last night despite having to spend much of the afternoon after work in the yard taking care of our yearly "Leaf-pocalypse" that occurs.  Looks pretty, but a lot of work...
      So, a relatively short update working on the lower deck doors to the cabin areas.  I was quite tempted to mock up the cabins though they will not be visible (mostly of the cool work done in several of the other Peg builds here), but then decided against it.
     However, I did want to set a bit of a 'barrier' to the deck by crafting a doorway.  I started with a firm template to measure out both the measurements and the deck slopes, and actually glued it to the beam. This let's me slide it in and out of the space until I'm ready to mount it.
Peg_070.thumb.jpg.9dd9cfd0d90f14c5707f9ab5f51fa23f.jpg  Peg_071.thumb.jpg.299d3eab0e38c424fcede5bb3c63aded.jpg
     Pretty basic stuff after that, measured out some framing and doors.  I carved out some relief in the doors to give them depth and shape with some pin files in case someone gets frisky and tries to look down in there at some point. I gave that several attempts and this is about as straight as I can get those by hand.  Really need to order that drill press from micro-mark.... Christmas is around the corner right?
Peg_073.thumb.jpg.98eb99a9dfd48599dd7cf077648aa0d8.jpg Peg_074.thumb.jpg.a75e16142d1da117ce3c8066cb7a9915.jpg
Edited by Moonbug
9 hours ago, Wahka_est said:
Really nicely set up build log. Collect all the posts and prnt as book to go with the ship :)
   Thanks Vahur!  I've seen other folks do this, and it might be a good idea for this one, especially since the build is for my youngest daughter.
  Ok - Lest you think I'm not actually going to plank the Peg - these next few photos show that I have indeed actually started planking her.  After a good two hours of re-reading tutorials and watching Chuck's videos, I finally plunged in. As you can see, I've got the tutorial and measurements all laid out so I can go by the book.
  I measured out the plank sizes and divided the hull into four sections.  I used some old pin-striping tape to mark.  Then, lo and behold I actually laid the garboard strake.  More to come on planking of course, but I'm taking it very slow.  I've also decided with the first layer of planking I'm going to go with stealers - especially since I'm not cutting my own plank sizes, but using the kit wood.
A03D3729.thumb.jpg.728436f89fe107f615d694760b08b690.jpg A03D3730.thumb.jpg.138cfe099ffcfc4e92e3e23074476dbf.jpg
A03D3731.thumb.jpg.2346137dd2d1a97f64dbf740544edd6c.jpg A03D3735.thumb.jpg.43e1c0ba906a43dd2420092a1933492c.jpg
   Incidentally, this is also the first time I purchased and used the little screw in plank holders from Micro-Mark. I saw them on Dan Vadas' builds, and I've gotta say - they work pretty great.  The only downside with the Peg is that they have tendency to split or strip the MDF if you're not very slow and careful.
   Even though it's going to be nearly impossible to see, I too (like almost everyone else) wanted to do justice to the Ship's Stove.  I took the plans from Antcherl and also inspiration from the various interpretations by Blue Ensign, Dan Vadas, and others.
  I began by carving out and putting together the basic frame of the oven, then I needed to measure it's scale on the deck.  The stove barely fits between the bottom and quarter deck with the vent/chimney sticking through the upper deck.  In order to accomplish this measurement, I had to go ahead and trim the bulwarks so the upper deck would lay flat. The Victory kit has these little notches that stick up through the quarterdeck.  It's a no-brainer that they have to go. Not just for this reason, but because they inhibit proper planking of the decks.
Peg_075.thumb.jpg.9799621cc959114e3043521113c0fd9d.jpg  Peg_076.thumb.jpg.1e11cc13eb371b05bc0af11a25a48d0a.jpg
    Once I had the basic size and shape figured out, I started adding the small elements of the stove like the side doors & hinges and the grates. I dove into my little trove of miscellaneous little scraps and cut and shaped brass strips left over from other builds - mostly the Stagecoach I built the Admiral. Some other parts I used were old stanchions and port lid hinges.
Peg_078.thumb.jpg.4d6c3ddadc6d2093391745e97f5c8585.jpg Peg_079.thumb.jpg.bf07b39a72137fb926e52c2e5374ba3e.jpg
    There are a couple of really specific pieces for the stove - the grate and also the hooks that hold the rotisserie bit on the front of the stove.  This is where it's really handy to have built other ships - especially, in this case, Chuck's USF Confederacy. Not only is the Confederacy also a 1/64 scale, but there were a plethora of extra laser cut pieces.  So I looked through my handy stash of extra bits and found just what I needed. I drilled some holes and used wire pins to represent the bolts. This was a solid three days worth of work in between setting planks on the hull to dry to shape.
A03D3748.thumb.jpg.fdd528145d3610ecdbc8aba38f3ed95f.jpg Peg_080.thumb.jpg.d037ee83631d94a9c3015ccae8b8cb67.jpg
 Peg_081.thumb.jpg.67061bc6480e83fde96fae190b1af5fe.jpg Peg_082.thumb.jpg.4e9a8a38d819ef854e8dde4673438322.jpg
   After it was put together, I hit the stove with a layer of flat black, then a soft brushed coat of this super cool metal-izer that I use on my WWII plane models.
For the final product, I added the brass rails and the little skewer.
Peg_083.thumb.jpg.7261e9d09ed41551a0f0ae80c12bec6a.jpg Peg_084.thumb.jpg.d55f7fc54705e11bbb3194a4a49b74be.jpg
Edited by Moonbug
   I'm continuing to chip away at the planking nice and slow - following the tutorials and pdfs.  As I said, I'm going to add stealers a little later as I go with this first layer.  I'm trying really hard to not let the fact that it's double planked give me an excuse to take too many shortcuts on the first planking.  Not only because I'm obviously trying to avoid the "filler & sanding" pitfalls that make the second layer sketchy, but because it's giving me good practice for the second layer.
   I practiced some spiling by soaking the plank then holding it in place with clamps on my desk. But then I decided to use that practice plank as a jig for some forthcoming planks.  I can adjust the severity of the curve by adjusting where I place the plank holders.
A03D3753.thumb.jpg.e881d12f8f52249c674ae1ff6cba214f.jpg A03D3755.thumb.jpg.5d4be9f5b2267b7f9a68dd5b5b55581f.jpg
  The exercise proved fruitful and I got the first plank below the canon ports in place. I originally just tried to get it in place without spiling, but it turned out funky so I pulled it off and did it again.
A03D3764.thumb.jpg.c92af81017c11f5047ba43e367c0eb3f.jpg A03D3765.thumb.jpg.db8e43600192251336b6467f0ffa2136.jpg
   Meanwhile, while in between planking and waiting for planks to soak and then waiting for planks to dry - I've continued to work on the lower deck fittings. I started on the pumps.  Now... I think it's safe to say that the Cistern that comes with the Peg kit leaves something to be desired in terms of appearance...
   So - back to the FFM reference to get some inspiration for the pump.  I measured out the amount of space that we have between the mast and the grate and it's limited at best. Not much room to play with there.  I started with my leftover boxwood strips to frame out the basic boxes. I added some framing and feet, leaving a little extra space in the front of the pump for the doorway that opens up for the pump dale. Once again - in addition to the FFM, Dan's Vulture build served as a great reference for these details.
Peg_086.thumb.jpg.485f82c88049ba51b759714e977a7fc2.jpg Peg_087.thumb.jpg.559a3b7d2b6f9903b0c98cc6bdb1ed50.jpg
Peg_088.thumb.jpg.a247df321a07e2c5a412e55c5c373b29.jpg Peg_089.thumb.jpg.1d6f8b00c4fd3f0dccb14e875441952b.jpg
   This angle doesn't show it, but I failed in the "measure twice, cut once" lesson this time around and the pumps were just a smidge (a mm and a half) two wide to fit between everything.  Fortunately I was able to solve this problem by sanding all sides of the pumps thinner - giving me just enough room if I notched out the inside legs of the pump to make room for the mast partner.
   I cheated a little bit on the cistern hoods - and instead of making them hollowed out, I piled the boxwood strips to create the right amount of depth, then used a compass to create a rounded template. From there it was a matter of sanding them down. As an additional touch I cut off the ends of a 2mm dowel to simulate the pump tubes that run through the deck.
Peg_091.thumb.jpg.51cac92c4ae4d6a4e84dbce911b90991.jpg Peg_092.thumb.jpg.904ee741a7fe0c11cdbde985566c85b1.jpg
Peg_093.jpg.660443383de405443d3bf89400927ff1.jpg Peg_094.thumb.jpg.13aa4d158e3c8f2b6cd0c85ac6c7aa40.jpg
    There is much more to do with the Cisterns. The pillars need to be crafted and I'm still noodling through how to do the pump cranks. Honestly, I'm not great at soldering this kind of thing.  I can solder the heck out of wiring (I'm completely rewired my Camaro by hand), but silver soldering often leaves me frustrated.
Edited by Moonbug
Hi Bug,
You may be interested in the way I made the pump cranks - Post 72.
https://modelshipworld.com/topic/25331-hms-pegasus-by-richard44-victory-models-164/page/3/
Your Pegasus is looking great.
Cheers
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
Thanks Richard - all input is greatly appreciated - I’ll check it out.
   Thanks everyone for your feedback and likes.  I've been plugging away slowly at planking. One or two strips from the keel, one or two strips from the bulkhead - measuring each where it needs to be spiled or tapered then letting it dry in place before it's glued. Still working on some deck fixtures while the planking goes on, some more cistern updates are one the way soon.
   I'm trying to keep the stealers consistent and not random; using a card to measure - making sure that they don't end in a point and are not randomly placed.
A03D3778.thumb.jpg.901176a45c5e021778065528092ac292.jpg A03D3779.thumb.jpg.304dccd65699bea8017122597fa4f026.jpg
Hey @SpyGlass  - you’re 100% correct. My intention is to lay this layer out as a practicum illustrating number of planks and methodology - then I’ll create second rabbet line and thin it down for the second layer.  A bit of extra work, but will help me plan out my second layer.  I’ll also be able to thin it down the exact amount of thickness based on the second layer planks.
(It makes sense in my head). 😛
Edited by Moonbug
New bounty just in: guns, carriages and a stern lantern kit from Syren. Thanks @Chuck!
    When I put together the ship stove I added a temporary vent that is removable. The actual vent needs to be measured and inserted through the quarterdeck into the stove after assembly.  The realistic vent caused me quite a bit of consternation in determining exactly how to make it happen. It's a very visible piece, so needs to be a good representation.
    I'm not particularly adept at silver soldering, but that was pretty much the only way to go here. There really isn't any kind of glue that works well for small metal bits - and JB weld or other epoxy is just super messy.  At any rate, I cut a small brass tube at a 45 degree angle, then reassembled it 'backward' to create a 90 degree vent.
Peg_086.thumb.jpg.8d6a8287420b448e401e63ddcb79b25d.jpg Peg_087.thumb.jpg.6dce6a819e32a46d120659c478ca6e8a.jpg
   This took me a few tries before I got it right, and got it to stick.  Each time I tried to either sand down the newly soldered vent parts or cut the vent to size, it would break off and I'd have to start again. The vent cover was a really tricky little bit.  I drilled to small holes into a circular piece of brass and used cut off straight pins as mounts.
Peg_088.thumb.jpg.0f43bdebf08dd3be519e72d9cf425827.jpg Peg_089.thumb.jpg.f7bfbb3509a7690d83bcac393231781f.jpg
Peg_090.thumb.jpg.8bde07f9256042d76552d782758df279.jpg Peg_091.thumb.jpg.acd73d7b7f7b0dd6033be696cea8e3c6.jpg
 After measuring to the quarterdeck I sized out the brass vent, then blackened it (which only partially worked). I ended up having to give it a light coat of matte black paint, then the same metalizer as used on the stove.
Peg_092.thumb.jpg.fe3bf63f85764b66815406922172897a.jpg Peg_093.thumb.jpg.914049c7c2f1dc9d8f2b48a38ff12454.jpg
Peg_094.thumb.jpg.408dfdd1f92aea2ea57eb05a1b564840.jpg Peg_095.thumb.jpg.475d1d6d2e23dc08c48b234dca55aaf0.jpg
   Meanwhile, the planking has progressed pretty nicely. As I mentioned before, I've decided to go with stealers so that I can just use the planks from the kit rather than cut wider ones for the stern. Honestly, I'm not that confident in my ability to get them perfectly straight along the length of the hull and don't want too many gaps to fill.   Here's my exercise in stealers at the stern - cutting card stock to measure and use as a template, then fill in the plank.
Peg_106.thumb.jpg.d5468880025ca7688e7fe95c01d4d47b.jpg Peg_107.thumb.jpg.354c0ce8e25d5227426085c56726b946.jpg
   Meanwhile, this little plank that meets the transom and the stern post is pretty tricky. It took me several tries to get the card stock measured, then another couple of tries to translate it to wood.
Peg_111.thumb.jpg.be0f99d9f233b3c36fec64da3bb45310.jpg Peg_112.thumb.jpg.b87e652197951e9dec9efbd85a9a9b09.jpg
Peg_113.thumb.jpg.6e6d4185bf845e52f480a219f523ac00.jpg Peg_114.thumb.jpg.51ab15f1557cd13822188797e4849160.jpg
    From there it was filling in the hull from the keel and the gun ports.  Of course by the time I got to the middle my measurements were off and I needed a couple more stealers.  Despite not having a completely cleanly planked hull, I'm pretty happy with way it turned out.  This is all pre-sanding of course, and I'll also need to thin out the area near the keel and stern to create a new beard line and rabbet.
   Peg_109.thumb.jpg.85094acbc86de74583aadd11fb366a52.jpg Peg_110.thumb.jpg.053dc812b3caabddbf07060d0e4d0cfa.jpg
Peg_115.thumb.jpg.946a58f51bafef5ca4502907660d5344.jpg Peg_116.thumb.jpg.df0412f2a9da66012f0dc41a5586bea9.jpg
Peg_117.thumb.jpg.a06e6b23e30891f429cd4a092c58fc69.jpg Peg_118.thumb.jpg.26e3f013cee519a907e88b3cbb20c1a3.jpg
