Good Afternoon Everyone,
Couple of photos on “Dave’s method for cannon rigging”. This Dave borrowed the idea from another Dave. 👍Thanks Dave. Then… I’d like opinions from those of you who have built the LN or any of the period cutters out there. Do I mount it now, or rig the anchors now? Get the rudder and tiller on? Does the tiller get in the way of rigging?
EC87BDAD-A795-4EB2-8835-19676DB09DF7.thumb.jpeg.26b873b5c4781a1f77bffa248b7615b7.jpegAC7C40CD-B1B1-4838-AD8F-D5035F2A43FC.thumb.jpeg.f50df847e8769689b7c92a0177d6b7a2.jpeg15254574-EF1F-4B79-8656-B798D3CC1AEE.thumb.jpeg.4cde1ae8a52d4c03a39bf605fac9b6de.jpeg
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Hi Dave, everything is looking great. I would wait  a while before mounting the anchors and the rudder.
Best Regards……..Paul
Hey Paul,
I'm really going into uncharted territory now. Haven't done any rigging (except the cannons) since I built a few plastic sailing ships 43 years ago. 😳 I'm kind of nervous about doing anything right now. Mount and call it good? I'M KIDDING. 😆 Every step is an adventure. I did see something I forgot. I installed the belaying pin board, rack, structure?IMG_0005.thumb.JPG.75b9fe395c1dfd578dcc1f360ba49a19.JPG
Dave
 Dave, from experience i'd suggest doing the rigging last. Trying to add elements after rigging makes for lines being too easily snagged and damaged. One damaged line can lead to hours of redo. A rigged ship is a delicate and tender thing.
Actually you should mount it before starting rigging.
Those out of scale fat belaying pins will make it harder to rig. Check out Crafty Sailor for a much better option.
Edited by glbarlow
Regards,
Glenn
Current Build: HM Flirt
 Dave, she's looking great! Your determination has resulted in a smart looking Lady Nelson.
Edited by Keith Black
Thank you all for following and helping with the knowledge and techniques of the hobby. Yes, the breeching lines of the cannons should have gone through eyes on the carriage. I do not have a hobby drill press and decided to forgo any cannon carriage detail with this first build as I did not have the ability to drill the metal carriages supplied by Amati. Next build will have wooden carriages that will accept a pin drill and can mount any number of eyes. Thanks for the picture Allan, I’ve set that aside for the next build as a reference. 😀
Edited by Dave_E
Dave
Dave, Just as an FYI, for the next go around, according to Caruana's The History of English Sea Ordnance, Volume 2, page 386,  32 pounders and above normally had a double block and single block for the running out and training tackle.   For calibers below the 32pounders the running out tackle  and training tackle normally had two singles, not a double and single.
Allan
Hi All,
Another serious noob question. Here I am at the rigging phase of construction. What do I do first?😊
Edited by Dave_E
Dave
Dave, it starts with research and looking at tons of build logs. You should have a rigging plan for the LN, correct?
Hey Keith,
If your referring to rigging on the plan sheets, yes I do. I just spent 2 hours studying the kit plans, the rigging book I mentioned above and one of our good members completed LN build. The Admiral came down to check on me because it was to quiet. 😆 I’ll start with the standing rigging I recon.
Dave
Hi Dave
When David Lees wrote The Masting and Rigging of English Ships of War 1625-1860 Alan Villiers noted in the Foreward on page vi that this is a most useful book for the sailing ship modelmaker and for all students of such ships and their rigging.  To that end, Lees includes the order of dressing the masts and yards on page 158.   This includes standing rigging attached to the parts of the masts and rigging attached to the yards such as braces, lifts, footropes, &c.
In addition, as can seen in most build logs here at MSW, it is pretty much a given that rigging the yards as much as possible before securing to the masts is preferable including the blocks to the trestle trees and yards followed by the foot ropes.
Lees does not give an order of dressing for the running rigging but working from inboard to outboard on the model seems to work for most modelers.  Perhaps your kit gives some guidance as well.
Allan
 Dave, Allan. I found it helpful rigging for the first time that I first understood the mechanical workings of the running rigging. The stays are pretty self explanatory. A rigging plan will get someone from point A to point B but when done that someone may not fully understand what they just did. One has to know how blocks and line work in relationship with one another. As I said, when a rigging plan is available you can get there but as one branches out to scratch building and a rigging plan may not be available, it's essential that one understands mechanical advantages and what's taking place when a line is run.
 Dave, that's why I suggested research being the first step. The better sense you have of rigging starting out, the better you'll be served later on.
 The better you understand rigging, the less there is to fear.
Good Morning Guys,
Thank you both for the input. I’m thinking another book might be in order. I love the references available on the build logs, however it’s a chore to bookmark a page I think will be of great help or to print many pages and have available for references and of course the old memory “where did I see that”. Absolutely concur, once you understand what a line or piece of rigging does and how it works, it helps us with the how, and maybe when to get it installed.
Dave
After setting the mast usually the shrouds first, then the bowsprit, then standing (black), finally running (tan). Work bottom up and middle out following the rigging plan for rope and block sizes and where things run. Other than the shrouds don’t permanently fix lines until you have them all run then go back and adjust as needed. Lines should be taunt not tight.
The LN model has very simple rigging, I used Peterson’s Rigging Period Fore and Aft Craft book and even my similar Cheerful’s plans to add more to mine.  Many of the frequently cited references don’t apply to cutters, this particular book does. It has lots of nice easy to follow diagrams. Just be logical about what you can get to now and or won’t be able to fit fingers or tools later. There’s no magic, just a line at a time.
Of course the many LN build logs are there as ready reference.
Edited by glbarlow
Regards,
Glenn
Congratulations, Dave! A build milestone.
May I suggest that you complete fitting the bowsprit, boom  and driver gaff before fitting any rigging. You'll find it much easier than trying to work round any existing rigging, particularly the boom and gaff. I have built this model although I don't have the build on this site.
Rick
Edited by Rick01
Hi All,
Progress continues… Standing rigging complete less catwalks, will start that tomorrow perhaps. Lots of lessons learned. Broke just about every cannon loose, broke the rudder off (I believe someone told me not to put it on yet), and broke off one of the catheads. 😕 The scale rope that came with the kit was hairier than Harry Henderson and while I was using the lighter to burn off the hairs, I torched one, it went to flame and well, you know the rest. 😆 I know there are boo-boos regarding seizing. From 2 feet away it looks amazing. 😀
B951905C-D810-40CE-B1DA-EFCBF1403DC1.thumb.jpeg.276cc3a61cbd42e643a522a6c031d68f.jpeg62F04B8A-7161-42ED-BAB9-053DFAAB75A1.thumb.jpeg.107bddafc3e4d686d0598190d298ec0f.jpegF214FB0A-A1CA-4A1F-9899-B8415348069D.thumb.jpeg.308538e36391bffe5a8bb36558fcca88.jpegC7671EC7-01AE-45B5-A8EC-1EEFFFCF1081.thumb.jpeg.d68fef6bb94d691fe2f707ca4e122270.jpeg
Edited by Dave_E
Dave
 Dave, the rigging looks great but how in the heck did you break the rudder? There's no rigging back there, did you have LN in a headlock? :)
 It seems most kit supplied cotton line stinks. On your next project you might consider getting line from Chuck or possibly laying up your own.
Hi Keith,
I was turning the base around to work on the other side of the ship, hand touched something, heard a crunch… 😕
As I was using the LN supplied rope and the lighter, I was very impressed with both Syren’s rope as well as Ropes of Scale that I have purchased. Then I opened up the Rattlesnake box to look at the rope supplied by MS. Really impressed, no fuzz at all. Don’t know whether it’s cotton or polyester.
Dave
