On 7/18/2022 at 8:15 PM, gsdpic said:
You clearly have too much time on your hands!  :)  I'll follow along as well.
I am confused though....I noticed the front of the box says "Solid Hull Construction for Easy Building!"
Hi John
Model Shipways also has a solid hull Bluenose model. Someone probably grabbed the wrong box lid when packing it. That's probably why the previous owner gave up the project. He thought he was getting a simpler kit.
I really like the detail of your Charles Morgan.
Nice work by-the-way.
John U.
Finishing the hull…
Cutting in the Hause Holes and Bowsprit…
Main Rail…
7ECBF6AC-DECD-4C56-9DAD-B9233F7517F2.thumb.jpeg.1c723f14ed77e8ca8f711306224c6ecd.jpegEA31B9E7-4A72-4CE1-A6D3-9B638E828A1A.thumb.jpeg.5178ca51c7f825f465efda2186d49cf7.jpeg0C5C4AD0-DD04-446D-99D9-11119B8AAC54.thumb.jpeg.bbd4b9a982afb67d2a81fa1f1f34599e.jpeg
Stern and Bow Railings are laser cut pieces. The remaining railing all has to be cut from wood strips.
I created a template of each section with tracing paper.
I then laid each template on to the strip wood with rubber cement.
Using a belt sander, trimmed away the edge of the strip wood up to the template.
A41D134F-10E2-4520-B97A-E9167FB23BF0.thumb.jpeg.f438a22663baab3b133e8fdea67c3e43.jpeg56745AE9-1E4B-4489-9C63-4C506197DFDE.thumb.jpeg.7bab5fb5c8455e9dc8c88c7bf5a89d5c.jpeg
Main Rail completed…
Back to the paint booth…
12800D95-AE59-4C23-8569-B032C3BAE0CD.thumb.jpeg.8094c315e70ca34e736a093d4ca7a9ba.jpeg6ECB3CA7-FCFC-40AB-9196-22A6020A42E0.thumb.jpeg.53652b683489f3a976af6845c8e66b99.jpeg
Hull finished and ready for details…
First coat of paint on the Main Rail.
Cheers 🍻
Edited by John Ruy
Hull details continued…
Airbrushed Hull Copper Red on bottom of the hull.
Applied white vinyl stripe to waterline and finalized with Clear Coat.
Hull completed and mounted on the kit supplied walnut wood stand. We can only go up from here.  😆
Cheers 🍻
Main Rail…
IMG_1770.thumb.jpeg.9d22abba899145d73648878489dabe87.jpegIMG_1771.thumb.jpeg.596d7b6f94190ea243138f7ee75c004d.jpeg
Monkey Rail…
IMG_1774.thumb.jpeg.7188bcc39d6d58a82cd665dccb5ced49.jpegIMG_1775.thumb.jpeg.ab617e9f2b30ca349edfbe37bce05f17.jpegIMG_1794.thumb.jpeg.e3c43519f5ef8253010039a0e6cfb3dd.jpegIMG_1796.thumb.jpeg.6d8cba4ee4404cafbb9d47cac9431b1b.jpegIMG_1798.thumb.jpeg.e1c8fea7f7c9c21f9620f623a33a8ab2.jpegIMG_1799.thumb.jpeg.36fba2e209f8dc55dbe3cc66a665904d.jpegIMG_1802.thumb.jpeg.63347a62e4767a906d8f8f90d82599b8.jpeg
Buffalo Rail…
Deadeyes…
Shoutout to @David Lester for your research and build logs.
Stern…
Bow…
Finishing up deadeyes…
Painting out to top Rails…
Placing eyelets and belaying pins
She is getting there… All this fiddley stuff is tedious. Time to take a break and scan over the drawings. I don’t want to miss any of the hardware on the inside of the bulwark, before I start on the deck furnishings.  I know I still have some eyelets, rings and things to do.
Cheers 🍻
Windlass…
Photos of the original Bluenose from Nova Scotia Archives. Very helpful resource.
IMG_1954.thumb.jpeg.87d48a94b6a99702ffa6194216f5fa4c.jpegIMG_1955.thumb.jpeg.8ef75792d39ef3fb0a4626e5b9cdf7c7.jpegIMG_1994.thumb.jpeg.612cbdd8c977c045fad28f7648526a71.jpeg
Many more details coming…
These archives photos are great. Notice the chain box just aft of the engine box. Not on the MS plan…
Cheers 🍻
Edited by John Ruy
Hi John,
Actually, that chain box is on the MS plan. It's on sheet 4, lower left hand corner of the page. These old photos of the Bluenose are great and I am quite impressed with how accurate the MS model seems to be.
Yours is looking great!
D
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
17 minutes ago, David Lester said:
Hi John,
D
Thanks David… yep, I found the chain box on the plans. Lots of detail on sheet 4. Requires lots of study. 🧐 I too am impressed with the plans from Model Shipways. John
Just got back from Nova Scotia, what a great trip. Beautiful coast line, much like Maine. Spent time at the Canadian Maritime Museum of the Atlantic in Halifax. Fascinating History. Also, went for a short cruise on the Bluenose II. Got lots of good photos and first hand knowledge of rigging, etc…
IMG_2152.thumb.jpeg.42c1806f5f4c424ad151e8cd6ddd9ce3.jpegIMG_2151.thumb.jpeg.9411bd833cda5796871618cca83d4d55.jpeg
There is nothing like close up reality, almost a step back in time.
Port Anchor mounted…
Cheers 🍻
Great pictures, John! What an experience...  Thanks for sharing!  Hope to incorporate some of what you saw in my Bluenose (when I get that far!)
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Always impressive to see how much detail you do. When I ever get to my Bluenose  I also  will be here often, well done. Thanks for posting.  !!!
                           :cheers:
Edited by Knocklouder
More info
        USCG
Foremast - Mast Coat, Pin Saddle, Gooseneck…
Kit provided laser cut rings have to large of an inside diameter. Solution: drill out a 1/2” dowel with a 5/16” bit and slice two mast coats.
IMG_2289.thumb.jpeg.8ca199e12d7ee6d0da8950455443195c.jpegIMG_2290.thumb.jpeg.a8af390f2fb69ec6e2305d5f8c0e135e.jpegIMG_2291.thumb.jpeg.0b82191b37d0b863e801b097edfa6ff5.jpeg
Utilized the laser cut rings for the pin saddle.
Carved chocks from a mahogany strip.
IMG_2347.thumb.jpeg.b980ea592f1c80986688f4b75b4f1da3.jpegIMG_2348.thumb.jpeg.0c9f9c54f233cd21e6d6a1e0d260f15e.jpeg
Here is a picture of the gooseneck on the Bluenose II.  NOTE: Oringinal Pin Saddle no longer there on the replica.
Created the gooseneck from provided brass stop and wire as follows.
IMG_2360.thumb.jpeg.09739150b382ae027868954c6241dac5.jpegIMG_2361.thumb.jpeg.ae2cdaade094d8774fc69b447fae17f4.jpegIMG_2364.thumb.jpeg.8f44fcca6e848e4c188567d820a8ca38.jpegIMG_2368.thumb.jpeg.7c5f58f56650e5da7006378529c08cd6.jpegIMG_2369.thumb.jpeg.7dddf9f4dde9525476bf479c9051baa3.jpeg
Edited by John Ruy
Eye Bands…
Using kit supplied brass strip and brass nails, jigged up eye band per instructions and soldered.
Note to self: buy a smaller tipped soldering iron.
Drill eyes before trimming tabs.
Eye Bands fitted. Easy? NOT!
Paint flat black to represent iron. 2 of 17 eye bands completed.
Should get easier with practice. New soldering kit order.
Cheers 🍻
Edited by John Ruy
Nice, John!  I am horrible at soldering.  Can you do 34 of 'em? <shrug> 😉
Gregg
