Welcome on the start of what will become a long build log of the Mary Rose. The idea is to build this model like on the cover of the book "Mary Rose, Your Noblest Shippe"
HISTORY (Wikipedia)
https://en.wikipedia.org/wiki/Mary_Rose
MUSEUM
https://maryrose.org/the-history-of-the-mary-rose/
BOOKS
INDEX
Frames (bulkheads)
Design
Building slip and align the frames
Fillerblocks
Planking
Keel and lower hull planking
Planking between wale 1 and 3
Treenails
Waist an bow
Rear castle
Build up
Fore castle
Build up
finishing and mounting on hull
Cannon deck
Basis
Cannons (base)
Upper deck
Base and planking
Wall, fore and rear castle
Base plate
Started sawing wood at the beginning of last year (cherry)
20210831_140245.thumb.jpg.71964cf09772f5475f3e51852af69494.jpg20210831_155210.thumb.jpg.6e62065ccef7d117d8cde22705e8c288.jpg
Books have been bought and partially read.
20220328_170235.thumb.jpg.5e1943194e5a514fab5526110cbf0d2b.jpg20220328_170125.thumb.jpg.4471ea7ffcdbac2f3353b1e841661bfb.jpg
The frames have been enlarged with a printer to a scale of approximately 1/48 - 1/50.
20221217_170059.thumb.jpg.873f557911c914040662bf014863e2ad.jpg20221217_170152.thumb.jpg.007db23a66dd4455150d9d520bc0f974.jpg
I first wanted to build on a scale of 1/45 (like my Pelican). After an initial investigation whether I have room for a fully finished model on that scale, it will be a scale of 1/50. 1/45 will be too big to fit in the closet.
The first step is drawing out the frames on paper (3D designing and printing is not my thing, drawing, sawing, filing, sanding and making dust is).
To be continued
Edited by Baker
Thanks for the encouragements.
To anyone who will follow this. Thank you in advance for your time and attention 👍
This build will take a very long time. Provide yourself with an easy seat, drinks, appetizers, etc 😉
Thanks Patrick for another 16th century ship. I'm looking forward!! :imNotWorthy: Ondras
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
Fingers crossed, Patrick. I hope you will finish it. It´s a beautiful ship.
Here´s  one building :
https://www.shipmodeling.ru/phpbb/viewtopic.php?f=45&t=71379
unfortunatelly, the builder died already. But there´s a lot of informations.
Jan
Finished:       Ark Royal 1588
                      Mary Rose 1545
                      Arabian Dhow
                      Revenge 1577 ( first attempt )
                      La Couronne 1636
                      Trinidad 1519
                      Revenge 1577 ( the second one )
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
On the table: Sovereign of the Seas 1636 - continuing after 12 years
All of them are paper models
First thank you for all the attention. Much appreciated.
The link to the "Russian" Mary rose model is bookmarked, thanks Jan.
After all the 12 frames are drawn,  plywood is first roughly sawn to size.
The drawings are glued to the plywood.
And, ready to sawn the frames.
But given the outside temperature is now between 0 and 5 degrees. After 1 frame my fingers were a bit frozen 🥶
So, for now, I will switch back to my military modeling in our heated kitchen.
All the frames are sawn.
The idea is to build the hull upside down. I've never done this before, something new to try.
The frames are clamped onto the buildslip. These are not yet fixed on the plate, This setup is to see if all my drawing and sawing work is correct.
20230129_145724.thumb.jpg.7c2f9e2dde42b7d64ebb6b5301c8dea2.jpg20230129_152506.thumb.jpg.0df69c9e4fd0beaa4f83b6583dfeaa0e.jpg
The result is not bad. Actually better than expected.
20230129_152822.thumb.jpg.171408b59dfa693c477e48a7e43095bb.jpg20230129_152913.thumb.jpg.3aae9db4e14729ed644142750e62f08c.jpg
These drawings are also enlarged. For now, it's still Chinese to me.
But again something new to learn.
Patrick - adding your new  log as well. in the mid-90s I visited the Mary Rose (well after seeing that other one - right next door) haha — Very interesting. This was before they of course totally rebuilt the Mary Rose museum, which apparently today is astonishing. Looking forward to your new build, which are always a delight to follow.
Cheers, my friend.
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
That will be a very big hull!!:rolleyes: I used the same build system, just prepared the top of the ribs for precise removal later so I didn't have to use too much violence.. Fingers crossed.👌
Ondras.
Thanks everyone for your interest :imNotWorthy:
A dummy plywood "keelplate" is made.
This showed that the mutual distance between the bulkheads was too great. So everything has been disassembled and the intermediate supports have been made 3mm narrower.
The new arrangement is now in proportion to the keel, stern, stem.
20230131_150828.thumb.jpg.571988bf7e2f4c707ef680df64bd08d8.jpg20230131_150856.thumb.jpg.c15ae4ebcac43b10653f296d7360e7e3.jpg20230131_150912.thumb.jpg.6aea74f4e1ee35d025e839525a1ed559.jpg
The shape of the front and rear bulkheads don't look right on sight (i think). I used the drawing from the book Anatomy of the ship (AOTS) and It looks if these are "taken" from MR Noblest Shippe (MRNS)
The AOTS scheme has 12 frames.
The MRNS has also detailed  "sections" and frames.
20230130_103610.thumb.jpg.4e9f00a6fa3576730f574ff1567dc4a0.jpg20230130_103851.thumb.jpg.735892d57bf667ccbffc7e6c8df8e7fb.jpg
That is why the drawing of the sections (MR noblest shippe) has been enlarged by 200%. I spent a few hours at work today at the engineering department...😇
The intention is to make masters with these to check if the shape of the bulkheads matches with the sections.
This will also help to determine the position of the decks more easily. The deck of the cannons is open (a real deck, no holes in the hull with dummy cannons)
@Ondras71 This is indeed going to be a large model.
@Veszett Roka
The keel will consist of 3 pieces from 2 different types of wood. The idea is to install it first.
Testing my suspicion.
After enlarging the section drawings from the MRNS book, these sections were all copied separately.
A first test clearly shows a difference with the drawings (bulkheads) from the AOTS book.
Grrr :default_wallbash:
20230212_104752.thumb.jpg.99d5b4afecd1e0d664d8a2c988de0870.jpg20230212_104756.thumb.jpg.5c6d6c97cca7123457a636f41c821026.jpg20230212_104802.thumb.jpg.d8ac5d87cbe7467a4d86bfe7b7ec9470.jpg
All these (some of of them expensive) books and in none of them you find the simple mention about the length - width of the hull.
So i continue with the keel length and the beam in feet.
Length keel 60,... cm and beam 23,... cm.
The sections from MRNS seem to match better the 23cm than the bulkheads from AOTS 24.5cm
Next plan.
Making these extra bulkheads and do a better shaping of the the already made bulkheads.
Better to do well now than to have problems later.
An admittedly brief review of my copy of MRNS indicates that the Mary Rose organization has not published a full blown “lines drawing” for the ship.  As the ship as recovered from the Solent was distorted wreckage they are probably reluctant to publish a drawing not fully supported by archeological evidence.  The frame and section drawings in the book used as is therefore, may not produce a fair hull.
ATOS appears to have taken things a step further with a lines drawing that produces a fair hull but does not exactly match all of the as recovered, but distorted wreckage.
As I see it, you have two choices:  Use the ATOS lines drawing as is.  This should produce a fair hull that replicates the shape of a Mid 16th Century large English Carrick based on corrected hull shapes recovered from the Mary Rose wreckage.  OR, You can use the MRNS data to draw your own lines drawing.  If you chose to do this you may well have to adjust some hull section shapes to produce fair lines.
Either case will produce a hull that reflects someone’s best guess; you or the author of ATOS.  Either approach will produce a handsome model that comes as close as we are going to get of this historic ship.
Roger
I fully agree.
But, the advantage of the MRNS book is that I have a lot of drawings on a scale of 1/100. And it is easy for me to enlarge them to a scale of 1/50.
So I'm going to make the sections of MRNS and place them next to the current bulkheads. And then see what makes the most sense.
I promesed this build would be a long way to a finished model. I'm doing this well, haha 😇
Edited by Baker
First a non Ship related item.
Recently my photos are reduced with this tool. The first time you use it is a bit of searching, but after a few times of practice this goes pretty smoothly
The length / width ratio can be found in the MR book by Haynes (thanks to Chapman 👍).
There is a waterline drawing in MRNS. It also shows the positions of the sections on the keel.
This drawing is enlarged and hopefully these water lines will fit
Bulkheads whose position corresponds to the sections in the MRNS book are adjusted.
The MRNS book sections (black) are in place. The intention is to use the water lines to bring the remaining bulkheads into a better shape
The difference in bulkhead 11 and section 10 is here good to see
20230226_092346_1280.jpg.664316cff901a5585bf9e6c451e22724.jpg20230226_092545_1280.jpg.3bf3910bdf2de19f32540d085a8b466d.jpg
Very early at this stage, designing flags
Thanks following and the advice
Part of the bulkheads are adjusted and ready. An opening is made in the middle.20230301_125443_1280.thumb.jpg.27484c338003ffcc6f4d7a044320a06e.jpg
Start aligning and attaching the bulkheads to the buildslip. The buildslip is first leveled flat
Aligning the bulkheads with the laser
Making sure that the screws remain accessible
The rear part is ready
The plywood keel has been sawn through (a mistake was made at the front). The final keel will be installed at a later stage.
Supervisor Felix has full confidence in this project 😼
The stem (problem)
So now I know why the water lines from MRNS were not correct.  The rason was  "a wrong" start with the stem.  So this problem will be solved first.
The stem on this drawing is enlarged.
The difference is clearly visible.
Oops...
20230303_104555_1280.jpg.6231bd59fa3d9018109a26369ecab1ca.jpg20230303_104602_1280.jpg.5a74901b25e2d21a9e817b1fe158d7dc.jpg
Adjusting the front bulkheads and repositioning. (Mister Bosch is a very handy little thing for this).
And my assistant is also there (on the right between 11 and 12)
All bulkheads are bolted to the buildslip. And the water lines from MRNS are pretty accurate now. :Whew:
20230305_091127_1280.jpg.610a89a55e4a3b5eadabeaed8e4191f5.jpg20230305_091252_1280.jpg.6215b00c0a9bfe51d30ca30aea08fe05.jpg
Thanks for following
Now that the bulkheads have approximately the right shape, it is time to add the extra supports between them
20230306_112006_1280.jpg.ff4b72802cefca57790a4ae2e9974a68.jpg20230312_182410_1280.jpg.b8b506a9babdd7c0730146e5a7b212b4.jpg
Then the bulkheads and the supports are chamfered
now my favourite part, fillerblocks
These will be installed in the hull part below the cannon deck
Number 1 in place
