Wooden ships “work.”  As the ship travels through waves, the uneven buoyancy causes the hull to flex.  With conventionally framed construction the frames made no contribution to to the longitudinal strength of the hull.  In the Nineteenth Century the use of diagonal iron strapping was an attempt to add longitudinal strength to large hills but of course this was three hundred years or so prior to Mary Rose.
As ships aged these longitudinal bending stresses affected planking fasteners allowing individual planks to slide relative to each other, working the caulking loose.  The repair would have been to caulk the seam and to nail the batten atop.  This problem existed to some degree into modern times until advanced adhesives allowed monocoque construction of wooden hulls.
Roger
Roger
Thanks Roger.
Indeed.
The Mary Rose builders (rebuilders) were also working on this problem
20240114_093724.thumb.jpg.9c7a7b87ca8f8d17474b1d663e38481f.jpg20240114_093801.thumb.jpg.0daf535f5473f80d42d8f1c78bad3562.jpg20240114_093813.thumb.jpg.1565c708fc6ce881e198eeedb5b3fe9c.jpg
The rear castle.
Not much is left of the original. So from here on, most becomes guesswork. The frames of sections 6,8,10 and the stern are used as a basis
The first test isn't too bad.
20240125_160409_1280.jpg.10c660d49993d3ed04a02511c4ee0ab9.jpg20240125_160542_1280.jpg.f33ff9e19cd2ed048baf4bf676e2dfe6.jpg
The stern in the drawing has an unnatural bend (personal opinion). That's why I'm going to deviate a bit towards the outside.
20240125_160334_1280.jpg.01c48693248cf6c9b9ebf99874ff7383.jpg20240126_163735_1280.thumb.jpg.83ab40de613f7e1dd0e414a6dc75d528.jpg
The first 4 frames have been placed. They are still too high and probably too thick. But these 4 must be long and sturdy enough as a basis for the rest
The intention now is to first provide more frames on this side of the model.
20240126_164014_1280.jpg.7c879d36160d30a3aef55a05a77b78f4.jpg20240126_163523_1280.jpg.39257fba9ba75f09384cd1adf655c333.jpg20240126_163608_1280.jpg.535c7f7dce040a51e337689e0b38915e.jpg
That looks really good Baker.  That hull looks pretty spot on despite having to use some 'guesswork'.
cheers
Pat
Looking good and I'll keep my fingers crossed the rest goes well.  As for the over long frames... better too long than end up too short.
Thanks for the positive comments and likes.
Further with the reconstruction of the rear castle.
Sawing "beams"
Preparation.
The first frames.
Take into account the cannon ports of the upper deck.
All frames have been placed. The drawings of the Mary Rose were followed for the approximately correct position.
The chaotic inside has also been cleaned up a bit.  (not exactly the same as the original, you won't see much of it later anyway).
The plywood pieces are the basis for the cabins.
Result
Next: port side
5 hours ago, Snug Harbor Johnny said:
One can always cut or trim off extra wood as needed, but its often troublesome to add back on.
Oh so true!
cheers
Pat
5 hours ago, BANYAN said:
Oh so true!
cheers
Pat
4 hours ago, druxey said:
You don't have a wood stretcher in your workshop? Pity. Neither do I.
A long time ago I sawed a plank too short.
I sawed off another piece of this plank, and it was too short again....🤪
Lesson learned 🫣
Haha
Thanks Ab, this is much appreciated.
The further build up of the rear castle
Frames 6, 8 and 10 are laid out using the laser
20240207_135709.thumb.jpg.2b088c5066b7feae400e027adf7b6335.jpg20240207_135749.thumb.jpg.a9ea8f56146577aa2028b04c523efce7.jpg
All frames are in place
Started with the cannon ports
20240213_102902_1280.jpg.c8d8ede529216466932afc35afdd3599.jpg20240214_122601_1280.jpg.dcb7520c182031515558603a1bfdc399.jpg
And planking of the stern
Some filler pieces are  first atteched
sawing...
On almost all drawings of the Antony roll a beam (wale) can be seen just below the opening for the tiller
20240214_132811_1280.jpg.7d7efcc59dfdab466083a4393839e09a.jpg20240214_135039_1280.thumb.jpg.ae9b09c69b11cca71889f432b12252e6.jpg
Follow the drawing as much as possible
20240216_143143_1280.thumb.jpg.e001941fec5a20f6ee885824df9d90ef.jpg20240217_155557_1280.thumb.jpg.de5ded2dc1364a606c31378072b7a727.jpg
Result
An oops moment. Where there should be a hole for a cannon are frames.
Time to bring out the isopropyl alcohol. Soak off the glue of the framing and do it right
Thanks for following
Further planking of the rear castle.
I started with the part that was planked according to the clinker build method. These planks were not sawn but made from tree trunks that were split. length of the planks no longer than 2.70 meters
The first of these planks was tapered.
Above the tapered plank it is marked how high the upper plank may be
Further planking
20240220_165338_1280.jpg.cce28ee5076239066cf64abfe3bf9fb4.jpg20240303_132709_1280.jpg.638471daf90fbe209e80f50d019149b8.jpg
And then there was a week's holiday in the sun, which was put to good use doing research .
Back home and continue planking. The intention is to have 6 layers of clinker build, in total I should end up with 9. Above that there will be shields.
20240303_132630_1280.jpg.8763f8927308c2a63e0b1798d6c8717d.jpg20240303_135038_1280.jpg.0c98d3cc7a6dfb14d1cd83864d77c30c.jpg
That's why I first have to place the 2 dales, which determine the correct location of the upper deck in the rear castle
English lesson :
Dale.. old English word. The intention of these two dales is to drain the pumped water from the hold outside.
And if you have to pee....Do it in the dale (so their 2nd name pisdale... 😳)
The two dales
Each is made of 3 pieces as a base
(bad photo, sorry)
A finished dale
Making the holes in the same place on both sides was a challenge.
While the glue from the dales is drying, work continues on the inside.
The support under each dale is fictional, and later virtually invisible. This gives the dale (as support for the deck) a slight curve
20240311_130152_1280.jpg.79a74ecc37dde77c4e32df5e4eabaa6c.jpg20240311_132834_1280.jpg.2d1a072ed0a8287eb20e0ba9f52da950.jpg
And looking 5 steps further in the future.
Checking the relationship between the sides of the castle, channel, mast and the schrouds of the main mast.
Oops, I'm going to get in trouble if i go further this way...
Noticed it just in time
20240311_132436_1280.thumb.jpg.5a72f91197e91fe97c004a97fd45e636.jpg20240311_132546_1280.thumb.jpg.64410647c34050861787a9dc56b95b84.jpg
First. The schrouds problem
Fortunately, cherry wood is very flexible and this can be easily solved. By stretching the frames towards each other.
This is something for later, if I do this now I won't have enough space to work in the rear castle.
Continued with determining the position of the decks.
And the "gun wale". On this beam were the swivel guns placed on the first version of the Mary Rose, on the current version only 3 would have remained.
Memory aid. Where is what ;)
Adjustment of the stern
The position of the 3 swivel guns
20240316_133827_1280.jpg.ebe7c8667c1e4c275c5fd330df00fa03.jpg20240316_150518_1280.jpg.03ae633607665c5418f2c229687b7803.jpg
further surgery of the stern
20240316_150532_1280.jpg.2b01734e9fbaafa91e7d3fa0bacd2913.jpg20240321_190249_1280.jpg.36e3d7faa3435d7c8dcc72da6bfbd9d3.jpg
Upper deck and castle deck determined. Upper castle still to do
current status
Thaks for following
Coming along nicely! I've noticed that a framed model tends to spread at the toptimbers until things are tied together by deck beams, etc. Glad you spotted this early enough to correct.
Edited by druxey
  The close up views inside the stern castle make one realize the size and depth of the ship from a crewman's viewpoint ... and I can imagine the horror of being trapped down inside when she sank that fateful day ... much like the Vasa.
Continued with the planking on the rear castle.
Frames 6, 8 and 10, which served as the basis for the rear castle, were too thick and were therefore made thinner.
I used the easy way, put the saw in and start sawing.
the stern is provided with the necessary holes for the tiller, etc.
20240402_183321_1280.thumb.jpg.eb2b7359143353ae594db8c8bb4d78a0.jpg20240402_183716_1280.thumb.jpg.cff127d17cc3ff6e78f53a735c0e30db.jpg
The frames were too wide at the top and would cause problems later with the schrouds.
The simple way, tighten with an iron wire.
1.8cm less wide at the top, and "schroud test" ok 👍
The rear castle is now temporaly on hold.
Sanding the clinker planking and the interior is for later (outside the house...)
Next,
The further finishing of the cannon deck. And start building the basis for the  waist and the fore castle.
There is also a cabin at the front. The crew of the (optional) cannon has a lot of space again...
The sloping side of the cabin will later serve as a basis for a staircase
I run out of wood supplies. So the men from the sawmill were put to work (me...)
There is material of 3,4,5,6,7,8 and 9mm thickness back in stock.
On 4/6/2024 at 8:18 AM, Louie da fly said:
gobsmacked
Thanks Steven.
Gobsmacked, a new word for me.
 Is this "Australian" English ?
Not really - it really comes from England - there's not an Australian equivalent that I can think of (not any that are suitable for a family forum, anyway). But I liked the sound of it, so I've adopted it as an "honorary" Australian term.
It means astounded, amazed and often also impressed, or even shocked. Flabbergasted.
Steven
PS: Your gob is your mouth, so it's as though you've been smacked in the mouth, that's how amazed you are.
  I thought that flummoxed or discombobulated were similar ... in the U.S. there is  "thrown for a loop",  "knocked over with a feather",  "mind boggling",  "hit me like a ton of bricks",  awestruck,  "stopped me in my tracks",  "made speechless",  thunderstruck,  dumbfounded, "set back on my heels",  "took the wind out of my sails",  "totally blew me away" ... or a favorite of mine - "turned my head like a one eyed dog in a meat factory".
