8 hours ago, Landlubber Mike said:
How did you end up attaching the PE name badges?
7 hours ago, CDW said:
I won't attach the scripts and badges until the very end of the project and then I will likely use an acrylic clear floor polish as glue, such as "Future" or whatever it's called today. An alternative....
May I suggest Gators Grip Thin? it is what it was designed to do.... Dries completely clear, ultra thin and they won't fall off...
Quote:
The next steps involve polishing and clear coat application.
I went over the entire painted model, wet sanding using sequentially, 3200, 4000, 6000, 8000, then 12000 micro mesh polishing cloths over the red metallic paint. Once it was dry, then sprayed on my clear lacquer, Mr Color Super Clear II. There are a few specks of dust in my clear, which I will polish out with compound in later steps.
DSCN3753.thumb.JPG.8d129b74af250515300274d3615b5df1.JPGDSCN3752.thumb.JPG.8be26870db69747f04dcb74403a171c5.JPGDSCN3755.thumb.JPG.907262e5c527f175bfd15e101bdc19ce.JPGDSCN3754.thumb.JPG.c6494aeae4a559168829a151b22ce7f2.JPGDSCN3756.thumb.JPG.e1641e0c34a7a7d5a80e01298c40ea98.JPG
Really nice looking finish.
Andrew
Completed (Kits):-
What a  lovely shade od Red  -   looking really nice.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
The finish is looking great.  One of these days I'll work up the nerve to go through all the steps to try to achieve such a shiny finish....just not on a build like my current one with a lot of decals....too much fear of sanding/polishing through the clear and ruining them.
Thanks Gary.
There are different schools of thought on whether or not to clear coat over decals. Some top competition modelers say they never clear coat over their decals. They achieve their finish first, then apply decals last with nothing on top.
My own personal experience with clear coat over decals has been a mixed bag. At times it came out great, other times disaster. The main thing that can be said in favor of no clear over decals is the fact that decals can be removed and replaced later on without spoiling the entire paint job whereas clear over the decals means stripping the entire model back down to bare plastic if the decals are under a clear coat.
Earlier in this thread, I mentioned the hood is slightly warped and does not cleanly match/lay down in the closed position. Now that I've laid down the color coats, I've realized another issue I did not notice before now. On close inspection in preparation for clear coats, on top of the hood appears ghosting of the structural reinforcement on the inside of the hood. It's difficult to pick up the detail in a photograph, but it can be clearly seen with the naked eye. In order to fix this, I need to strip all the paint off the hood and do some body work to hide the ghosting. Since the hood is slightly warped, I'm inclined to seek out another, replacement hood. Either way I go, it's going to delay my progress, but it seems to me I would be better off with a replacement (if I can find one). Either way, it will cause a delay.
Shame this isn’t a beat up aircraft, many modellers would kill to get an “oil can” effect like that on some panels!  The finish you have on the rest of the body is outstanding Craig, so appreciate why you looking at replacing the hood.
Andrew
Completed (Kits):-
29 minutes ago, yvesvidal said:
What a beauty !!!
There are a couple of classic muscle car dealerships in Tennessee I’ve been watching. They have some very nice cars come through there for sale, at prices more reasonable than I suspected they would be. I would much rather have one of those rather than a new Kia or something like that.
9 hours ago, CDW said:
The bare metal foil treatment on the driver's side windows will be repeated on the other three window frames, the trim areas surrounding the wheels, one strip down the center of the hood, and the rocker panels.
That is looking sharp, but what a pain it must be to place these strips around the openings.
Yves
Yves
It’s very tedious. Certainly not a favorite thing to do. If the body molding is sharp, it’s a lot easier. Soft molding can be a nightmare. The areas I have the most concern about are surrounding the wheel openings. I have a plan of attack but it’s one I’ve never tried before now. We’ll have to wait to see how well it works.
This  is  looking a  stunner   Craig   -  I can see  all the  work  you  are putting into  it.
OC.
Current builds
Completed works.
I needed a hard edge around the wheel opening to help me guide my blade as I cut the bare metal foil. For this I used a 1mm strip of masking tape around the wheel opening, then laid my bare metal foil against the tape before following the outline of the tape to cut the foil.
There's the rocker panel chrome on the passenger side of the body, three wheel opening trims, and last, the chrome strip down the center of the hood to complete the chrome trim pieces.
2 hours ago, king derelict said:
Lovely work with the metal foil. That looks very difficult to get a neat finish
alan
It's really not all that difficult if the right tools are used and you take your time doing it. A new, sharp #11 surgical scalpel is a must, along with some quality, pointed cotton swabs (Tamiya variety). I blacken the tip of my scalpel blade so I can clearly see it as it's carefully and lightly drawn against the edge of the chrome trim. It's certainly not one of my favorite parts of car modeling but nothing else takes its place.
