Nabopolassar King of Babylon and Daffadar, Skinners Horse by king derelict - Art Girona - 54 mm
A quiet Sunday morning and a bit more progress. I completed the turban, started the belts and cummerbund. I got brave and added the whites of the eye which I guess commits me to doing the pupils. Some touching up to do with the belts but I am happy with the face. I added a black wash to the beard and I like it.
I need to decide on the next step. The guide picture shows a lot of fine detail patterns on the sash and the turban. Thin stripes of red and brown on the yellow. I'm inclining to just going with some broad stripes seeing as this is my first figure and I want to end up with something I feel okay with rather than a shameful mess. I suspect the guy that painted the figure for the guide might have done a few other figures before attempting that one
I'm also looking for a bit of advice. I am wondering whether to try to use a wash to bring out the details and whether to spray a clear coat onto the figure before attempting the wash. Any thoughts or advice?
I bought this rather odd-looking device after browsing the DSPIAE range. Its a hand stabiliser to try to control motion when painting detail or using tweezers on small parts. I'm still adapting to working with it and it seems very helpful. I will definitely be using it when I get brave enough to try to paint the pupils.
Thanks you all for looking in and for the encouraging comments and suggestions
Alan
Looking good  Alan,   I do washes  over my  28mm   figures  but how well  I would  get  on  doing that  at this  scale  - I dont know,  you  could  try  a  very  slightly darker  shade  of Yellow  and  paint  the  shadows,  then  a  slightly  lighter shade of Yellow  and  dry brush  the  highlights  and  raised  areas,   I haven't actually  successfully  painted  any larger  scale  figures.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Only cause you haven't tried yet brother...
Doing them as small as you have been doing should make the larger ones easier I imagine... Anyway I would have a lot of confidence in your ability to paint any figure at this point...
Thank you  kindly brother.
OC.
Current builds
Completed works.
Hmm.. that hand stabiliser looks like an interesting tool.  How big is it and how is it used?  I've familiar with the old sign painters method using a long stick of wood but not sure how something that small would work.
I think it's the same concept Mark.
Jack
Current buildUS Constellation
FiguresGold Digger
I haven’t painted any 54mm for over a year but recently became interested in doing so between work on my current ship modeling project.  Like the kit ship my figure stash has too many figures representing different interests when I bought them.  My first step is to finish my collection of American Civil War figures starting with the last of several mounted Union Cavalry Men.  My objective is to improve my technique before moving onto more difficult subjects. I have outfitted myself with a wet palette, mechanical paint mixer, and fingernail striping brushes should arrive soon.
My first subject is the Cavalry horse.  I became interested in trying the technique of “pre-shading” via posts on building a Titanic model here on MSW.  The idea seems to shade selected primed areas with a dark color and then paint over with tin coats of a lighter color.  The horse has large enough areas to allow airbrushing.  Using it on figures might not work.
Roger
Edited by Roger Pellett
On 5/19/2024 at 3:50 PM, Javlin said:
You know Alan something I read the other day about the eyelid always covers half the eye........I have always done figures as Bug Eyes then something to keep in mind...you may already know this?Keep up the good work.:imNotWorthy:
Thanks Jav. That is a good tip. I have seen some great painted figures with pop eyes and it turns them into cartoon figures. I would rather leave the eyes if I can't get it right. I'm still working up the courage to attempt the pupils
Alan
OC.
Thank you OC, I think your suggestion is better than just using brown or black washes. I watched a couple of videos which recommended the same technique
Alan
Exactly; its a bigger canvas to showcase your skills
Alan
I think its the same sort of thing. I think it will only be useful for working over a small area but that's really what I want it for. It certainly firms up my uncertain brush when it comes to painting details.
This is the guide that was inside the box
Alan
Roger
I will be very interested to see how the shading works out on a horse. I have a Historex one in the pile which I bought to finally satisfy an early teenage want. As I remember back in the late sixties Historex recommended using oils.
Alan
Yesterday was another day that tries the patience of men. I was adding some highlights to the tunic of the Yellow Boy and the glue (Gorilla Glue) I used to secure the base to the pill container being used as a handle cracked away and the figure dropped. It landed hard, the base separated and the head fell off again. I decided to try 15 minute epoxy to resecure everything and had just placed the head back and thought it was settled when it fell off AGIN. Only this time it landed smack in the little tray of mixed epoxy and got a liberal coat. I gave it a liberal spray of alcohol which I had handy and wiped it off as best I could. Of course most of the paint came off too.
I switched to five minute epoxy and tried again and this time I think I got a good bond. Activity was suspended for the day to reconsider and repair the shower.
I initially thought of going back and air brushing the black and white undercoats but I suspect I wasn't able to get all the epoxy off and if so then over spraying it was going to obscure details.
I decided to use white primer hand brushed where needed and after it was dry, this morning, I started repainting. I may have lost some of the pre-shading on the turban but I think its good enough to carry on. I can try using different shades to deepen the folds. I see a couple of spots on the face which may need attention too then back to qorking on the details
I got ambitious and started adding the basic paint to Nabopolassar. In some ways it might be a simpler figure to work on. Its a great sculpt regardless.. The tan colour is an undercoat for the gold decorations that will follow - at least that's the idea.
RIMG0044.thumb.JPG.57a8da94c73ff0cad3abdb75161d4ab3.JPGRIMG0045.thumb.JPG.d64d36b67e1d140b5ed78f1bf04620c0.JPG
Thanks for looking in and for the likes and comments
Alan
Sounds like Mr Btfsplk paid you a visit.  Nice recovery ! Folds look good.
Edited by Jack12477
Jack
FiguresGold Digger
Youa re  certainly being tested  there  Alan  -  keep  going  mate   it will  work out  in the end.
OC.
Current builds
Completed works.
On 6/6/2024 at 10:41 AM, Landlubber Mike said:
Really nice job Alan!  I recently picked up that Dspiae stabilizer as well.  I haven't had a chance to use it yet, but even though I have pretty steady hands at the moment, there have been times where this would have come in handy.
Thank you Mike,
DSPIAE products seem to be well made generally. I've bought a few of their tools and like the quality. I'm still learning to use the hand rest but its definitely a help with the miniature figure painting. I think it might help me place small PE parts too.
Alan
It seems a long time since my last post. Life beyond the model work bench has kept me otherwise occupied. Some good and some not so wonderful
\Work out at the test stand got rather frenetic with some high risk testing which ended as these things do - somewhat prematurely. That finishes my contract to support so my time is back to being largely under my control again.
My cousin from North Wales visited for two weeks after Memorial Day. She chose her dates well. It sounded like she missed two weeks of rain in Wales and we had two weeks of sunshine. Admittedly a bit hot but the sea was clear enough for snorkelling and she went home with the requisite tan. I felt rather unwell driving home after dropping her off at the airport and found I had Covid again. The symptoms cleared up quite quickly this time but its taken ages to get over the tiredness and the lack of interest in doing anything remotely constructive.
Today I finally found some momentum and made a start on the flesh tones on Nabopolassar. I put the basic shades down and managed to work around the eyes. I need a few lighter shades to highlight and some darker parts. The lips need to be darkened and then hair and beard etc.
The nail art brushes are a great help for the small details and seem to hold their shape well
RIMG0055.thumb.JPG.e2e365f124b1121ac51816dcaa684831.JPGRIMG0056.thumb.JPG.1afc5d9e11d4d0c1a5ee8c0e56e841ab.JPGRIMG0057.thumb.JPG.408137ab0c4d4a8633d0d00d4cc64c93.JPG
Thanks for looking in and likes and comments. Its good to finally be back
Alan
Looking appropriately foreboding!  Nice work on face.  Sorry about Covid, I've had it twice since being vaccinated and boosted. 😠
Jack
FiguresGold Digger
Alan
catching
Looking  really  good  Alan,  I think  figure work  is  all  in the  layers  of paint  and  shadows  and highlights,    sorry to hear about  you  catching  the  pesky  thing  -  it made me  think back  to  about  Ten years ago  when I had a  really bad case  of flu  -  I had a  really high temp   severe   constant vomiting  loss  of appetite  hot and cold  like you would not believe    would  my works  let  me  off   -  no  chance  if I did  not  come  to work  they was gonna  sack me  -  we was  expected  to  just  get on with it  back then  -  how  things have  changed.
OC.
Current builds
Completed works.
Jack,  I  kind of joined  a  group  of  peeps  who  have  not had a  single vaccine   for many many years,  and  a  surprising  thing  was  that  very little  talked about  having  cv19  symptoms  -  all seemed  to  have  just been lucky  not to  have been  unwell  over  many  years  apart  from the  normal  things  we have  always  had.
OC.
Current builds
Completed works.
Thank you Jack. Art Girona sculpted an impressive face to work with.
Covid has departed and some enthusiasm is back
Alan
OC.
Thank you OC. This has been a huge learning experience but its a great figure to work on.
Yep I remember the incentives to work a calendar year without taking a sick day - and thus exposing your coworkers to whatever was going around
Alan
Suddenly I seem to have found the time and enthusiasm to get some solid progress on Mr Nabo. In fact I think I am going to call him done apart from a little work on teh base.
I dry brushed gold over the light orange base for the cloak fringes and some of the gold cloth parts of the tunic to differentiate between the solid metal plates and pieces  I think its fairly effective. The eyes are not quite perfectly aligned but I think for a first figure I am going to leave well alone.
I have just realised that I still have his sword to paint and attach but I don't plan anything further on the main body. This one is actually easier that the daffadar - the sculpting is so good and the colour delineation is easy to work with.
And of course I now see a couple of misplaced dabs of gold that need to be tidied up and then its back to the Indian trooper.
I have really enjoyed working on these miniatures so another shipment is on its way from Girona. This does nothing to diminish the stack of unbuilt kits but hey its my birthday very soon and I deserve a gift (well as well as the new car I bought yesterday hem hem)
Thanks for looking in and all teh helpful comments and likes
Alan
Outstanding!    Me thinks this is not your first rodeo !  He belongs in the MET !
Early Happy Birthday 🎂 🥳
Jack
FiguresGold Digger
You have done a fine  job on him Alan  -  really nice  details and mixtures of colours.
Have a  good  one  on your Birthday  mate.
OC.
Current builds
Completed works.
Thank you very much Jack for the very kind words. I used to paint the Airfix figures for wargames as a teenager and lusted after the 54mm Historex models but could never afford one back then. This is my very first attempt at 54mm white metal figures and I enjoyed it so much that I want to do more. I think 75% of the credit goes to Art Girona for producing such an excellent figure.
The directional black / white priming and glazing colours demonstrated by Night Shift was a great help too.
Alan
