Mitsubishi A6M5a Rei-sen by ccoyle - FINISHED - Halinski/Kartonowy Arsenal - 1/33 - CARD - Allied code name "Zeke"
A Tale of Two Zeros (and a Falco)
Welcome to my next not-a-ship build! I'll introduce the subject of this log by way of a story. I had long been considering building one of Pawel Mistewicz's WW2 subjects published by Kartonowa Kolekcja. I have built many of Pawel's WW1 and interwar subjects, but only one WW2 subject (Brewster F2A Buffalo). His A6M2 Zero (kit #2, published in 2007) is the oldest such subject in my stash, so I was leaning toward building that kit.
That is, until I learned last year that Model Hobby was publishing a brand-new kit of the Reggiane Re.2000 Falco. I leapt at the opportunity to purchase the new kit and be among the first builders to complete one.
But it was not to be. It took four months for the Re.2000 kit to arrive. 😑 By then I had already seen a finished example online, so the possibility of being the first to finish one had vanished. Oh, well!
So it was back to building the Zero. Back when I ordered the Reggiane, I decided to also acquire some 3D-printed after-market parts for the Zero build, namely a Sakae radial engine and a cockpit details set.
Included among the parts were fourteen individual exhaust pipes, which I did not know came with the engine when I ordered it. While looking through the KK kit instructions to see where the various parts would be used, something hit me: the A6M2 did not have individual, separated exhaust pipes. Instead, the A6M2 vented its exhaust downward through a pair of pipes on either side of the fuselage. The separated pipes were introduced on the A6M5 for the purpose of giving the aircraft a little extra forward thrust by venting the exhaust gases rearward (it only marginally improved performance). The individual pipes passed through cutouts in the cowling flaps. This distinctive feature is an easy way to distinguish the A6M5 from earlier variants.
                       A6M2 (no cutouts)        A6M5 (cutouts)
image.jpeg.ea95e54900e20a3d1c4746382434e2f8.jpeg  image.thumb.jpeg.2320a03ad25120510352ed847776b29a.jpeg
(Left: By Marc Grossman - Own work, CC BY-SA 3.0, https://commons.wikimedia.org/w/index.php?curid=15575787 ; Right: By unlisted - 1. Historic Wings [1], Public Domain, https://commons.wikimedia.org/w/index.php?curid=1631577)
Well, it seemed a shame to have such nice after-market parts and not use them, so I did the only sensible thing: I bit the bullet and ordered an A6M5a kit from Halinski (from their Cardboard Arsenal series), along with its after-market frames, canopy, wheels, and brass gun barrels.
So that's how I ended up at this particular build subject, and it's a bit of an ambitious one. The finished model will depict the mount of Lt. (j.g.) Sadaaki Akamatsu. I'm excited to see how this one comes together, and I hope you will enjoy following along. Look for first cuts soon!
3 minutes ago, yvesvidal said:
On the shelf, behind the "Zero", are these future projects in waiting? You have quite a supply there.
Ha ha! And that is an 'old' photo. 🫤  The shelf situation is much worse now. I long ago crossed the nebulous border between "builder" and "collector." I may even have made another purchase recently. 😬  But hey -- it was 20% off, so I had to!
I know it's been three days since I created this build log, but despite the apparent inactivity, I did in fact start building. And here's the progress so far:
Exciting, right? If you're not familiar with Halinski kits, I'll let you in on a not-so-secret secret in the card modeling world: Halinski kits are very highly detailed -- even to the point of being described as "over-engineered" by some modelers. This one, small, partially-built assembly has eighteen parts in it.
To give you a good idea of how detailed Halinski kits can be, here's a birds-eye view of all the cockpit parts:
That doesn't include all of the laser-cut frames that are part of the cockpit, nor does it include the wire and/or styrene rod bits that must be made using supplied templates. Some of these parts will be replaced by 3D-printed parts, but by no means all of them. It can make for some slow progress.
Cheers!
Slowly adding structure to the cockpit area. There's a lot of parts that need to be laminated onto various thicknesses of card, even if one uses the laser-cut frames set. The laminated parts often need to be trimmed slightly here and there to get them to fit properly, and with Halinski kits there is no margin for error -- get the frames wrong and fitting the skins afterward will be a booger.
And here we hit a little snag. This bulkhead location is off because there are tabs on the piece in front of it that fit into slots on the back of the bulkhead -- except if one accidentally installs the forward part upside-down, then fitting the tabs into their slots causes the bulkhead to be off by several millimeters. It's not a huge problem, since all I need to do is trim off the tabs and fit the bulkhead without them.
That's all for now!
Work on the cockpit continues slowly. Sometimes it is a "three steps forward, two steps back" kind of process. Here we have the instrument panel, which is 'glazed' with clear tape (the kit includes an unglazed option). There is a recessed instrument in the center of the panel that I had to do twice because the first time it didn't allow the panel to sit properly. There is also a series of electronic doohickies that sit below the panel, one of which you can see before its installation. The instrument is a tiny box that unfortunately does not fit into the space allowed for it, so I will need to do some surgery on that piece before proceeding.
I have hit a small snag while working on the 3D-printed rudder pedals. They are quite delicate, which means of course that a couple of bits have broken off and disappeared into the Carpet Monster, despite my best efforts to be careful in freeing the part from its forest of sprues.
In the meantime, look what arrived in the mail today!
You may dimly recall my disastrous attempt at building a Curtiss H75 (Hawk) in RAF colors a while back. The kit shown here is designed by the same gentleman who designed that kit. I have since found a great two-for-one build log by a Polish builder who built both models and did a fantastic job on both (as the Poles always seem to do); should I ever get around to building this kit I will definitely be looking in on that build log again. The P-47D-25 is a Halinski kit, so it is absurdly detailed, as is typical with their kits. The Kingfisher is by a designer I am not familiar with, but the kit looks very good. Something I learned about the OS2U -- when I first looked at the kit, I thought perhaps it was not actually in 1/33 scale because I expected the wings to be much larger on a two-seat aircraft. Turns out the Kingfisher's wingspan was slightly less than 36 feet, so it was indeed on the smallish side -- less than that of an F4F Wildcat.
Many "special words" may have been used in completing this next phase.
I had to scratch-build a new rudder pedal strap twice because the Carpet Monster ate the first one -- stupid Carpet Monster!! The tiny T-handles on the box on the right side of the cockpit were supposed to be made from styrene rod or wire (snort!!) -- I chose to cut them from paper.
Onward!
1 hour ago, Canute said:
And you have some more to add.
There's actually a lot more to add! I think it will look pretty cramped in the end. And then of course it will all end up hidden. 🙄
Working on the aft cockpit bulkhead. I got roped into binge-watching a new series on Apple+, so my modeling time has been curtailed. I have carefully removed the 3D-printed seat from its supports, which took about a  half-hour to do -- managed not to damage anything in the process this time. The seat fits the locator marks on the bulkhead perfectly.
I subscribe to multiple FB groups operated by card model publishers, and that is often how I find out about the latest sales. WAK recently ran a 20% off promotion, so I picked up the following goodies:
Pfalz's version of an Eindecker. This kit is the work of a designer I've not run into before, but the kit bears many striking similarities to the work of Kartonowa Kolekcja's Pawel Mistewicz. I wonder if he collaborated?
The first floatplane fighter in my collection. A beautiful kit by Lukasz Fuczek.
The ugliest front-line fighter fielded in large numbers by any of WW2's major combatants. The M.S. 406 is so ugly that I long resisted purchasing one, but I figured I should go ahead and complete the set since I already have an MB.152, a D.520, and a Hawk 75 in the stash. This kit is part of a series of intermediate-level kits designed by Lech Kolodziejski of CardPlane, who designed the PWS-10 kits I built a few years back. Features fabulous artwork by Marcin Dworzecki.
A Lavochkin La-11 in North Korean livery -- for the sheer novelty of having something in KPAAF colors. This is another of Lech's and Marcin's offerings.
And finally (drum roll) -- the first two jets in my collection. If I'm going to do a jet, it should at least be visually striking, and I think these two pass muster. The Hunter is by Lukasz, and the SBLim (Polish license-built MiG-15 reconnaissance variant) is from Lech & Marcin.
image.jpeg.acd771008f463e117de7dfe69f4831f8.jpeg  image.jpeg.99f6b82c3673b586f82160279db3068b.jpeg
So many models, so little time!
Okay, we reached a milestone today. But first, here's a picture for all of you who might still be firmly in the grasp of Old Man Winter. It was sunny and 72 here in Greenville this morning -- perfect weather for taking the dog out for a stroll through Falls Park. I have to enjoy this while I can, because in July it won't be perfect weather anymore. 😬
Back to airplanes! First, we finished off the aft bulkhead bits.
image.jpeg.ca2d6e416955f2598d9dcef0e6ae9cd5.jpeg image.jpeg.8d4598dddcd6d0789d24f7aad71ba528.jpeg
A few bits remained to be added to the cockpit floor, and then we were able to glue the aft bulkhead to the cockpit structure.
image.jpeg.4860090e097400deade48beb1050019c.jpeg image.jpeg.3889a09a64c15d71e2f8afbb1cf9d8cc.jpeg
image.jpeg.e2a1cf5e09f892d3ecc82d693cba6064.jpeg image.jpeg.0f5cfa007fb1098319e3d4170e2fef27.jpeg
Now we can move on to the cockpit walls, which means we only have this many cockpit parts left!
That's it for today!
My excitement about moving on to the cockpit walls was premature. I forgot there was equipment to be added to the space behind the cockpit. This stuff will really be hard to see once everything is closed up.
11 hours ago, druxey said:
That is a lot of detail! Does it deserve a cutaway?
I have seen such things done with Halinski kits, but I feel sufficiently challenged by just building the basic kit (plus the few 3D-printed details).
This is the port-side cockpit wall (part 11) and all of the #11 parts that go with it (11a through 11w) plus three styrene parts -- 27 parts in all. I think I made myself a little sick from staring at these through a magnifier for so long while working on them. Still have all of the #12 and #13 parts to go on this side.
Movin' right along. Here's the parts 12 and 13 I mentioned in my last post.
Parts 12 are a quadrant of some sort.
Parts 13 constitute another instrument panel. Optional parts are included for a glazed panel.
And here's a test fit of the completed cockpit side.
I will not glue this assembly on until I have the other side completed. I will need to make sure that there are no seam gaps between the two sides, otherwise fitting the outer skins will be problematic.
Cheers!
Good God!  And all this will be nearly impossible to see when model is complete!
I second the mention of maybe doing  cut-away model. I've seen many engines in the local airplane museum with openings cut in parts, with edges painted red to delineate them. It could be phenomenal, Chris!
Amazing workmanship.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
