Your metalwork is beautifully executed, Alex. Will the stove have a chain-driven spit as well?
Thank you Druxey! And yes, it will have chain-driven split.
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Great metalwork your stove looks like I could put some coal in and cook dinner right away.
David B
Hello, and many thanks for your warm words!
Greg, the doors are glued with industry CA glue from Würth, and hinges are faux. :D They are simple brass strips and rolled brass rods glued on.
Druxey, yesterday I have turned pulleys, here the driven one:
now I have to make a bracket, chain and chimney, and it is barbecue time (if you are not afraid of the smell of heated glue) :D :D :
Alex
Alex,
Very nice clean metal work. It will look great when it is complete.
BTW - I did a double take when I first saw your signature - my eldest son signs himself Alex M as well!
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
Just phenomenal work on the pulleys...
The "chain" ...
cooper wire 0,1 mm, knotted... several trials in the waste box... here the one that looks more or less OK
The size is OK, still need more trials to reach consistent link size...
Alex
Make your own miniature chain!  WOW!  That takes the cake.  Druxey's question is good ..... couldn't you buy it?
Hello guys, many thanks for warm words!
Remco, yesterday I have made images from making chain, not the best example, but I hope it explain the process:
Alex
Thank you Alex. It is the way you knotted the thread I was looking for and the picture shows it perfectly. Thank you again.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
It is blackened... was all other as easy, because the glue give a sort of patina around. after several cleaning and cleaning, blackening and re blackening it looks a little like wrong iron... here the result, I think, I can live with them...
and how it looks on model:
Alex
Hi Robin,
the base is the next task, it will be base with bricks
Thanks Dirk, but if you find it good, I will have it self. :P
Alex
It looks great Alex....no, FANTASTIC!  Would you please walk us through your blackening process. (how and what you clean with ,what you use to blacken, ratios of chemicals used, duration of exposure etc. etc.) Thanks.
Tom
Thank Druxey! Tom, thank you too. The proces takes some time but is not as spectacular as I may detailed explain it. Ordinary cleaning with spiritus and blackening with brass black. I have also used exacto knife, fine sand paper and steel wool on some places to remove glue.
Alex
