I have spent the last 3 days at the wooden boat festival in Hobart and was amazed to see just how common the reversing mechanism in this build is. There are heaps of examples here in beautiful old boats and thanks to Michael I know exactly how they work
hi Micheal i,ve just started today to read your log and i,m very impressed so far and i,ve only got to page 7 so far, i,ve down loaded your pdf and gone side way,s on your external link,s thank you for them i,m learning a lot i will be following your update,s i don't suppose there will a download for the full plan and just think your log will be a most invaluable building instruction,s and when i find the Watch button i will be pressing IT.
gary
Gary,
Upper right hand corner... next to the topic title..  labeled:  "Follow this topic".
Now looking at the engine and the tool,s your machining are there any end,s to your talent,s Micheal i wish i,d carried on doing metal work at school maybe i would be able to do a fraction of what you can do i,m inspired and envious
Thank you Mark found it and done it, it,s now after midnight time for bed i,m on log 14 i will start reading again tomorrow i can't wai't to see what happen,s next, goodnight all.
Steve I am glad that I have been of help regarding these mechanisms.
Gary, thank you for your kind words. I have been very fortunate in my working career inasmuch that I have always been able to work doing the things I enjoy doing the most. The interesting thing is that while I worked building models commercially I did not have much interest in building models for myself.
I have a tendency to work in spurts and am very focused during these times, I think it has a lot to do with solving ways to accomplish the next part. currently I am procrastinating about what part to tackle next. A little bit of "model-makers block"
Michael
Michael, as has been said to me, sawdust is great for shifting the block. I find making a simple wooden component really helps get the head clear so a fresh view is available
Michael
Haven't you got a cylinder head to make Michael?   ;)
I love watching you solve your problems and like others greatly admire your talents. But take your time, we'll still be watching.   :)
If I'd known I was going to live this long, I'd have taken better care of myself.
A little bit of "model-makers block".  Writers block, designers block, artists block, yes we all go through it from time to time.  There’s usually something in the back of our mind nagging us.  The car that needs to be fixed, the furniture that needs to be moved, the book we want to read, go do that nagging thing and come back refreshed.  We will still be here.
Bob
Current build:  SS_ Mariefred
I get this same thing but I find the best way to cope with it is to work on another project (or mini-project) for a few days after which I can usually find inspiration on my model again.
Lextin.
"I have no special talent. I am only passionately curious." - Albert Einstein.
Hi Micheal on one of your ext link,s popular mechanic,s what a find i,ve book marked it i will be back to that mag a lot thank you for the link and don't forget more ex link,s very informative and the engine,s looking really good, can't wait to get back to the boat. i will be requesting a friendship i hope you will say yes
I kinda went through a  'block' in the later part of this past summer.....I know what it's like.   it doesn't last forever,  my friend........you'll get some idea brewing.......and then ,  off you go! ;)  are you getting a lot of snow?..........we SURE are!!!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I am working on the spark plugs today, and it is not snowing.
michael
No snow today ... It's just freezing your n.ts off ... The snowdeck is probably thick enough not to have some more downpoor
I cannot imagine how you will make the spark plug ... Will it have any porcelain insultaion ?
Carl
I was able to get a little break from driving today and was able to stay home. I had a couple of hours in the shop and worked on the spark plugs a little more.
A few more bodies were turned up out of brass. the small diameter stub represents the plug body and will be filed to a hex section the larger diameter of the rest will represent the circular plate that is on top of the head covering the oval plate as in this picture
Next I cut a strip 1/8th by 1/8th off the side of a scrap of Corian that I used as a cutting board in the kitchen using the tablesaw.
Some time ago I made a special 4 jaw collet from a bolt in order to make square headed bolts out of 1/8th square stock
This came in handy for turning down the Corian to .078" diameter after drilling a .028" hole about 3/8" deep
I turned short sections 1/16 long down to the finish diameter and progressed toward the chuck, this helped to support the work. once the full length was turned I slipped the steel core rod into the Corian and then pressed the brass over the Corian, using the tailstock chuck to ensure a good alignment.
and a shot with the finger for scale
The electrode was tested with a piezoelectric crystal to see how the spark would work and it worked fine I will need to add a steel in for the ground so that the spark jumps from steel to steel and not steel to brass.
I will do some more experiments on the fabrication next week if I get time.
It was a good stress reliever today to focus on the model and take my mind of other things.
Michael
Michael, those are amazing ! Your machining skills are incredible ! :cheers:
P.S Hope your wife is doing better with her health.
Edited by Jack12477
Jack
Current buildUS Constellation
Thanks for all the likes, Thanks Jack, Judy sounded great on the phone this evening, I am looking forward to seeing her tomorrow.
Here is the short clip of the spark test I suppose I could have waited till dark then the spark would have been more visible, when it is set up with the electronic timing the spark will be triggered by the magnet in the flywheel.
Michael
Edited by michael mott
Terrific, Michael. Working spark plugs! Who else would have thought of it? Sorry to read of your wife's health issues. I hope things will continue to improve for her. I'm sure it's a stressful time for you. Best wishes.
Here, I was thinking the motor would be using glow plugs and model aircraft fuel... but, my jaw is dropping... working spark plugs.   I hope it runs on regular and not premium gas.  ;)  From the camming, (I went back and re-looked again) it looks like a 4-cycle then?
Michael,
Incredibale, I couldn't believe my eyes at the size of those sparkplugs. Don't know whether Judy will be glad when she sees that cut Corian board ...
Take care driving, and best wishes to Judy
Carl
Michael, amazing !
Glad to hear Judy is improving.
Edited by Jack12477
Jack
"I would never have believed someone could hand build a spark plug that small,"
Mark I have seen a smaller one on one of the model engine sites.
Druxey, thanks for the well wishes.
"From the camming, (I went back and re-looked again) it looks like a 4-cycle then?"
Mark yes it will be 4 cycle I still need to separate the cams from each other in order to set them properly on the cam shaft.
"Don't know whether Judy will be glad when she sees that cut Corian board ..."
When I have finished re trimming the edge no-one will be able to tell it being an odd sized piece of scrap to begin with :)
Jack, thanks for the support.
And thank you to all who posted the like option, it means a great deal to me to be able to connect and share our hobby.
Michael
We all need our hobbies to relieve the stress of caregiving.
Bob
fantastic job with the spark plugs Michael......how much clearance at TDC?   very sorry to hear of your admiral's health problem.......I wish her the best  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Bob, Row, Denis thanks for your great comments, and for all the likes recently.
I had to go back an measure it, it is set to be .047" I might need to change that, I don't know at this point. but the design will enable me to make a change if I need to.
spark plug.pdf
I will be making a small short sleeve at the bottom end of the plug that will thread in this will be then notched to creat a short stub to act as the ground for the plug so that the spark jumps from steel to steel.
Michael
