Hi Creackers,
this I have also asked myself many times, but it is also fact that from radiocalls received, the stearing rudderchain had broken in a full gale, making the vessel unmanouverable and probably immediately going square to the huge waves the hull rolling heavily, and fact is that the hatchcovers had been destroyed, this causing the uncontrolled take of water, until the ships superstructures could not withstand the stresses anymore. She may have sunk or suddely have broken through. We shall never really know what hapened in the last minutes
Nils
Current builds
-Lightship Elbe 1
Completed
Thank
Thank you so much for going to the trouble of making this log and sharing your incredible skills, this wonderful model, but most importantly bringing to life the history of the very real people and the ship itself!
For all of these reasons I can't wait to see the rest :)
Thank you Bindy for you nice words
It all was due to the nowdays possibilities via web for doing all this Research, for instance in gathering all available to myself historic US newspaper clippings, state archives, etc...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, I assume you made the rivet wheel (picture 2), can you tell us more about it? OOPS I found it!, Thanks
I also like the aluminum tape use for the riveted metal plates, Great start!
Hi Guy,
the toothwheel Comes from an old mantelclock-clockwork, obtained from a fleamarket, and so providing many individual brass toothwheels with different toothsizes.
thin wheels for single row riveting broader ones for Multi row riveting, etc...
From twinrow on upwards the toothbreadth would Need to be reduced by binging circular groves in like the Picture Shows. Provided you own a Hobby lathe and appropriate cutting chissels, no Problem..., if not, span the wheel on a Center fixed screw
span into your Drilling machine and tangentially (sturdy Hand!!) bring cutting side tooth-direction of your metalblade small handsaw into Operation, with running Drilling machine. Some Trials should be done with scrap- wheels before, to get the Feeling. The saw toothdirection must be in the "pushing mode" as if it were a chissel. Remove grit care fully and brush over with brass-brush, to slight break the sharp edges carefully.
Hope this is of help...
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 6
hold rim with removable hatchcovers
raw Forward mast
crows nest, the Access ladder from deck not fixed yet
take up Points for swivel loadbeams
after some paint touchups ...
plymsol marking at waterline
marking of Name and Registration port
These 3 pics..., quite pleased with the results so far
Build log part 7 to follow
Current builds
-Lightship Elbe 1
Completed
Build log part 7
ship is now tugged out alongside the Fitting out quay of the yard
etched brass stairs
check, fit to scale approved OK
brass rim fitted to lower deckhousing, all around the boatsdeck
self explaining
in opposite to the workdecks the forecastle deck is Wood planked
the soldering Task gets a Little tricky here (too much heat in one place loostens the already tight neighbour ones again)
checking with plan, space requirements for boats, Davits and boat Access platforms
cardboard template for complete boat deck base
stanchions for upper Bridge fixed and soldered
note the workdecks are painted tan, "earthbrown"
self explaining...
Build log part 8 to follow....
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Build log part 8
template topview for boatdeck
checking Position of midship stairs down to Forward working deck
deckhouse stairs to boatstations
aftstair from boatdeck to working poopdeck
view backwards at this building stage
wooden planking of boatsdeck, here also the bearing Support-sleeves for taking up the Davits already mounted
main wheelhouse, Navigation room and officers duty station
freshwater storage tank with vent on top
Build log part 9 to follow....
Current builds
-Lightship Elbe 1
Completed
An absolute brilliant model! So much attention to detail! Love the rivet tool you made out of old clock cogs. Maby I can give that a go myself! Looking forward to part 9 ! Good work.
Regards, Scott
Completed builds:
Awaiting construction:
Hi S. Coleman, Tom and Daniel,
thank you for your appreciative words, I`m preparing to post Log parts 9 + 10 tomorrow morning, stay tuned
Nils
Current builds
-Lightship Elbe 1
Completed
I love the metal work.  It really makes a ship.
Bob
Current build:  SS_ Mariefred
Incredible craftmanship. I am impressed with all the details. When you finish your ship model, will you donate it to a nautical museum ? Your model is of museum quality.
Montani semper liberi    Happy modeling
    Crackers   :):D
Crackers,
that idea is not completely out of this world, because I`m running out of space in my Hobby Office right now, I am 66 years old and I hope that they might find an honorable anchoring place in my childrens homes one day. Right now I have 2 steamships, two Tallships, and the uncompleted scratchbuilt 18th century Pegasus in Progress.
Besides that you might know or have experienced yourself, that the modelers fingers start itching when one gets mind-pregnant with the next "Project", at least the ideas Keep on sparkling...
It is since I had retired from my work that I again have time to go after this Hobby.
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Bob
Bob
you are right, I feel the same, and have therefore gathered quite some experience in soldering (solderable metals) with either small gastourch or with soldering iron
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 9
different size vents
machine room skylights
ongoing Fitting out
cross check with plan
starting to look like the Heinrich Kayser
copper Fittings from the crafters used for Basic funnel construction, have to do some cutting though
angle of funnels match mast angle
Building log part 10 to follow
Current builds
-Lightship Elbe 1
Completed
machine well Skylights done, railings on boatsdeck and started on funneldeck
forecastle railing fixed
this and next Picture railings fixed
railings, pillars for boatsdeck and upper Bridge stachions painted white
stairs to upper Bridge fitted and all stairs painted
upper Bridge rim completed
prefitting for davits
outer Bridge rim White (except for soldering area of stair)
attaching middle wires of stairs to boatsdeck and railing
Build log part 11 to follow.....
Current builds
-Lightship Elbe 1
Completed
Build log part 11
be invited for a walk on the boatsdeck
and on the poop working deck
flag tabernakel and grating on the upper bridge
lifejacket Containment on the Forward portside boatsdeck
Fitting of load beams
Fitting beams to mast bearings (sorry for pic Quality)
Tackling davit
checking Position of Davit-block to boat
upper Bridge Cage completed
build log part 12 to follow....
Current builds
-Lightship Elbe 1
Completed
Hi,
trust you are reflecting to the outlet (suction mode) vents...
well, the longer vertical tube is cut to fit soldering a small short cross-tube on top, an then for the parts of the intake side and for the discharge side I cut these off the Ends of small steel-brassplated mini Christmas Jingle bells
In case you mean the spheric bowl typ, this is shown earlier in part 4 of my build log
Hope this serves your question
Nils
Current builds
-Lightship Elbe 1
Completed
Bob
you shall make me very happy if you go on pleasing your mind (thought), and very welcome to the stoker gang, who really knows in our days of gas turbine and atomic operated ship powerplants, what a stephenson reverse device is
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
What a super build, just awesome plate and rivet detail.
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Thank you Ray,
Thank you John
regards
Nils
Current builds
-Lightship Elbe 1
Completed
lovely work - and a great subject
All the best
Kevin
KEEP IT REAL!
On the build table
Bounty - Artesania Latina - 1:48 by Kevin - started August 2025 - - Kit build logs for subjects built from 1751 - 1800 - Model Ship World™
My other builds:
Thank you Kevin
Nils
Current builds
-Lightship Elbe 1
Completed
The Deutsches Schiffahrtsmuseum in Bremerhaven, Germany, would be grateful to have your model in their collection, since the HEINRICH KAYSER was her home port at Bremerhaven.
Your model is such a wonderful example of the modeler's art, everybody should have the privilege to see your creative work. I hope you will consider my suggestion.
   Crackers    :):D
Crackers,
many thanks for your appreciative and encouraging words, I`ll have your Suggestion in mind for the day when (if) I Need to give it in other than family Hands. Question: do you as a Senior model builder have any personal relation to Bremerhaven? You are correct, the Shipping Company Kayser & Son was based at Bremerhaven before the ship had been transfered to their Hamburg subsiduary, but that is only known to very few People..... The fate of that shipping Company owner Family really shocked me and was very much touching, sad to say.
Nils
Current builds
-Lightship Elbe 1
Completed
