Thanks very much Kees,
a very smart way of producing the hull.
I was just thinking and imagining of Popeye`s Holiday Harbor fleet following your idea and producing a whole Harbor full of fishing Trawlers.
Please continue to share youre great modeling ideas I like so much. I asume you have some more surprizes "up the sleeve". A great enrichment for this Forum,
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Kees,
Didn't see that one coming. I thought you were up to a good oldfashioned solid hull...
Jan
I am full of surprises B)  A solid hull gave some problems because the ship has a bulwark. So I had to hollow it out or I would have to saw a big peace out and replace it with aluminium bulwarks. The vacuumforming gave me some work but I can go on now much easier and I can make more hulls in the future if someone else wants a ship like this.
Regards, Kees
Edited by kees de mol
I used to work in a cabinet shop in Florida........they did vacuuform for vanity doors and drawer fronts.   the machine they used is huge and used a vacuum system to create the forms.  the forms were placed in the machine......they had little holes all around to remove the displaced air..........unfortunately,  the rest of the process was hidden by the machine itself.   but,  as you did,  the heated plastic was lowered onto the form and the vacuum sucked out the air trapped in between.  I would help in the dept sometimes,  if they needed it.  I used to do the router work on the filler boards {doors and fronts},  to put in the formed plastic.   later the edges were trimmed and the backs were painted white to match the formed fronts.
a pretty cool process!
well!   that's what I get for not turning on the sound!   I didn't even notice that there was a vacuum hooked up to the form box......watching it the second time made even more sense  :)    yepper!  if I had something like that,  I wouldn't have had to do all that planking.  :D  :D
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 5 weeks later...
Due to some healthproblems I haven't let hear something last weeks.(sorry Iam not a very healthy person) In the meantime there is some progression in my shipyard so here are some pictures.
The hull is cut out of the surrounding plastic
The beginning of what will be under the front of the ship. You will see it hardly when the ship is finished but I rather make to much then to little and regret it afterwards.
And I made a beginning with the halfround. I tried to immitate the strakes (?) by taping them on the hull and then I sprayed filler over it and removed the tape. Whats left are some subtile strakes. Just ennough for the effect.
Hi kees
Looking good already! I shall be following along with great interest. Always wondered how vac forming was done properly......always worth a YES!!!!!!! When everything goes to plan!
P.s I still haven't done that explanation of how I made the case for the sloop but I haven't forgotten!
Hope your health stays good
Festive greetings
Cheers.....mick
Nice to see you back in the dockyard. Progress looks very promissing
Carl
hope you are doing better Kees,  and hope that you had a great holiday!  looking forward in seeing more ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hello everyone,
I managed to do some work on the KW49 Antje and I came some further with her. What was in the begining just a piece of raw plastic is now becoming more and more a ship. I really like working on here. I need to figure out a lot of things every time I have to build something, but its fun.
All the half round is added, the hole for the anchor is made. I adde al the visible ribs to the deck and I made the front deck and under it some hatches and a winch.
Now I started working on the upper structure and the bridge.
Regards, Kees
good to see some progress Kees.........nicely done Hawse hole.   deck structures are 1/2 the fun....can't wait to see how you'll detail her out!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
The last few days I worked on the upperstructure of the ship and the bridge. I used only polystyrene and glue. I am using lesser CA-glue these day but use super thin ps-glue. It glues fast and strong but you have the possibility to position the pieces you want to glue.
Pictures say more than words.
that looks pretty sweet Kees!   could you have used a heat source to make the bends around the corners?  I like what you did,  but I'm thinking it might have saved you the sanding and putty work,  your going to be faced with.   Like the shape of the structure very much..... ^_^ very well done ^_^ :im Not Worthy:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hello Popeye,
It is possible to use a heatsource to bent the plastig but then you need to make a mould. Otherwise the corners would not have the same radius at all places. And in real life it will never bent like you want it to bent so you need to sand and putty any way. I made a lot off wheelhouses with round corners and I found this way the best way to do it. Today I sanded the corners and they are nice and smooth now. Pictures will follow.
Regards, Kees
sounds like you've tried a few different ways....to be honest,  I've been out of the loop {working with plastic}, for quite some time.  I still kick myself for taking the hiatus from modeling in my mid life.    it's cool to see other concepts of shape.  looking at your photos again...I see the rail structure continues aftward,  making the judging of radius harder.    darn nice work! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks for the responce and for everyone who hit the like-button.
I managed to do some more work on the Antje. I build an exhaustpipe a roof for the wheelhouse and I added the first detaills on the ship.
I am amazed watching you work with plastic.  Well done.
Bob
Current build:  SS_ Mariefred
awesome!!!   the funnel looks great!    love the brass bit too..........truly nice work!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Some progress on the little trawler from Holland.
I made some antenna's, a compass, a searchlight and some other bits and pieces.
It's hard to build an acurate model. Drawings don't show enough detaills and the photo's are made from to far sitance or are bad quality. I have to use lot's of photo's (also from other ships), drawing, the internet and the help from an old sailorman to make the parts but its very rewarding to do.
Now I will start working with a very strange material. Its has a brown collour, has a smell, splinters when you break it, and is not very easy to bend. I think it's a high tech new material from Nasa's laborotery's. Do you know the name? Very strange.... It makes me sneeze when I sand it :blink:
Fantastic detail Kees, looks real!  Hey, I like the Gulden too!  I have a few left over myself  ;)
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Beautiful work on those tiny parts.
Kees,
Marvelous detail, I especially like lights.
(For the non-Dutch amongst us: Size of a guilder is approx. 1")
Carl
very nice detail there Kees.........really cool searchlight,  and those tiny lights are very realistic. :)   the curved parts of the structure came out very well.  I know what you mean about pictures........some of the ones I try to follow are less than helpful sometimes ;)   none the less though,  you've done well in filling in the blanks  :)     really super job!!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I work with that strange brown material all the time.  They call it wood.  I have to learn how to work with the old white low tech material like you do.  What you do with it is very good.
Bob
Edited by Cap'n'Bob
