Posts posted by thibaultron
I'll be following! I've built at least two of theses as A kid and teenager. Both got lost in various moves.
- Canute, Old Collingwood, mtaylor and 1 other
- 4
To use the laser, it is critical to buy or build a case for it!! The laser can reflect and injure you or more specifically your eyes!!! There are laser safe tinted sheets that can be used as windows, so you can view the process. These lasers while "Low Power" compared to industrial ones, can still cause burns and eye damage.
When designing or buying a case, allow for the table or work piece that will extend past the frame at each end when at full travel.
- mtaylor, scrubbyj427 and tmj
- 3
In a thread I can't location now, there was a request for the correct size cannons for a cross section model. The consensus was that the ones supplied in the kit for the George the 3rd Blomefield 32 Pounder cannons were the wrong length.
I have been working on CADing the entire series of this type and bumped the 32 Pounder to the top of the list. Here is an STL file for the full sized cannon. You will have to rescale it for your needs. I have also included two graphics showing the final 3D design.
Blomefield Pattern 32 Pounder Full Size_3183_47mm.stl
Here is a SketchUp drawing of the flash pan for the long 24 pounder. Feel free to use it for your 6 pounder. Scaling will be needed, but the general layout is the same. I've included a graphic of the drawing, and a picture of an actual cannon.
- mtaylor, Gabek and EricWilliamMarshall
- 3
Update long 24 pounder STL. This is scaled to full size 3262.31mm. You can scale that to whatever scale you need. I messed up with the first file, by not scaling it properly. My cat escaped and while chasing her, I forgot where I was in a program, and messed it up. This file has been scaled and error checked using Netfabb.
I'm working on a full set of the Fredricks, as well as several other types, in conjunction with Allanyed. I have the long 24 pounder finished for his carriage project. If anyone needs the short one right away, I could generate that one. Otherwise I will finish the Fredrick set after the Blomefields.
This is a graphic of the file
Here is the STL
Armstrong Fredricks 24 Pounder Long 3253_13mm.stl
I wrote a thread about setting up for printing cannons in 3D, to help those who wish to try it for themselves.
On 9/11/2023 at 4:22 PM, Egilman said:
Well to actually get down to the brass tacks of model railroad scale, it is ALWAYS based upon the gauge of the rails, which is the distance between the rails.... "O" gauge being 1/48 the distance of real live american gauge rolling stock... This is known as "Standard Gauge" in real railroad parlance, all others are based upon this standard.... European gauge is also "Standard Gauge" as that is where it was mandated by law in 1846...
Standard gauge, 4' 8.5", (56.5 inches, 1,435mm) is the most prevalent gauge around the world..... so, true "O" scale would have a gauge of 29.9mm or 1.177 inches... And since everyone serious about model rail knows that "O" gauge is 32mm where does it get it's relation to 1/48th scale?
The point of what I'm saying, is there are 4, (maybe more) different standards for "O" gauge model railroading, which isn't 1/48th scale... (more accurately 1/43rd scale) in the '50's the american model railroad manufacturer's started building for scale accuracy and chose 1/48 scale as their standard for rolling stock (including Lionel) but stayed with the original gauge for their track, and over the years "O" gauge has given way to the term "O" scale in model railroading...
Scale and gauge are not interchangeable terms... any serious discussion of Model railroading scales needs to take this into account....
And then the Bar Fight started!
Great build! I'm following along!
I drew up a comparison of the barrel to the carriage, and the drawing is correct.
First the drawing with a rough line parallel to the barrel, and center lines on the top view of the carriage.
Then I transposed the barrel lines onto the top view.
So while the carriage looks overly angular, it is an optical illusion. the angle is correct.
- wefalck, AnobiumPunctatum, Canute and 3 others
- 6
Not a wasted effort at all! Good job!
- VitusBering, dvm27, Gabek and 1 other
- 4
6 hours ago, druxey said:
Blomefeld pattern guns are more trouble to cast, which is why I suspect you don't see them commercially. Now, 3D printing is another story!
The drawings for Blomefields should be done by mid Sept.. I'm not sure I will finish them before a planed trip.
- allanyed, mtaylor and Keith Black
- 3
I've been drawing up the Armstrongs and Fredericks. Drawings and photos show them without the rings. The Blomefields I'm working on now do have the rings.
- Keith Black, Retired guy and mtaylor
- 3
The printing of the design on a red painted sail will not work at home. No home printer can print white. I relies on the paper, or decal film being white. There used to be a printer that could do this, it used print ribbons with white being one of the ribbon colors. It has been a couple of decades, though, since they made the ribbons, so that option has gone away.
My guess is that the crossbeam is rabbeted in the area of the strap, to allow it the curve around the axle, and rectangular the rest of its length.
- Keith Black and mtaylor
- 2
If you don't already have it, pick up a copy of "How to run a Lathe" by Southbend Lathe company. Grizzly and Amazon carry it. It was written in the 30s, but is a great reference for manual lathe operation.
- FriedClams, Egilman, mtaylor and 2 others
- 5
Due to family obligations, I have not gotten any further in my modeling. Physical projects at least, I have been doing a few CADing projects.
RGS Rotary Snowplow by yvesvidal - DURANGO PRESS - On3 - 1/48
in Non-ship/categorised builds
The price depends on what you are looking for. A large layout can drain funds rapidly, or you could build a smaller shelf switching layout. The big expenses are building kits, cars and locomotives. Track and turnouts too, but a small one helps limiting this cost. Limit yourself to a small layout, and one or two locos, and it becomes more reasonable.
For those building US prototypes there is a company that offers reasonably priced downloads for US style cardboard kits, that you print out yourself. Almost all of them are models of real buildings. They are highly detailed and can be built with just one photo quality layer, or from several layers for built up doors, windows, etc. , as well as layers for roofs or walls with torn shingles or other weather related damage. One of our well known Scenery and building modelers was surprised that some models he saw at a convention were cardboard models from this company. I have no affiliation with them as other than a customer.
http://clevermodels.squarespace.com/
Several years ago I designed two Yard office buildings for a friend's Baltimore and Ohio (huge) layout from the only two existing photos of it, and another smaller one from one photo. I then made cardboard models of them as mockups for the layout, while he had a professional modeler make wood models of them. He still uses the mock ups as back ground buildings. We asked the B&O community for comments on the designs, and they told him that he was one of the world experts on the railroad, so if he was happy, they could not add anything to the designs.
Here is a simple version, recolored to Santa Fe colors, that will go somewhere on my layout. I drew the multi-layer version, but can't find it right now. The two photos of this one were a distant one of the side with the single regular and tall thin window, that basically gave me the side dimension, and one with just the thin window and a very oblique front view of the dual window front. The rest I got using B&O system building standards That listed the standard single double hung window size, and standard wood siding width., and assuming a desk at the front I placed the door on the unseen side in place of the window. Not a complex design, but it took a couple months of research of other existing B&O buildings to come to the final criteria to base the building on.
