Everything posted by Landlubber Mike
Thanks very much guys, really appreciate the kind words. I'm glad I ripped out the first planking strake and a half a few months ago - it was a tough decision given how much time I had put into it, but the planks were the wrong size and me trying to taper them was the wrong approach. Don, I think the purpose was to drive me nuts Lots of time was spent trying to ensure that the planking runs would end up precisely where the various colored areas would intersect so that the rails, which are only on the order of 1-2mm. Not much wiggle room! Plus, some of those planks took me a good hour plus to craft, especially the tricky ones around the gunports. Lots of measuring, cutting and sanding by hand in order to get the planks to fit tightly. That being said, I'm really happy with how the deck and hull planking has gone. I still can improve, but I feel like I've gotten a lot better with the planking from my Badger days. Using better wood and having the Byrnes saw to cut custom planks with clean lines has really helped. Some tips I learned along the way that I can share: 1. Soak and pin. I soak and pin the planks around the bow. Let them dry overnight so you don't end up with shrinkage issues down the road. Once they are dry, they keep a pretty good shape that makes it infinitely easier to glue them to the hull. On my Badger I tried doing everything in one go, and things got messy, especially when I tried using CA for quick adhesion. Soaking and pinning is a much better approach. 2. Bevel. I sand in a slight bevel onto the planks which helps give a tighter fit. Even when using 1mm planks, beveling helps. 3. Pin planks along length. I found it's important to pin the planks along their length to ensure that the plank fits tightly against the hull/first planking. I've really liked using these grip pins from Midwest, which have a very narrow pin so they can pierce the first planking very easily, yet have a soft plastic head which doesn't mar the planks (can probably find it cheaper from other sources): https://www.amazon.com/Midwest-Products-Hobby-Craft-50-Pack/dp/B000O8IPXW 4. Use good quality, sharp blades. Working with dull blades is a no-no. Too much risk for slippage and injury (trust me on this one - the red areas on my Badger are probably not exclusively from paint ). I used to use X-acto craft blades but recently tried out Swann Morton blades - the latter are much much better. They hold an edge better, and are much stronger so you don't get the degree of lateral movement you get with X-acto blades. Ian posted a picture of a S-M handle that actually grips the blade to provide even greater stability on my post at the link below, but I haven't been able to find it here in the US. Anyway, I would highly recommend the S-M blades. http://modelshipworld.com/index.php/topic/7267-hms-pegasus-by-landlubber-mike-amativictory-models-scale-164/?p=267612 5. Don't settle. If you aren't completely happy with the plank for any reason, re-do it. Especially if you start getting clinking effects, which will just continue to cause difficulties down the road. It can be a tough decision to make, but in the end, it's usually worth it. I tend to complain about how slow a builder I am, but I'm really enjoying the journey. Waking up this morning and peeking at my build, all that time and work was well worth it. This is a really great hobby It's especially satisfying sharing my and other builds with other Swan-class and other ship builders from all over world. I've learned a ton from many people here on MSW who have been gracious sharing their wisdom and experience. I don't think I would be anywhere near my current level (which is still pretty low on the scale here at MSW) without the internet and MSW. In particular, reading Swan class logs from BE, Alistair, Martin, Nils, RWS, Aldo, and others (as well as logs of other models) pushes me to build the best Pegasus I can.
Upper hull is finally completed! Big milestone passed in completing the upper hull planking. Took me a while as I was planking according to TFFM, which had a bunch of oddly shaped planks, and even a scarph joint thrown in for good measure. Because I was using a mixture of woods and dyes, I was also trying to ensure that the planking ended up in such a way that the intersections of the areas would be overlapped by the various rails for a clean look, especially if the stains bled from one area to another or there were other blemishes. For the frieze areas, I used boxwood as I thought it looked best when stained using General Finishes Blue Dye Stain. I loved working with pear, but wow, boxwood is a really nice wood to work with. Here are some pictures after finishing the boxwood planking and installing the fixed blocks: The boxwood looked so nice in its natural state that it was a tough call to proceed with staining the area blue. But, I went ahead with my original plan and added the blue stain, and then added a row of redheart planks to the very top of the upper hull near the forecastle and quarterdeck: For the forecastle area, I had soaked the redheart for a while as one long piece that went around the full forecastle. It surprisingly bent very nicely and didn't give any problems. I thought about keeping that area as one piece, but since I had two planks on the quarterdeck I went with two on the forecastle. I still need to do some touchups, including sanding and otherwise finishing the redheart, as well as ultimately sanding back the planking to the gunport patterns (left a little extra on purpose just in case...), but I couldn't be happier with how this came out. The colors in my opinion complement each other nicely (they should deepen a bit after I apply a finish to it), and I really like that they show the grain and planking lines. There are a few areas between the blue and dark brown that aren't perfect, but like I said, these will be covered with the rails. And while I was very careful to follow the TFFM planking pattern, on both sides of the model, I had a weird extra gap just forward the third gunport. Since that gap will itself by covered by the rails, I didn't worry about it. So, I'm super happy where things are right now, and am pretty burned out by all the custom planking. I might remove the bulkhead extensions at the waist and finish my deck planking, but I don't know that I have the desire to start on the bulwark planking. TFFM has a sample planking pattern that probably won't be too hard to execute, but the thought of fitting more planks right now is not all that appealing. I might switch back to my Morgan build and think about something other than fitting crazy shaped planks for the next few weeks. Looks like I'm approaching the 2-year anniversary of the start of this build. At the rate I'm going, especially since I'm looking to add full sails to the model, I probably have at least a good 3 years left on the build, but likely longer.
For PVA which I usually dilute, I use the clear caps that come with the big laundry detergent containers. The PVA of course doesn't stick to it, and it makes for a small, reusable container. With three kids we're always doing laundry in my house, so I have an endless supply of these
- 396 replies
- Idea
- Bright Idea
Drops are looking really nice Mark. Thanks for the tip on the scroll sanders - what a great idea! Best wishes to your wife as well
Good luck Ulises - your Royal Louis is gorgeous, and I'm sure this will end up being only a minor, temporary setback. What about making them in wood?
- 786 replies
- Royal Louis
- Finished
David makes a good point. I think it would be hard to spile woods that tend to splinter. Walnut and tanganyika come to mind - the strips in my Caldercraft Badger were hard enough to taper without splitting.
- 701 replies
- phantom
- model shipways
Beautiful job David, really impressive work.
- 117 replies
- constitution
- model shipways
Sorry to join the conversation late. This is a really great topic of conversation Chuck, thanks for raising it and giving the customer some input on possible future product launches. I think for first time kit buyers, the market is pretty well saturated with good beginner kits where the beginner probably cares less about historical accuracy and bashing, but is just looking to get their feet wet and build something out of the box. What is probably most important is for there to be good instructions. When I was getting started in the hobby, I was looking for a beginner kit with very detailed instructions. There weren't too many of those out there at the time surprisingly, but I think that's been changing. I ended up going with the Caldercraft Badger because it had a 65-page instruction manual that was close to what you've done with the practicums. When it came time for my second kit, I was looking for a step up in difficulty, something interesting and historically accurate, and with good quality components. At the same time I wanted to bash the kits to improve on them, so I purchased "used" kits since I knew I would be replacing most of the wood anyway. With a kit under my belt, limited instructions were fine with me. Here's been my experience with some of the kits I bought since the Badger: -- Amati Pegasus: I bought the kit because of the ship's beautiful lines and decorations, the availability of TFFM and plans from the NMM, and because the kit components were of very high quality. The kit in my opinion is A+++ all around. If you like the subject matter, Amati has hit the ball out of the park with this kit. My only quibble is that the walnut planking and walnut laminated sheets had such variation in color that I couldn't use it since I wanted natural finishes on the model. -- MS Charles Morgan: I wanted something different besides the typical 18th century British warship. Great plans, lots of information out there, and you can see the actual ship in person. I'd knock the kit down slightly because the keel and bulkheads are in basswood rather than something stronger like MDF (Pegasus) or plywood, but otherwise I'm very happy with the kit. -- Corel Unicorn: A kit with a lot of promise with available plans from the Chapman Architectura book and the NMM (for its sister ship, the Lyme) that unfortunately frustrated me to the point of dropping the build. Keel was warped. The plans didn't match up with each other or with the parts in many instances. You can certainly build a nice model from the kit, but as you can see from the various logs on here, Corel took a few liberties and the ship is not accurate in many respects. Once I started comparing the ship with the plans, etc., it was going to be too much work to modify things and so I decided I will build a Lyme class ship from scratch in the future. Lots of good suggestions from others above. If I had to come up with my ideal kit, and if you're looking to target the more experienced modeler, I would look to these principles: 1. Good quality frame, plans and detail pieces - MDF or plywood keel and bulkheads, with plans that match one another and the parts. Either include good detail pieces or don't bother including them. Warped keels and bad plans are really unacceptable in my opinion, but they seem to be pretty commonplace. 2. Interesting subject - There are lots of good 18th century British warships out there. After rigging cannons with 2mm blocks, I was very interested in the Charles Morgan for a next build! No cannons, but lots of interesting deck details like the try works, etc. For subjects, maybe another whaler like the ill-fated Essex? A fishing or other kind of working or merchant vessel? Dutch or french ships (I bought the two Euromodel kits in my signature because they were relatively unique offerings in this respect). Something with history, decorations, cool deck items and details? 3. Additional source material - I think as people move onto second, third, etc. builds, the historical piece is almost as interesting as building the model. Plans available from the NMM, or from books like the AOTS series, are great resources to help improve the kit. I think the Pandora can fit this bucket quite nicely, and it also has an interesting history. 4. Option to buy kit components a la carte - Not sure how feasible it is, but I think there would be a market of builders who would buy a kit from a manufacturer if they could buy, for example, the plans, keel and bulkheads, and decorative pieces. Either offer upgraded wood packages or offer the kit without any wood. For me personally, if I'm going to use pear, boxwood, etc., no way I'll buy a complete kit from the manufacturer as I'd rather just wait to buy one off eBay for a big discount and use the savings to buy the wood I want (I bet for some buyers too, the attraction of buying good quality detail pieces from you is a huge incentive to purchase certain kits). Without this option, I think many people will buy from secondhand sources in lieu of buying retail, or they may scratch build what they want. So I'm in if you decide to ever offer an Essex kit with the keel and bulkheads in MDF, great plans, and either without kit wood or the option to upgrade it, and detail pieces for sale on your website You asked about price and build time. I think if you're looking to the intermediate/advanced set, then people get the price and build time factors. Like I said above, I think on price, people might be more apt to buy a kit retail if there was more of an a la carte option. Build time wise, I don't know if people care about finishing a model in a set period of time, unless they were doing it for a job or possibly they were elderly Thanks! Obviously these are idiosyncratic opinions. Sorry for the long post!
Very nice work Elijah! Getting that first strake of planks on takes time, but when done right, it makes for a good foundation for the rest of the planking. I've taken a slightly different approach to fitting planks along tricky curves. Spiling really helps, but there's still a need to bend the planks. Near the bow, I usually soak the planks, pin them in place, and let them dry over night to avoid any shrinkage issues. Essentially that helps pre-shape the planks making gluing much easier. Depending on the nature of the curve, how thick the plank is, etc., after the plank has soaked, I'll sometimes manually flex the planks in my fingers a bit to help stretch and relax the fibers in the wood. So far this has served me pretty well on my Pegasus. It stinks having to wait until the plank is fully dry, but having a little patience means the planks go on better and easier, and you avoid any gaps resulting from the planks shrinking if you try to glue them on right after soaking. I haven't tried using curling irons or crimping tools yet, but those are other methods of getting bends into your planks.
- 701 replies
- phantom
- model shipways
Don, a really great start on an interesting subject. That's amazing too that there is such a long, detailed manual - wish more kits did this. Very nice job! The filler blocks was a bit of any ordeal I'm sure, but you have a fantastic planking surface. Can I ask what woods are in the kit? Also, I saw that the bulkheads are hollowed out. I was curious as to why you think that might be, and whether you found that approach to weaken their structural integrity?
- 653 replies
- trabakul
- marisstella
Hey Martin and Spyglass, thanks for looking in. After looking at the many Swan class logs on here, I think my gunport patterns are right in line with the rest of everyone else's. So that's a good thing. Spy, I don't know what exactly my problem is, but it's most likely that I'm just way overthinking things If I was painting the model, things would be much easier - run the waist rail, paint the frieze background, add the friezes, add the sheer rail, and so on. By using stains, I'm trying to measure with precision where the rails need to end up because I'm switching from pear (dyed brown) to boxwood for the friezes (dyed blue) to redheart for the upper area above the drift rail. I've been trying to take exact measurements off the plans, and it seems like there should be very little bulwark above the bowsprit, especially if you look at the NMM plans. Every Swan class on here seems to be on the higher side, especially relative to the NMM plans. My sense is that the patterns do run a little high at the stem, and it's good to see that you also found that you need to take a bit off the "peak" at the stem. Makes me feel like I'm in good company. It would be nice if Amati noted in the instructions and plans where extra material, if any, existed on the gunport patterns. And you're right about my freestyle lines - that's why I broke out the blue tape to at least start with the waist rail. Once I've set that line, I can use a compass to draw the line for the sheer rail and drift rail, since the areas between those rails should be consistent throughout. I think I'm just going to go by feel on this and run the waist rail and other rails where it looks best. The difference between the starboard and port tape lines is only on the order of 1.5mm or so, and much of it will be covered by the headworks anyway, so I'll try to not make myself too crazy on all this.
That came out really nicely Martin, really nice job!
- 467 replies
- fly
- victory models
I've been making slow progress on my Pegasus. I completed the first strake of planks for the frieze area - using the TFFM planking pattern, I counted 26 planks per side from the frieze area on up, and so far I've gotten 10 done per side. The next strake is a little tricky as the planks have extensions over the gunport, need cut-outs for the fixed blocks in the waist, and one pair have a scarph joint. I'm using boxwood, which is a really really nice wood to work with. Very similar to pear, if not a tad better to work with. I mentioned earlier that I thought the bulwarks came up too high over the stem. Here is a picture that shows what I mean: Looking at the Amati plans, the bulkwarks should barely extend of the bowsprit - and the NMM plans show and even narrower section of the bulwarks extending over the bowsprit: I ran some masking tape to mark the upper line of the waist rail. Here is the line which matches the run of the planking: Unfortunately, I think this is a little high at the stem. From what I can tell, the top of the waist rail should be approximately 5.5mm below where the top of the stem meets the hull (the lower frieze is about 5.5mm in height, and the top of that area ends right about where the top of the stem meets the hull). So on the port side, I marked where I think the upper line of the waist rail should end up (about 2mm lower), and marked the edge of what should be the top of the bulwarks at the stem as well. This is a good picture to show how the run of the waist rail to the stem under both approaches, as well as how much of the gunport pattern will need to be sanded off: Looking at the hull front on, the line dips slightly on the port side, meaning I would have to sand off the stain in that section. I think the cleanest thing will be to just stick with the planking lines as is, though I think the waist rail line at the stem probably will be a tad high (the line is likely in the middle of both the starboard and port approaches). I could add in a very slight taper to the planking as it approaches the stem to help bring the bulwarks down a little more. I think all this bears out that my initial gut that the gunport patterns sat too high at the stem.
Can i live without a BYRNES TABLE SAW
Landlubber Mike replied to shihawk's topic in Modeling tools and Workshop Equipment
I waited for months to see if I could get my hands on a used Byrnes table saw, and had no luck. I ended up buying them new from Jim, and haven't ever regretted the decision. Too many things these days have more complicated and unnecessary configures with multiple parts that just raise the chances of the thing breaking down - Jim's tools on the other hand are built like tanks, and use a very simple yet effective design. I don't get as much modeling time in with work, kids, beer, etc., but I would rather spend the money on good tools that will last a lifetime than buy tools for slightly less that don't have the same quality both in terms of precision and expected lifetime that will end up getting replaced down the road. -
Hi Elijah, I haven't been on MSW much lately. Your careful and thoughtful approach to your build is very commendable! I've found that I probably spend 80% of my time thinking and planning things out, and only the remainder actually building (or finding lost small parts in my carpeting). On the planking, I couldn't find the 3" wide tape that Chuck mentions in his tutorial. I got book tape or something similar that was wide like that, and I just couldn't get it to work. I ended up going with the approach of just using a compass along the adjoining plank edge which I found very easy (though, I imagine the less wide scotch tape should do the trick as well): http://modelshipworld.com/index.php/topic/7267-hms-pegasus-by-landlubber-mike-amativictory-models-scale-164/?p=365802 I'm by no means an expert, but when I set up my planking bands, I tried to fit an even number of standard-width planks at the widest part of the planking band. So, I was using 4mm planks, I would set up 20mm planking bands at the middle of the hull, and adjust them for and aft. The middle of the hull should require little to no tapering/spiling, so it's nice to base the planking bands off that section. I think from your picture above that you have temporarily taped the planks to the hull. One thing to keep in mind is that because the planks will overlap at the joint lines, you'll need to sand the plank edges so that you have a smooth run to butt the next planking run against it. It makes it much easier when spilling or otherwise adding rows of planking. Good luck!
- 701 replies
- phantom
- model shipways
Mill Column for Sherline Lathe
Landlubber Mike replied to mikiek's topic in Modeling tools and Workshop Equipment
Hey Mike, I bought both separately on eBay, and only after they arrived did I realize that there was the mill column attachment. I had a bit of regret after seeing that option, but eventually came to the same conclusion that Grant did which helped me to validate my purchases. If you have space and budget restrictions, and don't mind the inconvenience of reconfiguring the machine, then I think the mill column is a very nice option. -
As with the planking, I think as you're finding out it's better to start from the bow and work your way aft to the stern. Use the deck patterns to help line things up, and run something perpendicular across the deck to make sure that the gun ports are symmetrical. For the "S" curves in the bulwarks, try pinning the gunport patterns in the middle of the patterns as well as at the top and bottom to make sure that the patterns adhere to the curves in the bulkheads. One thing I did was soak the patterns, and carefully flex them to get the patterns to relax to better contour to the bulkheads. As a fallback, you can always sand back the first planking to help improve the "S" curve shape if necessary. I did some of that on my Pegasus and the curves are now much nicer. I remember having a lot of choice words on installing the patterns, particularly at the stem. The hole for the bowsprit didn't seem to match up with the plans and the overall run of the gunport patterns, and I'm still having some questions on whether I need to sand back the tops near the stem a bit because they seem to be sitting a tad high. Like you, I also think that the patterns are a bit long - as I mentioned on my log, it would have been nice if the instructions and plans had pointed out where the extra material was located. On the picture labeled Exhibit A in your post above, it's a bit hard to tell from the picture, but is the bulkhead extension too high for one of the bulkheads? If so, this might be causing your problems with aligning the gunport patterns. It might also cause you problems down the road once you start planking, because you won't have a smooth line between the bulkheads in front and behind it. Since you're redoing the gunport patterns, you might consider reseating that bulkhead if that is the case - I think you will spare yourself some headaches down the road.
The Byrnes sander is probably my most used tool. I've tried things like the "sand-it," sanding blocks and the like, but nothing can approach the power tool approach of getting precise straight edges and corners. The Byrnes table saw is probably my next most-used tool. So far I've only used it for cutting planks and some of the deck items, but I'm looking forward to using it to build other things like the gun carriages. Like the sander, the table saw is great for cutting precise pieces with straight edges. When you add things like the taper jig, you can cut things like the stern post and rudder and other longer angled pieces with straight edges where it might be hard to use a sanding block to achieve the same results given the length. I love the table saw, but you have to respect it - turning it on always makes my posterior pucker up a tad. I also have the Byrnes thickness sander, but I rarely use it. I used it on my aborted Lyme build to sand down piece of plywood that I used to replace the warped keel, and use it here and there when my stock wood is slightly thicker than what I need. I saw a video of one of the Russian masters who seems to routinely use it to quickly get a nice finish on completed parts. The Sherline tools are really nice. I bought the mill and lathe used a while back on eBay to save money, and have cobbled together various accessories as well when I've seen deals. Maybe a tad overkill for what I would use them for since I'm not scratch building open-frame models, but after reading TFFM and seeing what people are using them for here, I'm excited by their functionality - if my wife ever asks, I'll just blame Ian for making me feel like I needed them after seeing his detail work on his Unicorn. The mill in particular has a lot of cool features one can use it for. I used to have the Proxxon mini-lathe which was a godsend when I was building the masts and spars on my Badger, but I figured I'd upgrade to the Sherline which is a little bigger and can also do metal. The add-on accessories can also be used on the mill which is a nice touch. The last tool I have is the Dewalt scroll saw, which I bought on Craigslist for a really great deal (a hobby furniture maker near me bought it on a whim at a show, got it home, turned it on once to see if it worked, and then realized he had no need for it). I've used this quite a bit. For the Pegasus, I used it to cut out the bulkhead tops out of redheart. I also recently used it for my Morgan to cut out a new stem in pear. It's also my go-to tool to quickly cut out a small piece of wood that I then sand down to straight edges on the sander (it's easier than resetting the table saw, especially when the rip fence is locked in place and I need it in the future to make repeated cuts in that width). Using the tools has been fun if you're into that sort of thing. Certainly they can be expensive, but if you don't mind used machines, you can get great deals on Craigslist, eBay, etc. Of course there are people that strictly use hand tools and come out with models much better than I can ever dream of approaching.
Herb, I would echo what Spyglass said about getting the gunport patterns as close to perfect as possible. They need to be not only symmetrical, but properly placed since things like the wales, rails, etc. use the gun ports as reference points. If you're interested, take a look at my log starting at this page - Spyglass provided some very helpful notes as you can see, which were borne out by my fitting of the patterns: http://modelshipworld.com/index.php/topic/7267-hms-pegasus-by-landlubber-mike-amativictory-models-scale-164/?p=270839 The plans are incorrect in showing the jigsaw joint line between the two pattern pieces as falling on the bulkhead. The jigsaw should sit just behind the bulkhead as you can see on my log. I also soaked and pinned twice before finally gluing it. I found that the patterns didn't really hold their shape too well after soaking/pinning/drying, though the plywood became a little more flexible. Good luck! It's an important step to get right so take your time.
