clearway
Everything posted by clearway
  1. Thanks for likes and comments and taking a look in everyone. All i can say is Futtocks! 😁. Following Lees book i have used chain for the foremost futtock shroud and rope for the rest (should be hooked to the deadeye plates on the top but seized them instead). I was in two minds as to use chain for all the shrouds but liked the difference in look. next i will have to decide whether to rig preventer stays for the main topmast or just single so i can fit thimble/ block in place for stays on fore masthead. Take care all Keith
  2. welcome back to the terror club Keith- not sure if you seen it but got back to your question regarding the tops on my log- been a couple of posts since i answered. Keith
  3. Work continues on fore and main masts with the battens fitted to the masthead and a piece of walnut for the sling cleats which will be carved to shape when glue dry. Also used the thinner brass rod in the kit to make strops for the futtock deadeyes (more in depth description on my strop making on my hms victory build log). next will need to paint them black along with hand rails and fit the chain necklaces around the masts for the futtock shrouds. take care all, Keith
  4. I agree Daniel anything better than instructions! the dashes around the mast area are eyebolts for taking hooks from rigging blocks. on later drawings there appear to be less. i settled for 6 (4 at base of mast 2 fore and 2 aft with a couple further forward under the posts for the winch drums / massey pump flywheels). Keith
  5. TY wahka- for future projects i have a few to choose from, but thinking occre's HMS Beagle (asides from finishing HMS Victory at some point)! Though i also have the trumpeter 1/200 titanic as well😉. Keith
  6. can't beat it when stuff like that happens😱. going to make you swear a little now..... the fife rail abaft the the mainmast should be on the forward side (initially made that mistake myself)🤪. Decks are starting to look nice and busy now😁. Keith
  7. Hi Keith and TY, the tops are made from scratch ,thin ply base with veneer strip for planking and ply curved front piece and kit decking strip around other three sides. The battens are around 1.5mm squared but then sanded thinner as in following pics. fore top is 55mm wide and 35mm at sides, curving to 40mm at front. Main top is 60mm wide x 40mm at the sides and 45mm at the front of the curve. take care everyone Keith
  8. Thanks for the likes and comments so far everyone. Back with the masts and fitted the battens to the main and fore tops using Lees's book (based them on the 1802 onwards style), and the handrails using some etched ones left over from victory build with brass rod from kit which needs ends files neater and painted black. take care all. Keith
  9. nice work with the main bitts- look far better with the curve😁. for my bands a just used some black card that was backing for a 1/35 turned aluminum gun barrell so can't say exactly but isn't much thicker than a sheet of paper. Keith
  10. Hi Daniel, i used some spare billings turned brass eyes left over from previous builds for my bearings (never throw anything away after a build)! The drums on the posts in front of the main and fore masts are warping drums especially for the jeers. In later days these evolved into dolly winches (see cutty sarks deck fittings). Keith
  11. yep keith, thats where that chain around the mast came from😉. Keith
  12. brrrrrrrrrrrr getting colder here !!! After much deliberation on how i was going to attach the mizzen topmast shrouds/ futtocks i decided on a single chain collar (will fit two chains per mast on fore and main as per Lee's book). take care all Keith
  13. or my capstan i used the spindle and base off the kit one and made new head from two pieces of wood with squares filed in then sandwiched together, and plasticard discs for the metal base and pawl bits.
  14. I used 8mm belaying pins for mine Daniel , glad to see the other keith clearing the decks and preparing for action😁. Keith
  15. nice touch (don't forget to leave a bit of it blank though😉) have you thought about replacing the occre belaying pins with brass ones though? Keith
  16. Thanks for looking in as always everyone, back in the shipyard and the mizzen mast is finished with the eyebolts for the topping lifts and peak halliard in place. Also fitted the fid on the topgallant mast. Thinking of the boom sheet i decided to go with an eyebolt on the transom and a cleat on the deck as in Lees book. Just realised i am now ready to fit the mizzen and start rigging the shrouds (i always start masting/ rigging with the mizzen and work forwards). take care all Keith
  17. the battens are on all three masts (not topmasts heads though) There are holes drilled into the ends for the shrouds to pass through from the topmast , and will attach them to a collar around the mizzen. Keith
  18. Happy New YearDaniel. The masts in Lees books show the set up on large man o wars don't bother with hoops or bands above the top, Oh and no top fitted on terror and erebus just the cross and trestle trees on the mizzen. The pic on top of page 10 on my log shows the mizzen complete bar the eyes for the blocks. Keith
  19. Happy New Year everyone, heres hoping its an improvement on the last one! It's not a Terror pic but thought it might help warm us up during the cold spell Take care all. Keith
  20. you too and here is hoping normality returns😉
  21. James Lees "masting and rigging the english ship of war" is good, but getting harder / expensive to find (have sent a few guys on here to the abe's books website). Also try local second hand bookshops as there are loads of books aimed at modellers showing masting and rigging, Keith
  22. Welcome back Geo, and thankyou😉 another set of stern deck houses added to a terror (maybe occre will take the hint and update the kit)! If not too late you should remove the pin rail from in front of the mizzen mast and add a spider band around the mast. Keith
  23. the camera can be a cruel mistress! looking good though😀 Keith
  24. Rather than go exact with the ratios what i do is work out the doubling + length of the bibs , make the tops then square the mast so the top is a snug fit- then i work the taper in if that makes sense (a pic of finished squaring on my log), but yes the taper is noticable (look carefully at the pic of my finished masts) especially on the topmasts and t'gallants. Keith
