clearway
Everything posted by clearway
  1. thinking about strengthening the bulwarks- how about using thick card without the corrugations glued to the frames ?
  2. 😁good idea about reducing the hole size- them new belaying pins look a lot more realistic, and as we know from the wreck shot the belaying pins are a brass alloy - still freaks me out because they look like they have only been underwater a week or so! Keith
  3. No problem Keith- we are experiencing massive delays with the u.k. postal system because they can't cram the staff into the sorting office due to "social distancing/ safe space rules" at the moment so are having to work with 30% of the staff doing 100% of the work. except for the mizzen build the masts as occre describe but with the squared tops to the masts and i will most likely scratch new tops as the ones in the kit are too small due to having 2mm wide rim added- i will make them to the different shape and add a finer rim on top so deadeyes are at the edge- will do the mizzen as fore and main but with just the crosstrees and trestle trees. i will also be scratching the trees for the top mast as i dont like using ply for them (same with mizzen) probably out of walnut or basswood as they will be painted white. Keith
  4. looking nice and smooth- don't worry if some of the planklines show through after top coat and varnish as they do on the real thing- it's more about getting rid of the oversize wood grain effect. Keith
  5. all sailing ships had the tops of the masts squared at the tops where they doubled- i make the top including crosstrees and trestletrees then trim the top of the mast , first with a knife then fine tune till the top is a nice fit- you will need to carry the flat down the sides for the cheeks and the two pieces of flat timber that run so far down each side- it shows some of what i did earlier in my victory log- also see below which shows varios styles of top through the ages. i think terrors will be like the top one fig D Keith
  6. yep spider band looks a lot better keith- i think occre have the heights of the masts about right but dont fasten anything to them until you have squared the tops and added the bands etc. Keith
  7. good to hear Keith , your soul sounded in a dark place there for a while. Not a bad little boat and nice seeing a sailboat gaff rigged as opposed to the run of the mill triangular sails you see . Keith
  8. Hi Keith- sorry to hear about the lost book- if you need any info in the future just ask(when i get to it there is a standard ratio they used for lengths of masts/ yards- a little "modellers licence" is allowed though😉. Taking a break from her is a good idea if it is doing your nut in- there's gaps of 6-12 months where i havn't touched victory, and i still have to finish a scratch built dredger i started in 1998! Out of curiosity what type of craft are you building as i grew up around boats being the son of a fisherman and was hopping over bulwarks and anchor chains about as soon as i could walk. take care Keith
  9. still working away on my winter messy modelling workshop so not much happening in shipyard though did manage to get the fore tops'l yard tyes rigged to the kevels on fore deck. next job will be the tops'l sheets. take care all Keith
  10. i install the masts then rig the shrouds starting with mizzen and sequence forward - basically there is a step by step guide on my billings victory log- then i install the driver boom and gaff then the yards working from mizzen forwards- on ships from terrors era the futtock stays rig to cains around the mast as opposed to the shrouds on earlier ships.😉 beware occre havn't got the rigging 100% correct. Keith
  11. not much happening in the shipyard due to D.I.Y. projects (getting my winter messy job lair organised with spray benches, stove and lift up shelter on veranda - admiral says i look like kiosk keith!) did manage to get the walnut planking on the outside of the bulwarks which gives an idea how the hull will look colour wise- should be dark enough though walnut can mellow in colour when it is exposed to air long enough. the access ports etc still need trimmed to size on bulwarks. take care all Keith
  12. that is the best way Emmet- i spent a lot of time getting the planking on my victory as good as possible because even though i was painting/ coppering i still wanted a sound foundation for everything to rest on- filler and coppering shouldn't be used to hide serfious mishaps😉 Keith
  13. it will go as far as the start of the bow or forefoot-the build log i mentioned will explain- but if your method is going to work go for it😉😁. everyone has their own viewpoint on this. Keith
  14. looking at her on the cradle looking sideways on with the ship upright (as if you were observing a real ship in a dry dock) Keith
  15. looking good considering you have not had much experience with planking- the priming and sanding until the wood grain is rubbed down is a pain- one of the jobs i only ever do outdoors due to the dust. Keith
  16. it will be tapered from the top to make it look straight when viewed sideways on- there is an interesting half hull project in kit logs showing planking techniques which you might find interesting- can't remember name on build log but posts were being added recently.
  17. is now a bad time to mention a european manufacturer makes a laser kit wooden deck for her😇- however excellent weathering technique with the deck. Keith
  18. nice to see you have learnt the art of tapering the planks- don't rush her she is looking great. Keith
  19. nows the time to decide if you want to show the steps leading down from the upper gun deck to the middle gun deck- you will have to squeeze a piece of deck in where the steps are😉 Keith
  20. welcome back Emmet- general rule is garboard plank should look straight from bow to midships when viewed from side- that bit for cutting gunports will save you a lot of time. Keith
  21. welcome to the hms victory builders club dave Keith
  22. weird i got wooden deadeyes with mine!? and even though wrong the ships wheels were bronzed- maybe due to manufacturing restrictions over last few months- i got some replacement boats from quaycraft via cornwall model boats. Keith
  23. looking good jeff -to get my run for the tuck on victory and terror i held a plank where the stern post meets the counter and let it fall naturally round the hull and tapered my planking around that at the stern end- basically you end up half way round the bilge from the top of the sternpost😁 Keith
  24. you look after yourself too Jo- glad to be of service- any questions feel free to ask. Keith
