Canute
Everything posted by Canute
  1. Alclad II paints has a blue green lacquer window tint for spraying onto modern passenger car windows. See: http://alclad2.com/finishes/transparent/
  2. David, did you seal the paper/card? I got some Krylon Matt Finish #1311 at Lowe's or Ace Hardware. Quick drying flat sealer. Haven't had any ink runs from the white glue I use.
  3. Rinse the part in white vinegar (common household stuff) for a few minutes. If there's any grease, this should remove it. Double check if you have to dilute/cut the blackening solution. I haven't used this particular brand. Some blackeners must be cut to work properly.
  4. Well said, Keith.
  5. Like David, I'm pulling up a chair to watch this build. I've got an Amati/Victory Granado in the stash, so any tips I can glean on these brand kits will be a plus.
  6. If you have a kit downloaded from a website, you can re-print a part, since you own the file. Working with a kit published as a booklet (typical of the many fine European card modeling sites), you have to be quite careful or else be paranoid and copy all the pages before hacking up the original.
  7. Ed, I've just started reading your work(s), lured by the reviews of your book(s). Beautiful work and nice clear explanations. Takes a lot to impress this former Jersey-man and I am very impressed. Thanks, and I'm following along, too.
  8. You may want to look at yelo-glo LEDs. Good simulation of the old kerosene lantern look. Or paint Tamiya Clear orange on the LEDs. Take a look at these folks' products: http://www.litchfieldstation.com/xcart/home.php?cat=22
  9. Dan, excellent primer on working with photo-etch.Thanks for the great photos.
  10. Great save! Another idea for that bag of "tricks".
  11. Cap'n, it's lurking in the shop. I've been lured by a card ship from the American Civil War. Not to worry, I'll get back to it. Boyd, thanks for the compliments. I had a wee block and wandered into a card model. I'm more comfortable with wood, just need to do some of the basics better. I'm fortunate for the assistance of all you folks and hope I don't prove your judgement isn't misplaced.
  12. Good stuff, mate. Thanks for sharing.
  13. Jay, I've used a piece of rail as a weight a time or two. But I wanted to weigh down a large, flat item, gluing card and cardboard together. Are those diving weights? Not sure about the iron ball. We've used big weights for surf fishing, but those were lead.
  14. Looking good Jesse. Great jig/fixture for the copper plates.
  15. Aye, thank the Dear, yer foosbal season be over and we all can enjoy yer scribblins in the sweet Connie. I canna wait to see what else may spring forth from yer fertile (?) imagination. I do like the great cabin's start.
  16. Well done, Mike. your hull can't be anything but beautiful, thanks to all the work you've put in so far.
  17. Plaster can be glued. I've used it on some Hydrocal cast buildings. Hydrocal is a super hard plaster, but it can break if not handled properly. Old model railroaders used it as a bottom layer when doing layout landscaping. They'd put molding plaster on top, since that plaster was easier to work with, due to it's softness.
  18. Brian, what gauge is that syringe? Mine has too wide a bore and is sometimes a pain to use.
  19. Thanks for the likes, folks. And David, I'll give it a shot. Thanks for the idea.
  20. I've been a fan of the Brown Water Navy and the combat along the various rivers during the "late Unpleasantness" known as the Civil War. The boats were mostly paddle wheel or stern wheel. Some of the US Navy ships, like Farragut's USS Hartford, were screw powered, but they couldn't navigate in the shallower waters inland. Check this site for some more info: http://users.wowway.com/~jenkins/ironclads/ironclad.htm Some of his links may be dead, but it's a start for getting to some basics.
