ccoyle
Moderators
Everything posted by ccoyle
  1. Wow! Your dad's workshop would be the envy of many modelers here. Sorry to get back to you so late on your query about the GH. Bob Cleek made some very salient comments about the challenges inherent in building a large scale model, but when I read your original post I did not think that that was what you had in mind. Some people have built vary large sailing models of everything from sailing men-of-war to modern battleships whose emphasis is much more on sailing than on being faithful to the original in every respect. These models are more like impressions of the real thing, and that is what I believe you have in mind. GH should be within your capabilities given your motivation and determination, especially if your dad is helping you, but you will find that it is not necessarily a simple project and may take more time to complete than you anticipate -- be patient and enjoy the process, and you may eventually find that you and your dad enjoy building little models as well as large ones. The main reason why I suggested that you try your hand at something like GH is first of all to get your feet wet at working in wood, second that you discover that there is a multitude of skills that must be acquired to build something like a scale wooden model, and third that you observe how a galleon built from a kit is not a real galleon in terms of its construction but rather a compilation of compromises in materials and construction methods based on the needs and desires of a 21st-century modeler rather than those of a 17th-century sailor. As I believe I said in my original post, some of those kit methods may work when scaled up to a larger sailing model, but your larger model will of course have to take in to account additional considerations based on the fact that it will be much larger and need to actually sail. As I said, we have members here who are knowledgeable on such things, but I'm not one of them. To see a large-scale sailing model being built by one of our members, check out this build log for a 1/36 scale brig.
  2. Mine are parts 55 L & P. The curvature of the bottom of each piece doesn't exactly match those of the previously laid strakes, creating a sliver of a gap, and the stern ends creep up a bit, hitting the stern post about a half-millimeter past the tick mark. Doesn't sound like much, but so far the kit has fit together essentially flawlessly, so this is a bit of a hiccup. I'm waiting until I'm rested and in the proper "frame of mind" before tackling this.
  3. I haven't posted for a couple of days because progress on the planking has been slow. I also hit a little bit of a snag with the next set of planks to be installed, these being the first that don't initially fit precisely. Whether that is a design issue or the result of some error creep I haven't yet determined, but I'll need to proceed carefully.
  4. I think when he said "slow-cure glue" that he meant slow-cure CA (cyanoacrylate, commonly known as "super glue"). CA normally comes in either thin, medium, or thick formulations which cure at different rates, from fast (couple of seconds) for the thin stuff to slow (several minutes) for the thick. Medium-cure is the most general-use formulation and will set in ~30-60 seconds depending on how much you use, which means that parts can be held together with your fingers until it sets. One downside with CA is that any excess slopped beyond a joint will dry into an unsightly opaque white crust and prevent any stains from penetrating the contaminated surface. Removing the excess can be extremely difficult in confined spaces such as the interior of your tiny yawl, which means that careful and precise initial application is a must.
  5. This YouTuber has a couple of interesting videos of himself rowing the Annapolis wherry. It is indeed a very nice looking boat, and apparently a good rowing boat as well. vid 1 vid 2 I feel a little sorry for the kayakers in the second video -- pluggin' away while this guy seems to just glide effortlessly on by.
  6. Yes, it's all wood, but some of it, e.g. the planking, is so thin that it can be manipulated and treated in much the same manner as card. For instance, the photo instructions suggest using a plank bender for pre-shaping the planks, but I found that moistening the back of the part and using my fingers -- much as for card -- produces the desired effect. The planking is not pre-darkened, but the instructions do suggest that it gets stained/varnished a little later in the process. The fit of the planking has been spot-on so far.
  7. Welcome aboard! The longboat kit has proven to be a very popular among beginners, and we have plenty of finished build logs for you to use for guidance. Sorry, no kits of Beaver, though, and she does not closely resemble any kits that I'm familiar with. Cheers!
  8. My paternal 3x-great-grandfather had a front-row view of Grant's maneuvers -- from inside the Vicksburg garrison (Co. G, 39th Georgia Infantry).
  9. I have a soft spot for the Flowers ever since building the 1/100 scale Agassiz in card from Modelik, though sadly without the striking Western Approaches camouflage.
  10. And that is very typical of Model Shipways designs. You have acquired a useful skill!
  11. Welcome aboard! Yes, modeling is a bit of an addiction, but with some professional therapy, most modelers can manage their habit. Ha -- just kidding! Once you are hooked, it's hopeless. 😉
  12. I agree! I bet there's a lot of orphaned models out there hoping that Mike will stumble upon them. 😉
  13. Weathering has never been a strong suit of mine. I prefer to leave things in the bright.
  14. Progress for Day 5. Another aspect of this kit that is very card-like is the need to laminate parts. The four stringers in this first photo are each laminated from three parts. And some more false decking. A few more bits need to be added to the hull before planking can start.
  15. The Mamoli product line is now produced by Dusek Ship kits. Daniel has made refinements to each kit prior to re-release.
  16. Nope. The false deck halves will not fit if accidentally reversed.
  17. Very nice work, Danny. I have the MV Schwan II kit in my stash.
  18. So, I was in the process of gluing up the interlocking parts of the false deck & hull formers and having a devil of a time trying to get the forward false deck pieces to snug up properly. Then I noticed that there were two deck tabs that had no corresponding slot in the longitudinal former. So first I checked the instructions ... ... and yep, there's supposed to be a slot. But, here's a shot of the deck tab, deflected about 2 mm down, and there's no slot there. Since the deck was already partially glued in, I had to use a ball cutter in my Dremel to remove the tabs. Not a big deal, but kinda strange.
