Everything posted by dafi
I think the "official" butt schemes are an ideal solution, that ensures maximum strength of the deck which is a integral part of the structure of the ship and not "just some planks to walk on". But reality then collides with plenty of issues, the biggest probably is dealing with the material available. Also repairs will easily give some deviations to the pattern. Also the Vic there are some parts where a 4 but shift can be recognized, but most is a irregular pattern. Whatever patter you prefer for what year is up to you, nobody can prove how it was in the year 1XXX. Just there are some remarks: It was never as neat as we would like our models to look ;-) I think important is to respect the deck beams, get near to a 4 butt shift system and avoid short ends and butts in between coamings and near the start and end of the decks. Cheers, Daniel
Impressive project :-) Love it ! XXXDAn
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Thank you sal, Pop, Izzy and Ian. @Izzy Thank you for the pictures. The modern model making version that I use and that works very well is the one shown from RB Productions and come in all necessary sizes: http://www.google.de/search?hl=de&q=rb+productions+rivet+tool&gbv=2&sa=X&oi=image_result_group&ei=ZUVxVdzDJILkUoG_gpAD&ved=0CDAQsAQ&tbm=isch Those I already tested but it was good for the seam of the plates but it was great to find the dermaroller as there the points are still finer - necessary for my scale - and also to see the trick of having the parallel rolls for an even appearance of the surface nailing as Popeye mentioned. Cheers, Daniel
Smells like danger ... ... big danger ... ... enormous danger ... ... one of these days, I was in the bathroom and I found a new torture tool belonging to my wife: a Dermaroller! Iron Maiden just inverted, spikes outside - how that could help the skin I will never understand. But if you believe that that thing is dangerous, you are on the wrong track - the danger lies somewhere completely else!!! I suddenly had a flash of inspiration and wanted to have a closer look at the thingy, and believe it or not, it crumbled into pieces just in front of my very eyes, I solemnly declare I did not touch it - I just looked ... ... but if it is already prepared for needing reassembly I thought that I could try out something. So I took out the 1,5 mm thick pinky spacers and replaced them by 0,5 mm sheet. Used the old ones as template, so it went rather fast ... ... and reassembled the bit with only five spikewheels :-) And here it is the patented Dr. dafi Rivetroller®© :-) :-) :-) Immediately tried it out on the copperplates to get an even and parallel surface-riveting ... ... which worked wonderfully as the roller had the right thickness for the row of plates ... ... and afterwards just gave the tighter riveting on the edges of the plates with the Riveter from RB . The small vertical lines come from the nut on the back of the small riveter, me doofus did not pay attention to this small technical issue. So if it takes some time to come back to you, it could be that I am trying to learn how to drink out of a sippy cup and also I do strongly believe that it will be difficult to type with broken my fingers ... ... as I am quite sure that it will come, the scream: "Daaaaaaaarrrling, have you seen my dermaroller?" ... ... and yes that is the true danger ... ... XXXDAn
Boy's Manual Of Seamanship And Gunnery
dafi replied to skipper1947's topic in Nautical/Naval History
thank you! DAniel -
US Brig Syren by Gahm - Model Shipways
dafi replied to Gahm's topic in - Kit build logs for subjects built from 1801 - 1850
Why?!? Why did this gem did escape my attention so far? Wonderfully build and thank you for showing so much of the "how to". Cheers and congratulations! DAniel -
Very nice work :-) For the gun tackles: There are plenty of ways to store them your version I saw on the Costitution :-) But if nobody is holding the free end, I would advise to secure them somehow. Either like I did behind the pulley with a kind of half hitch that can be opened like a lacet, or Boudriot shows something secured around the breech, in your case a nice tie around the faun´s head. Cheers, Daniel
- 196 replies
- plastic
- soleil royal
Great tool :-) I think there are some little tricks that could still improve the outcome: First when cutting the thread unravels. Better pass the whole length though PVA or wallpaper glue to stop this. Second before cutting put a drop of superglue onto the knot and the 1 mm underneath - so the will keep the direction. Cheers, Daniel
- 119 replies
- la reale de france
- heller
Thank you Izzy, Popeye, Steve, OC, Jerry and all the kind likes! Special thanks for information about Brown Betty, very appreciated! Great picture you and Bess :-) Looks like mine are 135 cm, have to lengthen the next ones by a 1/10 mm ;-) Luckily the strap is hiding the lump :-) Cheers, DAniel
Slowly hunger was shifting the mood and there were some concerns about the two sentinels being able to handle their mates ... ... so back to plan B and deliver the goods in form of the earlier proposed 10 course dinner. But small oupsy happened ... ... the meal was historical, but 107 years to young, I found hints it was from the 14. April 1912. So thinking about the side effects of this meal, the marines discussed and with an ice cold mood decided to opt for the normal stew. We should have a small look into the bucket, that would give us a hint, which day of the week is displayed in the small setup: Sunday 1 pound pork, ½ pint peas Monday 1 pint oatmeal, 2 ounces butter Tuesday 2 pounds beef Wednesday ½ pint peas, 1 pint oatmeal, 2 ounces butter, 4 ounces cheese Thursday Same as Sunday Friday Same as Monday Saturday Same as Tuesday An overview over our gay* party shows an increasingly raising mood, as the mess on the right is already served - with a lovingly elegant gesture the wooden spoon scratches out a blop of food out of the bucket and conveys it to the square plate with the metal dish *floush* Also the mess on the left is starting to giggle in anticipation as their bucket full of delicious food is coming nearer and perhaps even can be guessed through the olphactorical chaos of the lower deck. And dinner is served :-) Usually a mess consists of 4 to 8 man that shared cooking and eat together. One had the duty to bring the food to the Brody stove a deck above and take care that nobody stole food from it while being cooked. In case of the Victory there were about 160 messes. Next bucket with food for souls is drawing nearer. Now that is party time! See some already took off their jackets and hung them up on the ceiling. But nobody dared to throw them over the gunz ... One can see it simply is a tight and cosy place :-) XXXDAn PS: The drawings of Bray´s album still show the pre-1803-uniforms. http://collections.rmg.co.uk/collections.html#!csearch;searchTerm=bray * and gay here in its original meaning ;-)
Hy Izzy, I have a similar piece in even better condition. I do believe it is to coarse for the pulleys. Perhaps for the windlass of the grand barge? Cheers, Daniel
H.M.S. Victory, Heller, 1/100, Onward and Upwards.
dafi replied to Izzy Madd's topic in Plastic model kits
It follows the rope sizes :-) It is indicated in the rigging tablature in the end of McKays AOTS :-) XXXDAn -
Thank you Jason and Jan. The return question is: Will the lower gun deck ever be 'done' ... ;-) XXXDAn
And what does one do, if one has a bunch of hungry marines waiting for food and sitting in front of the gun room? Of course, one should take precautions. Preparations include getting the equipment ready ... ... and the arms too ... ... and to dress the guards. Ok I missed the epaulets ... ... but I shortened the tails according to the 1803 regulations. Just the officers had long tails, thanks to Foxy for that detail! Larger than life :-) And very important: place them in front of the gun room ... ... for that the Haute Volée can stay in peace and quiet. And the long tails of the to red men in the background clearly show. Yes, we are officers :-) Cheers, DAniel
For that there will be no mutiny because of the empty plates, here is the proposal for the menu, according to historical sources: First Course Hors D'Oeuvres Oysters Second Course Consommé Olga Cream of Barley Third Course Poached Salmon with Mousseline Sauce, Cucumbers Fourth Course Filet Mignons Lili Saute of Chicken, Lyonnaise Vegetable Marrow Farci Fifth Course Lamb, Mint Sauce Roast Duckling, Apple Sauce Sirloin of Beef, Chateau Potatoes Green Pea Creamed Carrots Boiled Rice Parmentier & Boiled New Potatoes Sixth Course Punch Romaine Seventh Course Roast Squab & Cress Eighth Course Cold Asparagus Vinaigrette Ninth Course Pate de Foie Gras Celery Tenth Course Waldorf Pudding Peaches in Chartreuse Jelly Chocolate & Vanilla Eclairs French Ice Cream *dream* XXXDAn
A very enjoyable build :-) Cheers, Daniel
- 1,477 replies
- essex
- model shipways
ancre LE BONHOMME RICHARD by Jeronimo - FINISHED
dafi replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Simply a dream! Thank you for sharing with us all, Daniel- 662 replies
- bonhomme richard
- frigate
Even a better source is Bray´s album in NMM Shows chest everywhere and being seated on :-)
Thank you guys for the feedbacks and the open eyes! @ Frank: Thank you, the scissors already are working their way through the compliment :-) @ Izzy: Beches still will be hanged on the inboard side - but still missing the beam ... @ all: was the out side fixed on the hull or was it hanged too? @ Izzy and Jan: Thank you for the nice pictures of the handles. I actually decided on the wooden handles, as the rope ones were too invisible. Will be a nice detail on the show chests. Actually the pictures of Bray show plenty of chests used for people sitting around. Cheers, Daniel
This too was described by Nares Seamanship in ca. 1860. Possibly this is the source of the Victory being equipped with the left hand breech ropes. Further research did not yet find earlier sources so far. So I personally find it doubtful for the use in 1805 on Victory. Has anybody further hints? XXXDAn
- 29 replies
- Rope making
- z twist
Thank you all, very appreciated! And the birthday party continious. On Modellmarine, Germany´s best known daily Marine-Blog there is a short introduction into anchor handling:-) http://www.modellmarine.de/index.php?option=com_content&view=article&id=4238:hms-victory-ankerhandhabung-auf-einem-linienschiff-1100-von-daniel-fischer&catid=491:daniel-fischer Please find the Google translation here: https://translate.googleusercontent.com/translate_c?depth=1&hl=de&ie=UTF8&prev=_t&rurl=translate.google.de&sl=de&tl=en&u=http://www.modellmarine.de/index.php%3Foption%3Dcom_content%26view%3Darticle%26id%3D4238:hms-victory-ankerhandhabung-auf-einem-linienschiff-1100-von-daniel-fischer%26catid%3D491:daniel-fischer&usg=ALkJrhg8ngeoPyT-nnQFrEo3I02RztiPnQ Part 2 probably on Thursday :-) Heep-Heep-Hurrayh, DAniel
HMS Victory windows fram
dafi replied to diablo0007's topic in Building, Framing, Planking and plating a ships hull and deck
Also it is a question of scale :-) Both are for larger scales. XXXDAn
