Everything posted by gjdale
I have to agree Andy, compared to some of us, your progress is just flying along. Looking great too!
- 1,148 replies
Good choice Timmo. Your artist's eye is clearly well focused. Looking mighty sharp. As for the committee, as long as they are only "advisory" and not an "executive" committee, we should do just fine! Otherwise, the words 'camel' and 'horse' come to mind.
- 366 replies
- granado
- caldercraft
Thanks Sjors, If you count the Launch as a separate build, then I have three builds in one log since I've already done one ships boat before.
Ouch Mobbsie!!! I don't like the sound of that. But I do hope you left a tiny speck of blood behind - sort of like an Artist's signature - just to show how much of you went into this build. Hope it heals quickly my friend and that you're back to full speed in no time.
- 1,279 replies
- agamemnon
- caldercraft
Thanks Augie, John, Robert, Sherry, and John for your kind words and encouragement. It's very reassuring to know you're with me on this interesting little diversion! I bent a few more frames around the formers tonight - have sorted the technique so that I can do four at once now. The only limitation now is the number of suitable clamps. The brass ones shown in the previous post are ideal for the job - but I only have four of these.
Nice progress there Sjors - looking good. Don't bother with the cannon ball stowage though, you just know that Anja isn't going to let you have any cannon balls!
- 1,873 replies
- occre
- san ildefonso
Thanks Sjors and Mark. @Mark - sometimes I just need to mull something over for a while before the solution hits me. Mind you, it's usually a BGO (Blinding Glimpse of the Obvious) Some more progress to day. The laminating of the frames is going well.........so far! I've used two pieces of 1/64" thick by 1/16"wide boxwood for each frame. I simply soak them for a few minutes in hot water, then dry them off lightly with a paper towel, apply some PVA glue to one piece then join the two together and clamp around the relevant former. It's proving to be a lot easier than I expected so far. Mind you, I suspect it will get a little more difficult once I get further away from the centre of the boat and start trying to bend some pretty sharp curves. Here's how it looks glued up and clamped around the former: It only takes about an hour or so to dry sufficiently to be able to remove the laminated frame from the former. Each frame is marked for the centreline and also for the sheer line will on the former. Note in this picture how little "spring back" there is once removed from the former: It's then a pretty straight forward process to glue the frame to the keel and the building board. The plug simply acts as a bit of backing when installing the frame. Here's a shot showing several frames completed: It looks to me that there may be a re-do necessary on some frames once all are in place. Sanding these little suckers is not really going to be an option, so getting the right shape is pretty important. Removing and replacing though is pretty easy. The slow part of this process is actually waiting for the frames to dry on the formers. I can only really do two at a time, but then again, there's no hurry.
Hi Mobbsie, I've scanned the section from Longridge on coppering and placed it in the attached files. Hope this is of some help (and I'm making an assumption that Aggy would have been done the same way - I could be wrong. I think this is the same way (or similar) to the way Kevin has done his. Interesting caution about the optical illusion of "waterline sag" too. Longridge on Coppering.pdf Longridge Plan 2.pdf
- 1,279 replies
- agamemnon
- caldercraft
Okay Mobbsie, I'll scan and send the picture in the morning. It's just on midnight here now and I'll disturb the Admiral if I try to do it now! I'll reply to your PM then too - just need to double check with the Admiral.
- 1,279 replies
- agamemnon
- caldercraft
Okay Mobbsie, That's enough procrastination for now. Best get cracking on that coppering if this build is going to be finished in time for my visit! On a more serious note, I don't know if Aggy is the same as Victory in this regard, but according to Longridge Vicky had two "belts" of coppering. I can't think how to describe it in words just now, but if you think it might be useful, I can scan the picture from the book and post here for you.
- 1,279 replies
- agamemnon
- caldercraft
Nice to see some pictures Sjors. Watch out for Augie with the chess set - I think he cheats
- 1,873 replies
- occre
- san ildefonso
Thanks very much Augie, B.E., John, Andy and Mobbsie. @Augie - Yes, the scale is the hardest part of this job. The vibra saw won't be used on the frames themselves. I will be using pre-milled strips that I will laminate together and bend around the formers. @Mobbsie - my current plan is to scratch build all of the boats, trialling a variety of different techniques as I go. Of course, I may get fed up with them at some point - this is not an easy scale to do boats. Still, it's all a good learning experience.
Hi all, Well at last I can report some progress..........of sorts. I've decided to pause on the rigging for a little while, while I wait and see if I can work out how to replicate Chuck's block making method. If I can, I'll make my own blocks for the remainder of this build. If not, I'll proceed with the kit-provided blocks. In the meantime, I made a start on scratch building another versions of the 34' Launch (back on page 13). At last post, I'd made the plug and the building board. I'd been having some difficulty making the keel for this boat. Basically, the material is so thin and fragile that I couldn't seem to keep a keel/stem post in tact while cutting it out. I tried making it in separate pieces, but making the joints at this scale seemed nigh on impossible. I scratched my head (pardon the pun) about this for a few weeks until I had a "light bulb" moment a few days ago and implemented it today. I remembered that I had a "vibra" saw in addition to the big scroll saw. The vibra saw is basically a miniature scroll saw. I inherited this from my Dad a while back when he gave up model building, but I'd forgotten it was there (I know, too many toys!). I worked out that I if left a lot of "meat" on the outside of the keel, while I cut the inside section out, it would give it some stability while I fine tuned it. The vibra saw was also a lot more gentle in its cutting, so at last I had some success. Once I had fine tuned the inside shape, I then used an Exacto knife to slice off the outside bottom edge. Here is the basic keel, made from 1/32" thick boxwood: The next step was to add a piece of 1/32" sq deadwood to the keel and mark and notch it for the frames, using the building board notches as a guide. The frames for this little boat will be made from a laminate of two layers of 1/64"thick x 1/16" wide Boxwood. In order to achieve the bends, I will be using some formers from patterns provided within my practicum. To cut the formers, I laminated together two sheets of 1/32" thick cherry in a cross-grained pattern to add strength. Here are a few patterns stuck on ready for cutting out: Then it was a simple case of cutting them all out on the vibra saw and sanding to final shape. There are a total of 25 frame formers, including the cant frames, which have been cut in pairs for forming. Here's a few pics of the state of the parts as of close of play today. Note that the keel has had a stem apron added. This is twice the thickness of the keel and the overhang either side will form a small rabbet for attaching planks later on. Tomorrow I hope to start forming up the frames and installing the keel into the build board.
Robbyn, Noting your dissatisfaction with the basswood, and that you have only done a couple of planks, one option might be to pause, take off the existing basswood planks and order some boxwood replacements from Jeff at Hobbymill. While I agree that it seems a double whammy after you've paid for the kit, you must remember that ME has built the kit to a price point. At least if you replace the basswood with boxwood you will have a timber that you will enjoy working with and will be satisfied with the result, rather than being frustrated and unhappy. And after all, Chuck's prototype was built with boxwood. This is what I'll be doing before starting this kit anyway.
- 234 replies
- 18th century longboat
- model shipways
Welcome back Andy. Hmmmm....... Sailors and hotel bars.............from my experience, I guess it will take a couple of days for you to dry out before you'll be under the legal limit to work on the build!
- 1,148 replies
Hi John, I have to agree with Daniel (Dafi) - cannonballs only, not grenades as far as I know. Your plank bending "machine" seems to be working. Personally, I have only used a steam iron on pre-soaked timber, but your method looks very good. I've seen others use this with great success - you can just vary the diameter of the tin can for different radius bends. Note also demonborger's comment re the upper deck (poop deck) and placing guns. I think I've already given you the heads-up on this issue. Looks like you're really getting into it now. Keep up the great work.
Good choice Daveor, It looks to be a really nice kit. There will be no shortage of advice and guidance available from some skilled and knowledgable folks here too. Good luck with your build and I'll look forward to seeing your build log once you start.
Thanks for dropping by Lawrence and for your very kind words. I've been quietly following your build too, and must say you're doing a fine job yourself.
Okay, late again! Dang, this time zone difference makes life hard at times. But I'm here now Robbyn, propping up the bar with Mark in the corner and waiting for Sjors to get up for more popcorn! Hope you enjoy the build - I'm sure you'll do an excellent job with it.
- 234 replies
- model shipways
Let me join the chorus of congratulations Ed. A beautiful model indeed, and your log has been such an inspiration to so many of us. I look forward to the remainder of the posts in this log, and eagerly await publication of Vol 2. Thanks again for allowing us to share this journey with you.
Nice start Daryl. I'll be following this one with interest.
- 16 replies
- river queen
- finished
