Posts posted by RGL
Never seen this before, interesting technique. Would not use skin, that’s why I use acetone on all large pieces of PE now to help the primer stick, acrylics just won’t stick.
- popeye the sailor, Piet, Canute and 1 other
- 4
- Old Collingwood, Canute, Piet and 8 others
- 11
Nice deep red!
Be careful using normal masking take as it will lift at the edges or be very ragged. The Tamiya tape really is the goods for it.
- cog, Old Collingwood, Piet and 3 others
- 6
I was going to say your IJN build......
What do you call it when a computer locks up?
- Piet, Old Collingwood, Canute and 1 other
- 4
You have other responsibilities young man. Big Japanese boat perhaps?
Ships cranes. Instructions tell you what the parts are and where they sit but not how to put the thing together. Just horrible. Not intuitive, not like the real thing either.
I wanted them moveable but it just does not align properly, do doubt it’s my fault but instructions would have helped. A lot.
Today’s effort, the fore mast. These things are always a pain to build. I added the type 293 radar to it which used to sit between the forward secondary gun directors.
The little radio room is not glued in yet (none of it is for ease of painting, so there needs to be several more ladders s added later plus more rigging.
- paulsutcliffe, Ryland Craze, Piet and 14 others
- 17
So Pontos barrels and ladders, handrail stanchions will be added after painting to keep them very fine. Pilot holes drilled, 1 unbroken.3mm left.....
The A turret is simple, just needs some stanchions added for handrails, I added a hatch on top, and some windows at the front of the range finders.
The B and Y turrets will have 20mms on them. Pontos gives you the option of the ‘’as Built” useless rockets for the ‘41 version.
I trimmed off the blobs on top on top that were proporting to be ammo boxes which I’ll replace later.
The back of the turrets have access hatches added.
Masts and cranes to go as major build pieces.
- Old Collingwood, BenF89, Jack12477 and 9 others
- 12
Octtuplet 20mm cannons. Over a day’s work to do 6 of them, individual barrels, ammo cans, brass and resin.
I wanted to do these up first to see how they fit on top of the main and secondary guns to measure up the railing stanchions that go on top of them.
You can see the three piece gun in the centre is just no comparison
You’re welcome to join in old boy!
OC, they’re Korean
Banyan, the eyes start to cross and the concentration just goes completely which just means you have to stop.
- lmagna, popeye the sailor, Canute and 5 others
- 8
- CDW, harvey1847, John Allen and 16 others
- 19
@cog @Canute @popeye the sailor It arrived and parked ready for some Infini PE when it comes out.
Sigh, to prove a point that Pontos did not use the KVG for their KVG upgrade, the bridge piece is s not the same. I’m about cross eyed from the wind deflectors. It is easier to break the piece apart and instead of a 1 piece requiring 15 bends, it’s 5 pieces requiring about 3 bends each.
As you can see i had to use a razor saw on the flybridge to get the side panels on. The Instructions say this piece is flat.
G Class Destroyer by cog - FINISHED - Trumpeter - 1/350 - PLASTIC - from Tribal Class kit
I just use a piece of post it note, it’s small enough to rotate in the hand whilst edging so it does not get too soggy. Cheap and you gets lots of them,
