Posts posted by Ondras71
- GrandpaPhil, mtaylor, Valeriy V and 8 others
11
- Siggi52, zappto, vossiewulf and 10 others
13
- mtaylor, Hubac's Historian, Archi and 12 others
15
Very good and clean work! I sink my hat ..
O.
- Keith Black, mtaylor, Baker and 1 other
4
I also love to look at a metal ship model if it's beautifully created like this ..
- popeye the sailor, Canute, Valeriy V and 1 other
4
Wonderful work !!! The first POF? Surely you have been doing this for many years, that ...? !!!!
Doors were provided with 0.5 mm nails, 0.4 mm for the windows. They're also waxed ..I planked the front wall and placed windows and doors on it ..I wonder, if I should place pins or nails in the front wall aswell..In addition, I'm preparing to drill holes for the big nails on the wales, they're on the plan but, after a closer look, in the wrong distance..Of course I am placing the nails (studs) into the ribs, clear logic ..
O.
- GrandpaPhil, Baker, davyboy and 7 others
10
Hello. Here I stitched the sails according to the dimensions. All you need is an agreement..
O.
Hello marsalv. Great start! I'm tense .. O..
On 9/26/2018 at 11:22 AM, Thunder said:
Blimey, what do you need to do to get a gold! An amazing build well done, and I never comment unless seriously impressed.
Perhaps could describe as a merchant ship brought into the Royal Navy for convoy escort protection? The problem with a lot of these kits is they seemed to go out of their way to take real plans and make the description as inaccurate as possible so that you cannot trace the original. Or as in the Unicorn and Royal Caroline, have a full set of plans and then not bother to use them for the model, very strange!
I think the problem was with starting by following the kit accurately, e.g. wide deck boards and gaps between them. After that, I started studying more. But I'm still happy as it is. I also found out that little would be enough to make the kit more accurate, but the manufacturer probably doesn't want that or it would be too expensive.Thank you very much for your feedback! Ondras71 -
Hello. I was also dealing with how to make clean edges on the gunports. On the internet i found a simple way of hand-making this. I mark the ends of the boards with a hole-shaped cork, cut it out roughly and then grind it with sandpaper on a strip. After some testing, it works....I use the Proxxon TG 125 / E front disc grinder to grind the board ends. If needed, I slowly turn it by hand taking less material...
O.
A very good result Zappto..
- Baker, zappto and Old Collingwood
3
Roter Löwe 1597 by Ondras71
in - Build logs for subjects built 1501 - 1750
The deck, repaired, now looks more realistic..👌
