Everything posted by Keith Black
Eberhard, I tried that and it was impossible for me to do it that way. I'd get two eyes in the holes and in placing the third one the first one would pop out. I tried it enough times to know that for me, it didn't work but I appreciate the suggestion very much.
Sometimes one side is better than the other but the way I see most ships shown is bow on the right side as if the ship were sailing left to right. Is this because we read left to right? Are models predominantly shown with the bow on the left built in Middle Eastern countries, reading right to left?
Rob, Brian, Pat, and Iraymo, thank you for your supportive comments and thank you to all for stopping by and the likes. Installing the jackstays on the smaller spars is so tedious I can only sit for a short time at the work table and I have to really force myself back to the table to work. There are 5 to 7 jackstay eyebolts (eye pins) per jackstay, they measure .05 x .175 inches. All of the eyebolts have to be placed in their respective holes and then the jackstay (22 GA wire) is threaded through each eye from tip to the inside eye. The happiness is, the eyebolts can't be glued until the wire is threaded through because the glue (CA) clogs the eyes. The wire has to be straight as an arrow and hopefully the eyes haven't deformed durning the trimming and placement and that they don't rise out of their holes durning the threading process. To help some I've drilled slightly undersized holes (.013) so the eye pins stick into the spar but the eye pins are photo etched and they deform easily. I am happy dance excited when I can apply CA to the base of each eye completing the process. I've completed the jackstay process for two of the six spars, four to go but who's counting.
HMCSS Victoria 1855 by BANYAN - 1:72
Keith Black replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Pat, beautiful. Nice to see you post.- 1,005 replies
- gun dispatch vessel
- victoria
Rob, there are no blocks in the cannon tackle on the instruction sheet, which is incorrect. The drawing in post #108 shows blocks and tackle and your cannon should be modeled accordingly. It's more work (and more expense if the blocks didn't come with the kit) but it's more accurate. Your cannon and carriages turned out great.
Greg, I'm sure most of us could scrounge at least four from the wasteland perimeter.
- 433 replies
- open boat
- small boat
I just did, the eggshell measured .015 to .016 , 1/64 inch = .015625 Glueing surface, what glueing surface?
- 433 replies
- open boat
- small boat
David, I don't think any doubted your ability to recover. Nicely done. To my uncalibrated eye it appears that the plank thickness is just about that of an egg shell, close?
- 433 replies
- open boat
- small boat
Because we're a captive audience. I've had a mulch kit on order from Cub Cadet for my brand new never mowed a blade of grass way too expensive lawn tractor since March 2nd. I can't mow my yard without a mulch kit. No aftermarket alternatives, so, we wait like the trained consumers we've become. Chris, hopefully they get your paint to you in short order.
David, hoping the repair goes smoothly and that you're pleased with the end result.
- 433 replies
- open boat
- small boat
Iraymo, it turned out great. Good save!
- 85 replies
- Lowell Grand Banks Dory
- First Build
druxey is the one to answer that question.
- 85 replies
- First Build
Keith, it'll be interesting to see how you portray the DS. On US Navy ships it seems the DS was 90 degrees to the waterline. Most models have the DS 90 degrees to the bowsprit. In both old and new photographs I see it done both ways so it can't affect functionality or it would be only one way.
