Posts posted by KORTES
Thank you very much Colleagues.
3 hours ago, Valeriy V said:
Alexander is an interesting solution using plastic. Why didn't you use black paper?
My greetings dear Valeriy
I haven’t worked with paper, although I have been reading a lot about it. Time ago I picked from several variations of caulking imitation, and chose this technology and from that time on I have been using only it. For several reasons – plastic can be surfaced and scraped very well in final polishing of the deck covering. And secondly, to my point of view, it resembles better the seal of joints on the deck. And thirdly, on these ships joints are very wide and paper imitation wouldn’t work. Even plastic had to be glued in two layers.
My best regards, Happy New Year.
4 hours ago, G.L. said:
Alexander,
Did you make your carvings with a chisel, a knife or a rotary tool?
Your boeier yacht becomes a real beauty.
My greetings dear Geert.
This element of carving was made using nothing but incisor. For the finish processing I had to surface it using a wooden toothpick, fastened by microdrill.
My best regards. Happy New Year!
Hello Paul.
I used plastic film for calking. I used this method when i was building "Carolina". All that one needs for this can be found in any stationary shop.
Plastic bag for paper (they can be found in different colors and thickness) and two sides adhesive duct tape. I
use the balck side of the plastic bag. I put the duct tape on plastic fim and cut it in stripes according to the thickness of the batten,
it can be made with a small margin, then I separate
protective paper from the strip and stick on the end of the batten, the allowances are cut off with the knife, - it's cutting off nicely.
Here are several photos, maybe they can be of use to somebody. If you have any questions - it would be my pleasure to help.
My best regards, Alexander.
- druxey, Keith Black, dvm27 and 6 others
- 9
- G.L., druxey, GrandpaPhil and 6 others
- 9
This is a great work with metal.
- Canute, popeye the sailor, Valeriy V and 1 other
- 4
Happy New Year.
Respectfully yours. Alexander.
- popeye the sailor, DORIS, EJ_L and 2 others
- 5
- Duanelaker, Baker, paulsutcliffe and 18 others
- 21
- DORIS, muratx, GrandpaPhil and 6 others
- 9
On 12/26/2018 at 5:42 PM, dvm27 said:
Yikes, thats a detail that was made for photoetching!
Yes, You are right, this is a good photoetching, this is the only way to make this decor element. I understand this. But having judged my skills, and the lack of necessary equipment and materials, I came to the conclusion that I wouldn't be able to make this element properly. That is why I opted for abberation from the original. Probably I shouldn't have done it and leave the door without stained-glass window. Probably I should have done it that way.
- Keith Black, michael mott, cog and 14 others
- 17
5 hours ago, amateur said:
Hi Kortes,
I guess you have seen the original bars on Sperwer?
that pattern is very distinctive, more than the rather basic pattern you have used.
Did you simplify on purpose?
5 hours ago, amateur said:Unfortunately, I couldn't think of any technology and make a
door bars at my scale indetical to the original. Due to this i decided to play some tricks. I have to confess it's a deliberate deviation.
I didn't have enough skill.
- DORIS, mtaylor, Keith Black and 1 other
- 4
SPERWER by KORTES - FINISHED - 1:30 scale - Friescheboeier Yacht
Scepter.
After solder, as usually, broaching file…
