Posts posted by John Allen
Please advise which bender is suitable for most jobs keeping in mind cost. Do not want to spend $ 100.00 when I can use a less expensive bender that will do most jobs. (I just butchered 2 hangers for the torpedo to the USS Picket Boat.)
Help an old man out whos getting long in the tooth.
John allen
- thibaultron, Jack12477, mtaylor and 1 other
- 4
Thanks for the response all.
- mtaylor, thibaultron and Canute
- 3
jaager-Johnny
thanks
- Canute, mtaylor and thibaultron
- 3
Appears I may be stuck with lead fittings with Mamoli CSS Aabama. Can they be properly treated other than primer or watered down white glue to slow down the degradation of the lead over the long run. Does this problem also plague Brittania metal fittings.
Would wood or brass copies when feasible be better. Could not find Metal for dummies #2 at Amazon.
- mtaylor and thibaultron
- 2
Recently purchased this kit from Steve at Cult man, Included was the PE, masking for the globes, and I ordered the light kit. Started build for my son-in-law. All ok until masking the plastic globes. Followed instructions in addition to checking U-Tube to cover all bases, masking was tedious to say the least. After masking in place washed with future to prevent paint bleed. Dry did procedure a second time. Applied gold acrylic for metal frames. Removed masking no paint bleed thru but masking left glue residue on clear plastic areas. Did not attempt to remove believe cannot be done without keeping the integrity of having clear globe.
Called Steve at Cult man explained the problem asked if replacement globes and masking could be provided (at no cost) he stated I would have to contact Pegasus.
Placed a 2 calls to Pegasus Admin. with my complaint and request, never addressed problem. Return call to Steve at cult man advising no response from Pegasus hoping he may assist noting he is a reseller no response.
I have no idea if the masking was defective, or old and lost its integrity or maybe I screwed up in application. But should have received a reply from at least Pegasus. emails from 9/16 to 9/23- 2 to Steve- 2 to Pegasus Admin.
Pics attached John Allen
On 8/11/2020 at 9:50 PM, mtaylor said:
I'm curious. Did you try the "reconstituted" paint?
Hello Mark,
Been out of the loop for a while. Sybile wife of 52 years passed May 8th. I am just be beginning to deal with it. Years ago she was an ACLS Paramedic and I a Marine Policeman. Little Bio Hurricane Frederick took out Dauphin Island Bridge. We went on calls together, her medicals my rescues. for a 3 year period. this was before life flight so transport times were between 2 to 3 hours depending on weather by boat and C.G. Training choppers if training in the area. We were tied to the hip, and as close as 2 people could be.
Apologize to all know this was not the area to post.
To the paints, I have reconstituted semi dried (the totally dried hard as a rock I did not attempt) they were soft enough to break down, added very little water and mixed with a drill bit on a Dremel. They seemed pretty thick (totally smooth no chunks or hard pieces.) even had to add a little water to thin. That being said I had used a couple of colors on the interior of the Hunley I am trying to destroy. They seem okay when dry, colors seemed as bright as a new bottle, whether they last who knows. Having shallow pockets I'm cheap. I do not have the skillset at this time to expend dollars on tube acrylics and mix colors I would and up with a model looking like a Rat Rod. So I'll muddle along until someone takes the word model out of acrylics and the price and packaging becomes reasonable.
- justsayrow, tarbrush, ccoyle and 1 other
- 4
Keith,
Caught up "magnificent".
- KeithAug, mtaylor, FriedClams and 1 other
- 4
Have many bottles of model shipway paints that have dried up. I have used a Dremel and bit to break the paint down add water and bring it back, this is a tedious process. Today I took a bottle of red that was totally dried up. Put a small amount of water in it and put in microwave for 10 seconds. It did not distort the shipway bottle which is a heavy plastic and paint softened enough to stir with a stir stick. That being said This may be a stupid idea, not knowing the chemical nature of the latex paint and or any residue left in microware.
Therefore moi being a dumb soul when it comes to chemistry and all the little molecules and atoms flying around what is the danger if any.
Keith,
Been out of the loop for sometime, caught up on your masterpiece. I appreciate your inquiring mind and always needing to know. Building backwards to go forward very cool.
- KeithAug and Keith Black
- 2
Trust me being up close and personal to numerous lawyers (of which most were the bloodsucking types) they would buy a cheap knockoff from China or Vietnam all the while screaming about Chinese imports.
- Canute, mtaylor, Roger Pellett and 2 others
- 5
13 minutes ago, Roger Pellett said:
BTW, if you PM me your deadeye bill of material I might be able to help you out.
Roger,
Thanks I should have made the post clearer. I was about to pull the trigger on the kit, since not being able to find one that was comparable. There is the Revell plastic and the Mamoli Alabama on eBay. Been mulling this over for a week but the cost vs material made me come to my senses. Post is to verify I made right decision. Thanks for the offer that's what is great about this site good folks willing to help each other
- lmagna, RichardG, Roger Pellett and 3 others
- 6
Please advise if I am being nitpicky. The price of the kit is $ 749.00 I am a little disappointed in several of the supplied materials considering the cost of the kit. Most of the fittings including cannons are brittania or a base metal for the money I feel that at least he cannons should be brass. The pre etched deck does not in my opion look as good as planking (personal choice that can be changed by the builder.
I ordered deadeyes at one point before I realized they were metal and had to be painted or browned. I would have thought for the money wood deadeyes on the caliber of Chucks should be supplied.
I know they have a great reputation as for as instructions support and replacing parts.
It just seems for the cost of that kit some parts should have been upgraded.
Am I being to critical, I bow to suggestions from the more experienced.
Me thinks one who chooses to post cornbread made round in a square tray is destined for greatness as a facilitator. What better way to take a position of baking round or square cornbread. Now all can get a jar of sorghum syrup and slather over the cornbread.
- Edwardkenway, bruce d, mtaylor and 1 other
- 4
Rob S,
Don't worry about the bumps in the planking tiles even though there extremely thin they will take a lot of sanding, also you will probably have half the bag left over so don't be chincy if you break one or sand too much you will have plenty left.
Also late to your log always read ahead with Mamoli instructions you'll find on page 6 you should have added to page 2 (example).
Looks Good
John Allen
LOU,
Looking good, light at the end of the tunnel.
By the way thanks for the life check instead of a knock on a neighbors door a phone call. No answer check obits, answer still kicking unless you get a recording then go back to the obits. Ain't technology grand.
Get the Huey done.
17 hours ago, JesseLee said:
Buddy refusing to be left out of the picture! Will put a few more up of completed ship later
Been a long road, flags are the cherry on the cake. Kudos on a wonderful build.
I couldn't put my little buddy next to any of my builds, he's a canine chain saw turn your back and you have toothpicks.
Looking forward to more pics.
Am impressed, one of the best in awhile. Attention to details excellent Kudos on a masterful build.
If you made her a little bigger could have added cotton bales, cattle and Minstrels playing at the dock that would have been a real hair puller, all kidding aside 1st class build.
Kieth,
Your metal work is almost supernatural kudos. I read somewhere about human osmosis. From what I read we need to meet do a fist bump and your skills will be transferred to me by human altering osmosis.
Bad thing is my ineptitude in certain aspects of modeling may be transferred to you.
Good thought bad idea.
Lou,
You old rascal you have been sandbagging. Thought you were old and senile and made excuses about your abilities or I should say infirmities.
First class job on painting the figures Kudos.
Am impressed with what you created, bears no resemblance to a base plastic kit. Wonderful job keep on. I agree on the cheaper acrylics I purchased some real cheapies Wal-Mart 2 ozs they go on great and still look good after a long period of time. I did a half model sailboat and tried their enamels also cheap as dirt, could not believe how well it turned out, never any brush marks either one.
I know a lot of these folks poo poo these paints to each their own. Myself being in the empty pocket bracket of society enjoy a deal.
Keep posting doing a great job.
- BobG, popeye the sailor and Fright
- 3
40 minutes ago, lmagna said:
My failing memory
Lou,
Could be my memory, its sharp as a tack from the 50s to 60s there's a disconnect from the 70s to late 90s memories during that time come in flashbacks ( I'll try to remember a specific and go blank. Can be in a dead sleep a day later than whammy it comes back) present day to day hour to hour is a crap-shoot.
- mtaylor, coxswain, Old Collingwood and 3 others
- 6
Photo Etch Bender
in Modeling tools and Workshop Equipment
Thanks all, bug it is
John
