Posts posted by shipmodel
Hi Mark -
Glad you got the warping problem under control.
Looking forward to seeing the solution.
Have you considered buying small photoetched cleats?
I know they are out there, but can't remember who makes them.
If they are painted brown, at that size I don't think anyone will be able to tell that they are not wood.
Just a thought.
Dan
Hi Mark -
Just read through the log.
You are making excellent progress and the results are inspiring.
Now I'm off to read the Sphinx log.
Thanks for giving me some happy hours of reading.
Dan
- Keith Black and mtaylor
- 2
Impressive research, Marc. Your thoughts are fascinating and your conclusions fully supported.
I always look forward to your next post.
If you ever collect and collate them into a book I will be one of the first on the purchase list.
Thanks for sharing.
Dan
- mtaylor, Bill Morrison, Keith Black and 5 others
- 7
- 1
Chris -
Just went through this build log and am truly impressed.
It is amazing how clean and crisp all your edges are and how you persevere in building all those tiny details.
PS - my vote is to spend for the 3-D printed hedgehogs and other fittings.
Sometimes it is better to beg forgiveness than to ask permission.
Flowers and a dinner at a good restaurant always eases those difficult conversations with my wife.
Be well
Dan
Just beautiful brass work, Keith. I am always envious of your work.
Can you set up a link directly to this build log in your signature, the way you did for Altair? My system is a bit clunky and I have to go to your profile before I can access this log.
Love following along, as always.
Dan
- druxey, mtaylor, FriedClams and 1 other
- 4
Marc -
I think that you have perfectly illustrated the many puzzles that we all have to solve to achieve a fully realized ship model. In your case you are even more limited by the basic structure of the kit. There is only so much kit-bashing that can be done, and you are doing it extremely well. I was worried that you would not be able to justify the various levels, heights, and angles of the headrails, but your solutions are elegant and beautiful.
Looking forward to seeing more great work.
Be well
Dan
Thank you Jim, Druxey -
Yes, I did consider casting, but my previous forays into those mysteries were less than perfect, and I did not think that these shapes, with the many undercuts, would lend themselves easily to the process.
Dan
- mtaylor, Keith Black and Jack12477
- 3
Hello again –
Thank you all for your well wishes on my health. I do seem to be recovering, slowly, on the long covid front. I can mostly sleep at night without coughing or sitting up, but it does come back with a vengeance from time to time. The silver lining to this cloud is that I can get more done during the insomniac periods. Hence, this post somewhat quickly after the last one.
As in most builds, especially with modern ships, I work on several sub-projects at the same time. While the superstructure was still being finished I turned to the containers on deck. In an earlier build of a container ship model for the museum, the El Faro (build log soon to be written), I had researched these ‘intermodal containers’. I found that ninety percent of the global container fleet are closed rectangular boxes, almost all 8 feet (2.44 m) wide, and of either 20 or 40 feet (6.10 or 12.19 m) standard length, and with a standard height of 8 feet 6 inches (2.59m) as defined by the International Organization for Standardization (ISO) regulation 668:2020.
The height and width of the containers on the Mayaguez seem to fit these dimensions in this photograph taken just after the recapture of the ship. You can also see that they are stacked in sets of three, and in two layers.
However, to my surprise, when I used Photoshop rulers and scaled out the length of the containers from the overhead shots, they measured out to only 35 feet long, a size that I had not encountered before.
Back to the books! After a good deal of reading I located a single sentence in “An Act of Piracy, The Seizure of the American-flag Merchant Ship Mayaguez in 1975” by Gerald Reminick. There he says that when Grace Line sold its Santa Eliana, ex-White Falcon, to Sea-Land Service in 1965 the ship was sent for a second conversion where the container cells on board were enlarged to accommodate the new 35 ft. containers. It was Sea-Land that changed her name to Mayaguez later that year.
Now that I had confirmation of the correct sizes, I had to determine the details of their structures. Modern containers have sides of pressed metal with the corrugations quite close together, like those in a cardboard box. Instead, the 1965 containers had smooth sides reinforced with square section battens spaced much further apart. In the detailed photographs of the Mayaguez containers only 16 of these battens can be counted. With the two ends there are 17 panels, so in 35 feet the battens must be close to 2 feet apart.
I tried a number of ways to create this look. I started with looking around for what was commercially available, but none of the Evergreen Plastics sheets were close. Neither their railroad car, passenger car or siding extrusions were close to what I needed. Then I tried making them myself, gluing 0.01” square strips to smooth plastic sheets at a spacing of 1/8”, but I could never keep the long strips straight. If I did it by eye, they wandered all over before the glue dried. If I held them against a metal or wood straightedge, then they got glued to the straightedge. This happened even when I used thin glue meant just for plastic, which melted the plastic, but the melted plastic then would attach again to the straightedge. I tried cutting narrow parallel channels with a thin blade in the Preac table saw, to be filled with thin strips, but the depths could not be cut consistently.
Ultimately I decided to compromise on the look a little in order to get it done. Evergreen has a product which represents a metal roof with batten supports (#4521). It comes as a sheet 0.04” thick with channels 0.015” deep set 3/16” apart. These channels are to be filled with thin strips 0.01” x 0.03” which are supplied with the sheet. Doing this is a tedious process, to say the least. Each strip had to be turned on edge and set into the start of the channel. It was tacked there with a small drop of Tamiya extra thin plastic glue (which is mostly acetone), which welds the strip to the sheet. Then the rest of the strip, still set upright, had to be fed into the length of the channel and glued there.
There was a distinct learning curve and a good bit of wastage of these expensive sheets before I got the hang of it. The final product looked very much like the photos of the container sides, although the spacing of the battens was 3’ rather than 2’ apart. As mentioned before – GEFGW.
With the strips in place the six pieces for each rectangular box had to be designed and cut. Each had to be sized to compensate for the thickness of the material so that the final assembled size was 0.50” x 0.53” x 2.19” (8’ x 8.5’ x 35’). I also had to compensate for the various edging strips that were added to make up the look of the corners of the boxes. Once all the calculations were done, the pieces for the sides were parted off the sheet on the Preac.
These ribbed side pieces then had to have edging around all four sides, made from strips 0.02” x 0.06”. The final piece is shown in the insert below.
The final components are shown below. These are the ones needed for a set of three containers. To minimize the number of ribbed pieces only the outside sides, ends and tops of the containers are ribbed. Where the side will not be seen it is not ribbed.
The first step to assemble each container was to set a side piece against a top piece using wood blocks to hold them perpendicular. Thin plastic glue was fed along the seam and held until it was hard.
Turning it over the matching ribs can be seen.
The second side is attached in a similar manner, but using a specially cut wood spacer to keep the sides parallel. I marked it in blue so I would not throw it out by mistake.
Each end was installed using the spacer block again to make sure it was vertical.
Finally the open box was turned over and laid on the base, which had been cut a bit oversize. When the glue was dry the excess was trimmed and the container complete.
To give some differentiation and interest to the containers they were randomly painted in three different metallic colors: dark steel, flat antique nickel, and titanium silver.
Placards with the Sea-Land logo and name were created in my computer and printed out onto thin acid-free paper. Two different styles for the larger side labels and small ones for the ends as seen in the photographs.
With the labels attached the containers were attached in sets of three to an underlying base plate and stacked on deck to judge how well they fit.
Here they all are, 8 stacks of 12 containers each.
Sitting here you can see the curve of the sheer of the deck. Without some levelling structures the cranes would not have been able to move them consistently. Those structures will be covered in the next installment.
Thank you all for following along and for your interest and comments.
Be well
Dan
Hello again to all –
Thanks for all the likes and comments. Keep them coming.
Sorry for the long delay since my last post. I have been fighting a long covid problem that gives me bronchitis which makes me cough, especially at night, so I am having a lot of trouble sleeping. Also I have had cataract surgery on both eyes, which has interfered with writing this blog.
But enough about me – back to the model.
At the end of the last segment I had completed the basic structure of the hull and was proceeding to work out the superstructure. This began, as with the rest of the model, with a careful examination of the photographs of the ship. Fortunately there were a few images of high resolution like this one of the entire ship.
Once enlarged I got a good, if a little fuzzy, picture of the 5 decks and deck houses of the superstructure. I was able to tease out some sense of the complex shapes of the various decks and overhangs. Porthole, door, and stairway locations can be seen, as well as the fact that the top deck house is taller than all the others.
In this slightly clearer image I could start the actual analysis of the dimensions and relationships of the shapes that can be seen. I started with the assumption that the original superstructure footprint had been retained, which is the lowest deck house with the curved fillets on either side. Then, when the hull was widened by 8 feet on each side, some changes were made. The supports for the lifeboat davits had to be built out and supported by pillars reaching to the outer edge of the deck. There is an overhang to the right of the lifeboat that extends to the new deck edge and is supported by three diagonal braces. The bridge wings had to be extended, and a number of other small details all had to be changed.
These images and analysis was integrated with the information from the overhead photos of the ship taken during the incident and rescue, such as this one from just after the recapture.
The image was enlarged and straightened out to give a top view that could be worked with. Always being aware that the image is not precisely taken from directly overhead, I could make out many more details, such as the stairways marked with the red arrows. Hours of staring at these images, individually and collectively, were needed to determine what the various elements and details were. I am still not 100% sure of all of them, and even where I am sure of the shape of things, I am not sure of their purpose. But since this is for the US Merchant Marine Academy, it is good enough for government work.
Other images which were not full pictures of the decks and deck houses also informed a number of details of railings, stairways, overhangs, supports, etc. Here, for example, is one of the Marines taking control of the ship. I would not have seen the tall ventilator/filter under the stairs at the side of the bridge except for this picture.
So, taking all the information in hand, I laid out the shape of the lowest deck house over the top image.
Using this as my basic starting point I laid on the shapes of the stairway platforms and lifeboat davit supports to the first level. Then using the relationships seen in the photos, I drew on the shapes of the second and third decks, deck houses, and overhangs in contrasting colors, giving this image.
Based on these drawings I cut ½” planks of basswood to the shapes of the deck houses (less 0.04” all around) and sheathed them with 0.02” styrene (restoring the full sizes). The decks were cut to the full size of the deck houses and painted grey before being edged with styrene. This gave a pleasing delineation to the decks, which can be seen in the photos. The edges extended just a bit above the deck level, making a lip that anchored the photoetched railings when they were added later. Portholes are the brass dollhouse electric circuit pieces, while the handrails are 0.015” round rod. Here the superstructure stack is about half done, with all the upper details still to be done.
Here is an enlarged shot of some of the details. Notice the diagonal supports for the overhangs of the second deck and bridge wing. The railings and stairways are photoetched brass from Gold Medal Models’ ocean liner set. It is expensive, but makes for a very convincing impression when painted, folded and installed.
The railings come in long frets four scale feet tall (1/4”) with horizontal rails numbering from one to five to be used as needed. The photos of the ship show that the railings mostly have three rails, so these were the frets that were used. They were spray painted gloss white before being cut apart. Unfortunately the paint was a bit brittle, so it chipped off when bent, as can be seen in the last photo, but that was easily touched up later.
The stairways come as part of a larger fret with hooks, steering wheels, etc. They have a central length of steps flanked by angled wings for the side railings. They come in three different lengths. Mostly the middle length was used, but occasionally the short or long ones were needed for a particular location. Small adjustments to length were made by trimming the bottom of the stairways.
The basic stairway is made by bending up the wings of the piece to form the railings at either side of the steps (left image). But this is meant for use on the ocean liners, so it is wider and less steep than the stairways on merchant ships. To make them steeper the railings are pressed down towards the steps till the supporting posts are vertical when the stairs are at the steeper angle (middle image). Where the stairs had to be narrow, one side railing and some of the width of the steps was cut off and the stairs supported by an added strip of styrene (right image).
Work continued on the superstructure with detail added as they were identified in the photos. Note the cross supports between the lower and upper bridge wings and the fact that the front facing of the upper bride wing is taller at the bridge house than it is at the outer end. The funnel has now been sheathed and is set in place so I could determine the location and size of the many details on the upper decks.
While this analysis and work on the superstructure continued I was also starting to puzzle out the size and shape of the 96 containers that had to be installed on deck, and how to build them in a reasonably efficient manner. This will be the topic of the next segment.
Till then, may your health be better than mine.
Dan
Hi to all my friends who are following my logs.
I am starting another one - scratch building an ocean diorama of the 1975 incident when the SS Mayaguez was siezed by armed gunboats from the communist Khymer Rouge government of Cambodia (which they named Kampuchea).
The model was honored with the Jim Roberts' Craftsmanship Award at the Northeast Joint Clubs conference last April.
To follow along, just click on the underlined text in my profile for my 'Current Build'.
I will try to make it, hopefully, as entertaining and informative as this one.
Be well
Dan
- Cathead, Ekis, Keith Black and 3 others
- 6
Hi all -
Thanks for joining me. I'll try to keep it interesting.
Keith - it will be more than one post, but not a full, extensively detailed, build log.
I was working to a bit of a deadline and did not stop to take photos of every day's progress.
I will show the construction process for many of the more unusual details, but the general construction follows my usual methods shown in other build logs.
Druxey - I use plaster of Paris because I am familiar with it. It mixes easily, spreads thinly, and dries to a stiff, hard surface that can still be easily sanded to smooth surfaces with sharp corners and edges. With a final coating of Minwax Wood Hardener it takes on a great deal of strength that stands up to the occasional clumsy ding without a major dent. I am not familiar with gesso, and don't know its properties. It may well be as good or better, but this is the Devil I know.
Thanks for your interest.
Dan
Hi guys -
Thanks for joining me here. Yes, this was an interesting subject, if not for the ship herself, but for the historic event.
As for the ladders and stairways, these will be covered in detail in upcoming installments.
Dan
- druxey, Jack12477, GrandpaPhil and 3 others
- 6
SS Mayaguez (c. 1975), scale 1:192 by Dan Pariser
Hi to everyone who followed me from the build log of the restoration of the bone and ivory POW model to this one, and hello to any modeler who might be interested in a completely different subject using completely different materials. I hope that I can make this build log as informative as the last one.
The subject here is the SS Mayaguez, an American container ship that was involved in a famous incident of piracy at sea. On May 12, 1975, about a week after the fall of Saigon, and a month after the fall of Cambodia (renamed Kampuchea) to the communist Khmer Rouge, Mayaguez was en route from Hong Kong on what was to be a routine voyage. Travelling through a disputed area, the ship was accosted by a gunboat flying a red flag which fired machine guns and a rocket over the bow. The ship stopped and was taken over by Kampuchean sailors. The crew were captured and removed from the ship. Upon learning of this, American planes were scrambled from nearby bases and photographs of the ship and gunboats were taken as hurried plans were made to recapture the ship and free the crew.
SS Mayaguez was launched in April 1944 as SS White Falcon, a Maritime Commission C2-S-AJ1 freighter built in North Carolina. Type C2 ships were all-purpose cargo ships with five holds, but were remarkable for their versatility, speed and fuel economy. U.S. shipyards built 328 of them from 1939 to 1945 similar to this one shown in wartime camouflage.
After her service in World War II the ship was sold to Grace Line and carried coffee from South America. In 1960 she was converted into one of the first all-container ships, with a capacity of 382 boxes below deck plus 96 on deck.
To do this she was lengthened from 459 feet to 504 by adding a midships section and widened from 63 feet to 74 by adding oddly shaped and angled sponsons on each side.
To support and level the containers on deck above the curved sheer of the hull, structures similar to railroad trestles were built. Because few ports at the time had equipment built to handle containers the ship was also fitted with two rolling cranes, one forward of the superstructure and one aft, riding on rails mounted on those levelling trestles.
The cranes had wings that could hinge up to shuttle the containers out and over the docks and onto or off of waiting trucks or trains. In this photo the wings are up and extended, while they are down in the prior one. Notice that these are extended even though they are over the water side. I suppose that this was done to help balance the ship during loading operations.
In 1964 the ship was sold to the container line Sea-Land Service and renamed SS Mayaguez after the city in Puerto Rico. In 1967 she began regular container service in support of US combat forces in Vietnam and Southeast Asia. After the US withdrawal in 1973 the Mayaguez began sailing a commercial route between Hong Kong, Thailand and Singapore. It was on one of those runs that she was captured.
I was recently asked to build a waterline model on an ocean base commemorating the event for the U.S. Merchant Marine Academy museum in their preferred scale of 1/16” = 1’, or 1:192. As usual, I scoured the internet for plans and images of the ship so my model could be as accurate as possible. Unfortunately, I could not find any plans of the ship available from after its conversion to work from. I even contacted Sea-Land, without success, so the project became mostly an exercise in photo interpretation.
I found many images, most of which were of only moderate resolution, but all of which gave me some information or viewpoint that let me develop the details. I did locate a plan of a generic C2 cargo ship which gave me the general outline of the original ship.
I then located two photos taken by the US Air Force during and just after the incident that were of high resolution and taken from almost exactly overhead on the centerline. These gave me the outline of the expanded deck which could be combined with the C2 plan and photos of the sponsons to give me a good idea of the final shape of the hull.
Armed with this information I could lay out the lifts that I would need to build the hull. I first used Photoshop to resize both the C2 plans and the overhead photos to match the overall dimensions of the model (504 feet x 12 / 192 = 31.5 inches). On the C2 plans I marked out ½” lifts from below the waterline to the beginning of the upward curve of the sheer of the ship. A 5/8” tapered wedge at the bow and a similar 3/8” wedge at the stern gave me the basic curve of the deck.
½” basswood sheets were cut for the lower lifts according to the plans, then attached with wood glue colored black with acrylic paint. This gave me indelible horizontal guides to guide the shaping process, especially the waterline. Here the bow has been assembled and the 5/8” sheer wedge has been planed to shape and attached. The wedge was sanded to a smooth shallow curve and the 1/8” deck piece was cut a bit oversize to allow for adjustment, then secured.
At the stern the same process was used, just with a flatter wedge. The raised fore and stern castles were cut to shape from the photo and attached, fairing them to the lower hull.
The hardest part of the hull construction was to fashion the sponsons, which had to match the overhang of the deck piece, fit snugly against the curves of the original C2 hull, and match the shapes seen in the photos of the sides of the hull. They were built up in several pieces, being pinned to the hull temporarily with wooden dowels during shaping. Several attempts had to be made to get everything to fit, and even here in this photo of my third stern sponson there were problems (notice how the bottom edge of the aft piece is curved and not straight) and the piece was discarded.
Eventually I learned from my mistakes and the sponsons took on the shapes that I wanted. Once that was done the entire hull got a thin coating of plaster of paris to seal the wood and fill the larger joints.
This layer was mostly sanded off to give me a smooth surface for the first of half a dozen primer coats. These were individually sanded as well until any small defects were filled and smooth. The hull then got a color coat of rust resistant red paint below the waterline and a navy blue coat above, as seen in the few color photos. The deck was also filled and sanded, but left with just the primer coat.
While this was going on I was also fiddling with the layout and construction of the superstructure. That will be the subject of the next installment.
Until then, be well.
Dan
- Keith Black, druxey, FlyingFish and 16 others
- 18
- 1
Hi Marc -
I know I'm coming in late to this discussion, and I agree with you all.
But it seems to me from looking at the photos that you could fairly easily raise the steeve of the bowsprit.
Cut off the angled support under the bowsprit close to the deck.
Replace or adjust the cutoff piece with one that will give you the steeve that you want.
Pin it in place with brass if necessary for strength.
Redrill the hole for the heel of the bowsprit.
Fill and paint and the joints should disappear.
Or there could be a problem that I am not seeing.
Dan
- Keith Black, mtaylor, Bill Morrison and 3 others
- 6
Hi Marc -
Beautiful work, and I appreciate how committed you are to the precise fit of all your interlocking pieces.
I agree with Kevin that any slight discrepancies will be impossible to notice in the finished model.
That said, I also agree with Druxey that the windows as drawn look a little off.
But I do not think that it is windows 2 and 5, but the outer ones, 1 and 6, which are a bit too wide and the mullions are a bit too upright.
I am sure the finished ones will match perfectly, as usual.
Great work.
Dan
Keith -
I double all the compliments and accolades.
Top of the tree for imagination and execution.
As for the final resting place of the model, it certainly deserves to be in a museum.
I hope there is one which would value her.
Bravo !
Dan
- druxey, FriedClams, michael mott and 3 others
- 6
Hi Marc -
Beautiful work as always.
Thanks for the mini-tutorial on converting plastic to wood.
I have saved it to my toolbox and will rely on it as needed.
Best wishes to you and your father in his circumstances.
And Happy Holidays to all.
Dan
Good point. I had not measured the drawing.
I think your decision is a good one.
Stay safe and well
Dan
Hi Greg -
The new tops look good, as do all your masts and spars. They should compliment your hull and fittings very nicely.
As for the tops as drawn, I do not know of a contemporary model with such tops, but Captain Bligh's notes on the conversion of the Bethia to the HMS Bounty indicates that he had her fitted with 'gratten' tops, which I took to mean 'gratings'. I suppose that this was to readily shed water in the rainy South Pacific where he was headed. I have seen some modern models with such tops, and some look quite nice.
As the man said, "You pays yer money and you makes yer choice. . ."
Stay safe and well.
Dan
Hi Chuck -
Beautiful craftsmanship, as always. All the joints are so clean and tight, which is really impressive.
Though I do not plan to build a kit, I have read pretty much every instruction manual, article and book, and wrote a few with Jim Roberts.
I have to say that your explanations and instructions are up there with the best. They are as clean and tight as your woodwork.
Following along in my head I take it a sentence or two at a time and I can actually see the model rising from the building board.
Every one building the model is extremely lucky to have you take them through a master class in the arts of the shipwright.
Two small suggestions, if I may - -
First, it might be a bit easier for the modelers if you gave them the knee of the cathead along with cathead. The slant of its top will establish the angle of the cathead relative to the hull. This then determines the way the bottom of the notch rises from inboard to outboard.
Second, you suggest a really sharp chisel for the cuts. I think many of your followers would appreciate a quick lesson in sharpening chisels. I don't know, myself, I just pull out a fresh hobby blade. It is a skill that I should add to my toolbox.
Keep on with the good work.
Stay safe and well
Dan
- WalrusGuy, FrankWouts, bdgiantman2 and 4 others
- 7
Really nice work, Roger.
I love the idea of giving the viewer a glimpse of some of the internal details.
It should be interesting to see who notices and who does not.
Hopefully you will bring the completed ship to the next NRG conference, whenever it is.
Looking forward to seeing her in all her glory.
Be well
Dan
Truly excellent results. Congratulations.
I am a little old to work my way up the learning curve, but I am blown away by what can be accomplished.
I wonder what may be around the next technological curve.
I just hope that we will never get to the point of duplicating a fine old wooden model of the Constitution with the push of a button,
If you continue as you are going, this will be an amazing model of the Maine.
Looking forward to following your progress,.
Dan
Hi HG -
Those small guns moved around a lot. You can put them in several places. It's your choice as Captain.
As just an idea, I chose to mount gatling guns near the base of the boat cranes.
Here are some images that I relied on, although you probably already have them, and the final result.
I hope that helps a little
Dan
The design of the gun
The gatling mounted on a ship's rail
The gun on the finished model
- GrandpaPhil, lmagna, Egilman and 2 others
- 5
Hi again -
I forgot to add my two cents to the discussion of the big gun tactics for the Maine -
She was the first "ship of the line" the United States designed after the Civil War, almost 30 years earlier.
(The USS Texas was designed later but launched earlier) However, it is not a line of battle if there is only one ship in it.
The design of the ship changed radically over several years as the ideas for its proposed use evolved.
The final design of the Maine, with its two turrets overhanging the beam of the ship, reflect the final tactical doctrine.
If the Maine ever came up against an enemy line of battle, the plan was for her to turn towards the largest of the enemy ships.
All four turret guns would fire forwards, ignoring any self-inflicted damage, until the Maine could ram the enemy with her reinforced bow.
Fortunately, she was never called on to do so.
Here is what the enemy might have seen.
- Haze Gray, lmagna, GrandpaPhil and 5 others
- 8
Armed Virginia Sloop by CiscoH - Model Shipways - 1:48
Hi Cisco -
Just read through your build log here. You are doing great, working your way up the steep and long learning curve of hull planking. I love how you meet and solve the many problems and challenges that you have encountered. Your creative solutions will stand you in good stead as you approach the second layer of planking.
Here are a couple of tips that I have learned by hard experience over 35 years of doing this:
1. Fill and sand the first layer of planking till the shape is smooth and to your liking. Paint the whole thing with a light colored water based paint. Now you can draw the plank outlines on the hull in pencil, using dividers or tick strips to give you your initial layout. Look it over critically and change the run of the planks by erasing and redrawing until you are happy. Drop planks at the bow and stealers at the stern are much easier to figure out in pencil before you start cutting wood. Then you can cut and taper your planks to match the pencil lines.
2. Lay in the location of the wale first. This will determine the bulwark planking strakes above and the hull area to be planked below. Plank down from the wale and up from the garboard, as you did before. The final opening will be closed with a 'shutter plank'. When you get to that point, lay on a piece, or pieces, of translucent tape covering the opening. Draw the outline of the shutter plank on the tape, then transfer the tape to a wider piece of planking material and cut to the line. This should quickly get you very close to the final shape that you need.
3. For the garboard, lay the lower edge of the wider planking material (1.5 times the width of the hull planks) against the keel rabbet and slide it forward until the front end begins to lift as the rabbet curves up the stem. Pull it back just to that point and temporarily tape it in place. This has been suggested before. But now take a second plank (known as the first broad strake), place it on the hull above the garboard piece, and slide it forward until its lower forward corner contacts the stem rabbet. Mark this point. This is how high the garboard should come on the stem. Cut the bow end of the garboard strake to fit the open curved triangle that has been marked out. Now the lower edge of the broad strake will be straight, and you can work off it up the stem.
I hope that helps a bit. Feel free to ignore it if not.
Best of success.
Dan
