cog
Everything posted by cog
  1. sorry to hear that OC. You can open a paypal on a debit card though ...
  2. have to stay my expenditures for a month ... so I'll be waiting for next month before I can order the PE ... at least I can see your troublesome progress ...
  3. that's very bad luck my friend. it is also the reason buying through the internet will always be a risk. for me it's the reason to buy through paypal.
  4. i would put them inline with the outer propellor shafts, but having seen this from the sms koning - same class - I have to revise my view. It looks like the rudders are in between the longitudinal axis of the props, and some way aft of them. have a look here
  5. He just finished a card tank in less than no time, Greg ... I too wonder what's next, but then after his current build ...
  6. How many rudders, 2 .. 3 I would expect the rudders' positions would be in line with axle/shaft of the respective propellors, or the number of rudders is less than the number of props ... P.s. I tend to forget picies too, but then I edit the post so it doesn't show
  7. Why don't you apply the CA to the part, or on the spoit where you will place the part?
  8. Major improvements, whom ever said plastic builds arre boring ...
  9. Thanks for the likes and the support gents did I ever, OC ... My sentiments exactly LH Although you never know on what track you are ... Lou, haven't found any bonsai crew as yet, so I'll leave them as is for the time being ... most figures at 1/350 come in PE and are very flat ... not much real sailor body Actually, these oerlikons are far better to deal with than the tripple AA's from Musashi, those really give me a bleamin' headache.
  10. XXXL, XXL, XL, L, M, S, ........ what shall I say ... not to big would do I reccon ... 8 parts 20 mm Oerlikon cannons, need another four to complement the type for this build ...
  11. I either apply the glue to the PE, or to the plastic before I attach the item ... if ever I do apply glue when the part is positioned, I press it against the underground with tweezers and use a very thin drill to apply the CA, something like a 0.5mm (broken) drill
  12. The more often you work with these little parts the easier it becomes, Jack. Looking good for a first time P&PE ship
  13. Yes you should ... make an end to it ... that is: the build of Vendetta. How can I be disappointed when we get our value worth of build logS entertainment from you ... Insanity ... you could put it that way ... creative is another, or psyco ... ... you don't look fat ... at least ... no fatter than usual which is a thick as a web page can be
  14. I had some problems when using Tamiya "acrilycs" and Vallejo on top of one another, I used that for the camouflage on a Fokker Dr.1 However, I didn't have problems with Vallejo and other brands, especially after lettinmg it cure for a day as you do
  15. Thanks Denis, I like the colour scheme too, should have done it on Vendetta as you did. The demon ... hmmm, yes, there are still quite a few of us struggling with that one ... I don't dream of it, it gives me nightmares , although, only when I consider it which is rarely :) From what I saw, you do not really have the time to dream ... to many interesting builds ... hard to keep up with you mate
  16. Like the way your planking turned out. Will you paint or lacquer the hull?
  17. J-P nice work on hull, deck and masts, glad you don't have a 200 pages buildlog!
  18. tu haces mi día .. (a very litteral translation)
  19. it's so ... tidy, Sam ... goodness gracious ... your progress is rather good if not great, despite the hours ... I start to relate to you ... work wise that is, at modelling you are still far above me
