Posts posted by WalrusGuy
Hi Werner, the headrails look fantastic! This is probably the most trickiest part of the build.
Thanks so much, Tom, Kurt, and David!!
I finished up with the windows! A very tedious task... but I did become quicker in assembling them towards the end.
I tested the micro crystal clear solution for the windows but I wasn't too big of a fan of the frosted window look. So I opted to use the acetate instead. I placed each window frame on the sheet, ran a #11 blade on the outside edges of the frame, lightly marking the acetate. Then I used a metal ruler as a guide to run the blade multiple times until it went through. Finally, I used the micro clear solution as a glue for the frames on the acetate. Here are some photos with the windows+frame dry-fitted in the openings:
Thank you so much for the kind words and the 'likes'😄
I have been slowly working through the window frames. I finished the portside frames.
For the angles windows, I used the kit supplied ones as a guide. Here, I glued the two outer strips and used the kit frames to get the right angle by letting the glue set as the strips rest on the edges of the kit piece.. After letting the glue set and doing the same on the opposite corner, the 2 'L' shaped pieces were then glued together, followed by all the internal strips:
Here are a few photos of how it looks on the ship (only dry-fitted for now):
I got to say, all this is really really fiddly work. Getting the notches in the correct spots on each strip is very tricky. Had to discard twice as many as those that made the final round!
Thank you, Werner. Thanks all for the likes as well 😊
A bit of a shorter update. I was not very happy with the kit supplied window frames. They did not fit well on model for some reason. I am not sure why as I did check their fit during the initial framing stage of the build. Also, they had some notches on the sides (not sure why it has these).So decided to try building my own ones. While working on them, I did think I may have taken on more than I can chew...
However, I thought it would be best to take some time off and think about this problem for a bit and tackle it more systematically. So, first I made a simple jig for my mini planer to glide on the rails to thin down some larger pieces of Alaskan yellow cedar I had laying around:
Using this jig, I was able to create relatively square strips (around 0.5mm x 0.5mm):
Next, I used the kit supplied frame as a reference to notch out sections of strips, then glued them together to make the entire frame assembly.
Below is just a test piece I made to make sure the method I used can work. The strips are not parallel since I did not pay much attention to the notch placements. The second iteration will be more carefully done to ensure it is better aligned.
And here it is on the ship:
I will use this test piece to try out the Micro Krystal Klear solution as well.
So next I will redo the frame for better alignment. But I am sure the angled windows will definitely be more challenging....
Hi Werner, your build is gorgeous, everything's so neat and tidy. Very inspirational!
Harshil
The checkerboard pattern is now glued to the false deck 😬
Fingers crossed I don't mess it up during the build. I'll try to be as careful as I can. Also, I hope the stick glue I used to bond the card stock onto the thin basswood sheet would hold up over the years. So far it seems good, but let's see....
Anyways, below are some photos. I guess this marks the completion of Chapter 10!
For the next step, I am thinking to backtrack to finish up the stern. Hoping I can get better at the carvings this time around!
Harshil
20 hours ago, wernerweiss said:
Hello Harshil,
Congratulations on this progress, excellent work as always!
Yes, you have to be very careful not to spoil the great cabin' s deck with its pattern.....but so it is with the much bigger area of the gun deck, the basswood is very soft and does not forgive tools falling on it, but, as modelers we ARE careful..
I am going to update my Confederacy build log soon showing the progress of the forecastle deck and the bow stem
Greetings
Werner
Thank you, Werner. After correspondence with Chuck, I think the best option would be to glue in the pattern section, then covering it with paper to protect it until its time to install the guns.
Looking forward to seeing your update post 😁.
Thanks again for the nice words and thanks all for the likes!
Harshil
It's been a while since my last update! I finished treenailing the deck, installing the waterway, and have stained everything with tung oil. I shaped the waterway to be in a convex shape using a planer and sanding sticks. I have not yet glued any of the deck fittings in case they come in the way when installing the ladder etc.
Here are some photos of where the model is at currently:
The next step would be to paint the margin plank + waterway in the great cabin white before gluing the checkerboard pattern. In the meantime, I will also continue thinking of different options for the checkerboard pattern as I am not too confident that I can keep the printed card stock pristine throughout the whole build...
Thank you Steven, David, and Rick! Your comments are much appreciated
I think using thinner planks should be doable, but some adjustments should be made for the wales, and decking (since the gunports would be slightly higher from the deck level with thinner planks).
But curious to hear what @Chuck thinks.
Harshil
Thank you all for the likes!!
Decking is now completed 😁
There are some mistakes with symmetry, especially for the edge planks. That made me realize, it would be best to plan ahead of time and mark the plank locations (similar to the hull). I also had to redo the aft planks as I realized I did not follow the same pattern as the forward part of the ship. But glad I found that before it was too late!
Before I forget to mention, I spot glued this plank to make sure the decking would be flush with the great cabin
And here are some photos of this stage completed.
Next is the treenails, waterway, and then lastly finishing with tung oil.
- Jorge_Goncalves, scrubbyj427, ccoyle and 13 others
15
1
A quick update on the decking. Managed to get some hook scarfs at the bow.
For this, I used a planer for the long end, and an X-acto blade at the forward-end of the plank where the planer could not reach. Then carefully peeled of 0.1mm slices until the plank was completely flat. I checked the end result against a normal plank facing a source of light to make sure no light seeps in any potential gap. In some cases where light did seep in, I used sandpaper glued to the edge of a flat piece of wood and lightly sanded it straight.
Harshil
No worries Werner. I'll be sure to be very careful when the tiles are glued to the false deck. I plan to glue it once I finish with the treenails and apply the finish to the deck.
1 hour ago, wernerweiss said:
Hello Harshil,
once again, very clean work!
Yes, one has to be very careful once the cabin floor is finished, and later on there are two cannons and possibly furniture to be positioned and glued.....
Did you print the pattern directly on the card? I printed it on self-adhesive paper (is this what you mean with label paper?)
Werner
Thank you, Werner!
Yes, printed directly on card stock and glued to to a thin sheet of wood. And yes, I did mean the self-adhesive paper. Is the surface of the self-adhesive paper similar to normal paper?
Harshil
Thank you, Bob!
Currently working on the decking. Here are some few progress photos 😊:
Also, I was thinking of exploring more ideas for the checkerboard pattern. I am worried that any small mishaps or stains (like glue seepage or paint droplets) on the printed cardstock may be hard to remove since it is very porous just like paper. Might test out label paper..
Harshil
- VTHokiEE, wernerweiss, Knocklouder and 16 others
15
4
13 hours ago, wernerweiss said:
Hello Harshil,
wonderful work with an amazing result - highly recommended for imitation!
With this attention to detail I look forward to your finished model!
I must admit that I was too lazy to paint the bricks in different shades.....
It is a pity that most of the brick surface is later on covered by the stove.
Thank you for the kind words!! Yes I am a bit sad that most of the work will be hidden..
- wernerweiss and abelson
2
On 11/21/2022 at 4:27 PM, wernerweiss said:
Hello Harshil,
regarding the gluing of the hatch coamings and the brick platform on the false deck I would highly recommend not to follow the instructions and plank the gun deck first.
This makes it much easier to sand the gun deck all over its length because then there are no obstacles for your sanding tool....but maybe you already thought about it.
Hi Werner, nothing is glued to the deck as I was constantly thinking about things getting in the way when it is time to sand everything smooth. But thanks for the reminder!
Also thanks a lot for the tip on painting the bricks. It worked out for me. I did however add a few more steps in the process.
I first painted the entire section grey, then painted each "brick" with different shades of red and brown (by mixing the below paints in different variations). Some of this paint did seep into the grooves.
After the paint dried, I painted everything again with thinned grey paint making sure the grooves took all the paint in. The last step was to wipe out the grey paint quickly with a kitchen paper towel. For this I placed the towel on the bench and then applied even pressure on the platform onto the paper towel making sure all the surface paint was wiped off. Here is the end result:
Also, from the above photos, I ended up painting the coamings black. I really liked the look of the black against the deck in contemporary models and many Winchelsea builds and I wanted a similar look.
As usual, any constructive criticism, recommendations, or tips are more than welcome!
Harshil
- BobG, Paul Le Wol, Prowler901 and 12 others
12
3
7 hours ago, wernerweiss said:
Hello Harshil,
again, very clean woodwork...did you use the provided basswood or another kind of wood, e.g. beech?
I cast the "bricks" with moulding cement and cut/sanded it to shape to fit in the wooden frame. Then I painted it red to resemble "brick". Afterwards I painted it all over with grey (not too thick) to fill the grooves and immediately dabbed the grey paint off the "brick" surfaces leaving a rest of grey paint....I think this method should also work on your wooden "bricks"
(As the height of the cast didn´t match the height of the frame, I glued the cast on a piece of thick card)
Werner
Thanks, Werner. I'll do some testing on some scrap bricks with your method to see if it works on wood.
I used the supplied basswood for the simulated brick pattern.
12 hours ago, wernerweiss said:
Hello Harshil,
Very fine and clean woodwork.....wish these coamings were on my model 😃
For my taste, I would not paint them black, too much contrast to the companionways if you intend to paint them in "oak".....but that is of course up to you...
Werner
Hi Werner,
Thank you for the compliments!! From my eyes I see the black going well with the wales, but I can see how the contrast may be too much. I'll ponder over it some more.
7 hours ago, wernerweiss said:Hello Harshil,
some remarks on the brick platform for the stove.
In the building instructions it is made of provided wood strips which are grooved, glued together and painted to resemble bricks.....I didn´t like that at all and looked for an alternative. I found a silicone casting mould for brick walls for rail modelling. The "bricks" cover an area of 72 x 49 mm and imo meet the size, so I made a cast and was content with the result. The rest was cutting to length and width, painting red and "washing" with grey.....
The bricks look so lifelike! Especially for the scale we are working with, this is amazing. What material did you use? And how were you able to create the texture on each brick? Thank you for sharing 😊
I followed the instructions and this is what I was able to accomplish:
Here are the tools used for the individual strips:
- X-acto knife for scoring
- Saw blade for a deeper cut
- Tip end of the needle file to make the grove
- Planer to create a 45 deg chamfer on the edges
- Retired guy, Gahm, abelson and 6 others
9
I forgot to mention in my last post, I made some modifications to the build stand so that the ship is more stable when working on her. It's not the prettiest but works great 😁
I also ended up painting the cap rail at the stern black as the different shades of basswood was still bothering me. Before, I felt like it would be too plain with all black. But after painting it, I like this look much more.
Lastly, I started working on the hatch coamings and gratings. The corners were cut to 45 deg with a sharp blade (just to where the deck would be) and then rounded with sandpaper and files. The top edges were chamfered to 45 deg with the plane, then rounded with sandpaper.
Here are a few photos of where I am currently at (nothing is glued on the false deck):
I am thinking of painting the coamings black after seeing Chuck's Winchelsea, but I will think about it for a couple more days while I work on the bricked platform.
Harshil
- abelson, CiscoH, Paul Le Wol and 7 others
10
Hi Werner, she's looking really beautiful. Do you plan to rig her?
On 11/14/2022 at 3:33 AM, captain_hook said:
Looking forward to see your progress. She looks beautiful. Are you going to build some Interieur for the cabin? My Badger is placed aside as I‘m busy with the Coureur but I hope to build up her cabin as well when I resume the build next year. But I fear that there won‘t be enough light coming trough the tiny windows to see anything of the Interieur later.
Thank you for the kind words! Hmm I haven't given much thought about the cabin furniture. Right now I'm leaning on leaving it plain but let's see if I change my mind 😁
On 11/13/2022 at 5:24 PM, wernerweiss said:
Hello Hershil,
thank you for following my suggestion for the chessboard floor pattern. But check the forward edge of the template....it runs along the aft bulkhead, and the aft bulkhead must not sit too close to the hole for the speaking tube to allow enough distance for the deck coat at its base.
I look forward to the progress of your model, and in the next days I´m going to upload the next pictures of my model which were taken just yesterday....
Strange that you had problems with the margin planks.....
Greetings
Werner
Thanks for the tip, Werner. I'll trim the aft end of the tiles a bit so that the hole has more space.
On 11/14/2022 at 2:31 AM, datadiscovery said:Good to see you back at it, Hershil. I look forward to following your progress and you completing this beautiful model.
Pete
Hi Pete, it's good to be back! It'll take a few more days for me to get back to the groove so I'm trying not to rush things.
17 hours ago, wernerweiss said:Hello at all,
meanwhile I got the answer to my problem. I learned that the reason why pictures which appear upside down when posted is that these pictures were taken with the smartphone held upside down.....it is a matter of the rotation data.
But what I also learned in this context is that in another forum in which I am registered all pictures are uploaded and posted unrotated.........
The solution for my problem I finally found in this post here in the forum:
My solution to this is uploading a screenshot of the image. That seems to work fine so far, but glad you found another solution!
Harshil
I am back to model building, and have made a bit more progress. I planned to continue working on the quarter gallery and carvings, but after some failed attempts, I decided to start on the decking to get my feet wet again before diving into the deep end!
The margin planks are now glued in place. I decided to scratch build some of the pieces as there were 1 mm gaps in the scarph joint when using the supplied ones as shown below.
Here are a few photos of scratch-building the planks:
Some more photos the margin planks installed:
I was inspired by @wernerweiss's build to have a black and white checkboard pattern instead of the wooden one as the instructions suggest. I used a card template for the overall shape before printing out the pattern on card stock and gluing it on a 1/32" sheet:
Here, the checkboard pattern is not glued to the false deck. It will be permanently glued once all the decking is done and sanded to avoid any mishaps on the card stock.
On 10/2/2022 at 9:38 PM, datadiscovery said:
Did you ever finish your Confederacy? If so, I'd sure like to see some pics. Thanks.
Pete
Hi Pete! I took a pause from modeling for a few months so the build did not see any progress for a bit. I plan to resume the project in the coming days. Stay tuned!
On 10/8/2022 at 7:00 AM, captain_hook said:Nice progress and clean work. Did you use the supplied basswood for planking?
Thank you! Yes, I used the supplied basswood for all planking and moulding.
USF Confederacy 1778 by WalrusGuy - Model Shipways - 1:64
Thank you so much for the kind words! I’ve taken a pause on the build but hoping to get back in the coming months.
