Mirabell61
Everything posted by Mirabell61
  1. Build log part 39 chain plates (here in the Moment only those for 5mm deadeyes) on closed, planked starboard side port side foremast chainplates, as far as the planking is in place the complete chain is fitted, in the area of the cutaway portions, I use one of the stringers together with length-dressed chain plates and leaving away the the lower cap plate. The boltings are placed at half width of the stringer Mainmast chainplates, I trust it is a solution that does not look too much out of the way after all thealignment angles can be set just like on the planked starboard side Nils
  2. congrats Hans, a good looking and nicely built ship... Nils
  3. nice axilliary-tool Tom, I like that solution for clean sanding Frame contours, and its easy to set up...., and the edge is perpindicular to the base board. Nils
  4. Thanks for your "strops into the channels..." solution Jason, I`m afraid that that Version would put to much tension on the channels from above, as the channels should actualy only spread the shroud- and backstay chords outwards. A unpurposed knock on the masts during handling could rip off the channels, even in spite of the rather riged channelsupports I have an idea of how it could be done without putting additional tension on the channels, will do some Trials tomorrow and post it if I`m satisfied with it... Nils
  5. Jason, you`re right with the stepped shrouds, and I also felt like taking a Little risk in doing like I did to find the angles (no risk, no fun... ) I hope it won`nt turn out wrong to set the chain plates at this building stage. On the partial outcut portside its going to be more tricky because there is no "Skin" to bolt the chainlinks to, have to find an alternative solution for that... Nils Pete, thanks for your words, yes slowly it is coming together, and yet if I ever would build another one of these 18th century models there are so many little inspiring solutions tricks and ways gained from this MSW Forum, how to do things better, recognizing that it would probably be taking at least twice the time to build. (depending on the own set obligations) Nils
  6. congrats to your lucky find Nenad, am curious to the results with your new "poncewheels" on brass sheet, but do`nt Speed with it, leave yourself time for Trials and improvements, until you are self satisfied... Nils
  7. Moving on to the chain-plate mounting.... although I tried to get the individual link lenghths in size to enable the lowest mounting Point above the wales, I could not get them all alingned in a straight horizontal row, but I`ll leave as is. therefore the deadeyes are all horizontal in a row which I felt is more important. main mast arrangement fore mast arrangement the alignment angles I get with a string from the appropriate hight of a preliminary 8 mm diam. mast with an adjustable dummy top-platform in hight for main and foremast Build log part 39 to follow... Nils
  8. Karl, I had some bad news today... but looking up your early Posts, especially the Fitting out of your LBR section (furniture, etc, ) cheers me up tremendously Very, very well done !! Nils
  9. A beautiful model Grant, a masterly build of a great ship, well done ! Nils
  10. Hello Grant, thanks for sharing your method to make ordenary blocks look great, I always thought the "tumbling" was bound to metal work Nils
  11. 0,3mm drill Karl, That is micro surgery, incredible, how do you prevent those in breaking off ( 1 per drill hole ?) It Looks fantastic ! nils
  12. Thanks Pete, the time is now not far from putting on the forecastle and the aft quarter deck permanently, but all Fitting-out that goes underneath will have to be rigged first (anchor cables, Messenger cable and appropriate guns and their rigging) Nils
  13. Build log part 38 I am working at the forecastle in the moment, the deck, the deck rails, the the gratings and roamings, the catheads, etc.... prefitting Position check the galley chimney shall be dressed to fit for final shape later on... catheads (double sheaved) fitted on top of eking rail and cathead supporters, The mainrail shall be fitted later on the catheads slip in with tight fit Nils
  14. excellent sail making Pete, those sewed on bolt ropes look great, Well done ! together with those spruce masts and gaff booms your Pilot schooner is a fantastic sight Nils
  15. Pete, this is a lovely build log you are presenting, hull,sails, Fitting out, all very well done in Detail, I love that topsail schooner... Nils
  16. Very good looking model Bob, nice and clean built in all datails Well done ! Nils
  17. Your Diana is a superb built model Ray, I enjoy those pics every time I look into your build log. Also although Long completed already, I like to look up your HMS Pegasus, which I also find an inspiring and very well done model in all Details... Nils
  18. Many thanks E&T, for sharing your intensive experimental tests on blackening, great work.. Nils
  19. Hi Darrel, nice to hear that you have good freinds in Ol`Germany, hope you and your wife had a pleasant stay in this Country. I also still have an 80% completed Billing Boats Bluenose on the shelf, started at least 25 years ago, my wife always reminds me to get that one done before I begin something new. There are several good looking builds of those fabulous gloucester fisher schooners here on MSW, or here in Progress, that my fingers start itching to continue. I love the lines of These ships Nils
  20. The hull of your schooner is very nicely built Darrel, wish you much fun and good ongoing success in the further build sequences... Nils
  21. welcome in the Swan Class Mihai, you have had a good start and I wish you further much fun and success with your build. There are so much inspiring Versions of the Pegasus on MSW that nothing can go wrong with this lovely model you have Chosen... Nils
