Everything posted by Veszett Roka
Surely i'd dismantle the deck with a thin scalpel, just a little. I think the guns were glued themselves just below the opening, but a long bamboo stick can help tickling them out. I'd assume the glue is not too firm, since no pressure applied during the contact. I believe repairing the paint is easier than fabricate a new gun position.
Collections of Ship Models: Help!
Veszett Roka replied to Sam Willis's topic in Nautical/Naval History
Welcome Sam. You might consider to go ta Amsterdam, relatively close to you and easy transportation. Scheepvaartmuseum is a must to see there, featuring many excellent models there. Also, i've been in Lannan Model Ship Gallery in Boston where i saw (actually touch too) any of biggest model in my life. The owner Larry Lannan is a very friendly gentleman. -
Hi Bill, Although the wheel is good in this form, you might try to solder a blob at the end of the copper wire. But before try this, you must remove the wire out, because the soldering heat will melt out the wheel. Other thing i can think of the 'magic sculpt' epoxy putty, easy and cheap to order. But after all, i'd leave the wheel as is now.
Back to the searchlights. Aren't they painted on the real ship? I think everything on board exposed to salt sprays must be protected from corrosion any way. Well, nickel plating is good for it, but the searchlights i saw on other ships (actual museum ships) were all painted. I've found this color photo, most probably a colorized one, so more fantasy than reality. This shows the searchlights on lower position as black (or gray?) and on mast mounded ones as ochre (possibly brass?)
Agree 120%. I was followed an other, russian modeling forum. I thought that the modelers are smarter than politicians. Well, on that forum the vehicles section flooded with Z trucks, and the comments are cheers the occupants, 'our heroes' and so forth. To be honest, i found it disgusting, and i'm not a member anymore. Also, i have to tell you that in the shipmodels section no any politics occur.
Third hand is for newbies. Professionals use their own two hands only. Chuck Norris builds models without hands.
That gorgeous. Will be a challenging task in this scale, but knowing your works; not for you.
Unlikely. As an electronics engineer, i can tell they are way ahead of this size. Chip technology uses photo etching and/or metal steaming-vaporising to build the circuits. They are really in nanometer scale. Nowadays a semiconductor in a chip is 5 nm wide, and now trying to reach 2 nm, but due technical difficulties (not the size, but the intereference between neighboring transistors: electrons can travel between them) those chips are not yet reliable. I bet diagnostic and precision instruments industry who can use this level of accuracy in printing.
Hi Ian, My copy just arrived from UK. Yummy! It is a Grafton 1981 paperback, but well preserved.
Hi John, thats the same, and you're correct. If you measure an inch on the model, thats 78 inches on the real thing. Or, other words: a foot long model would be a 78 feet long boat in the reality. If you have a Bavaria 35 yacht which is exactly 35 feet long, its model will be 35/78=0.448 feet, so 5.378 inches in 1:78 scale. If someone can give you the exact plate sizes, just divide them by 78 and you will get the scale size.
- 39 replies
- cutty sark
- sergal
Very impressive Bill. Your Vic made me to want another one for myself, but my Pamir is stalled due other projects and i will finish her before start any other.
Those brackets purpose primarily the direction and elevation measurement. On the picture, you can see a bearing scale ahead of the crew, and on his left side you can see the elevation scale. With those scales the watchmen can give precise direction of incoming threats. Their binoculars were equipped with a very basic rangefinder in the right eyesight.
Hi Jan, yep, same situ here in Hungary. However, i was in a shipmodelers' meeting once, and a guy came with a 40*40 cm chess set, with all the board and figures was constructed from card. Of course, the figures were all different type of ships. The pawns were small boats with a single latin sail, the knights were frigates with 2 masts, the king was a ship-of-line and so forth, of course identical ships with black and white sails. You should have seen the dropped jaws there (mine included). I think the hobby shops just followed the demands, shipmodeling is not too familiar due small scales, much more modelers interested for armor and planes. Also i remember when i had to order my Titanic abroad (Academy 1:350) in 1995 because nowhere i found a kit before the 1997 film, which skyrocket the interest again to her lately. Still have the original Korean instruction sheet
Unfortunately not yet. There is no available copy in local antic shops, so i'm checking the internationals.
Simply marvelous. It is real, not need to think what this or that could be, all of the fittings, ropes, rods, and other things are perfectly recognizable at first sight. Few models can present this 'feature' for me. Accept my congratulations, even it worth nothing.
