Everything posted by BANYAN
Very neat work Dave; looks spot-on! How did you cut the square hole for the boom through the cap? it is an excellent fit, I had a lot of difficulty with that. cheers Pat
Nice work Greg, that would have been very tricky to hollow out those gun shields in soft plastic- kudos! cheers Pat
I have not seen such (exterior) doors during my service; however, as JUD points out, the high coamings may have been deemed sufficient if the ship was a relatively dry one? I am researching an 1855 built steam screw/sail sloop which had open gratings set into a raised box type coaming around the funnel. This elicited similar questions from me as I thought the boiler room may have been prone to flooding with such an arrangement. Hence my earlier response re location etc. The consensus of reply WRT to my query was that high coamings (which it had) and being a relatively dry ship in most weather may have influenced this design. cheers Pat
- 11 replies
- 19th century
- Galilee
- (and 6 more)
Hi Terry, cannot answer your question directly but it would help us to have a little extra info (especially WRT the watertight aspects of the door). For example, the location of the deck house it services, direction it was facing (into the elements or aft where a little more sheltered). This may allow some of our better informed members to establish the likelihood of of water ingress? cheers Pat
- 11 replies
- 19th century
- Galilee
- (and 6 more)
Welcome back to the fray mate! Look forward to your updates.
- 1,616 replies
- caldercraft
- agamemnon
What you point out makes a lot of practical sense Jerzy, but I cannot avoid the advice from several eminent authors that state that the lower yard parrels, where still used, had been rigged as static (no fall with purchase or tye with tackle) by mid 18th century. Hopefully I will get to find out what the replica is doing but failing that I think I need to stay with the consensus of the various authorities even though the practical element is difficult to follow. Thanks for the input; appreciate your time to read and comment. Pat
Thanks Dashi; that is what I was hoping to do, great to have it confirmed as the better option. TFFM also states this so I will do away with the tye/tackle option at this stage. cheers Pat
Hi again folks, I am getting myself further confused (not hard to do) According to the AOTS - Capt. Cookes Endeavour, the Fore and Main lower yards were fitted with 2 row parrels (6 ribs with 5 trucks per row). Ray Parkins does not discuss/show them at all in his H.M. Bark Endeavour. According to Marquardt (18th century rigs and rigging), the version of parrels used on English ships changed during the 18th Century and were not in common use after mid-century. Early in the 18th century, the version that could be adjusted with a truss fall and purchase were phased out in favour of the standing parrel (which is the version described by David Antscherl in TFFM vol 4 - I think). James Lees and Mondfeldboth provide similar info/advice and the Truss, with fall ending in a tackle secured to an eyebolt adjacent to the mast at the deck, was in common use on English Ships from the mid-18th century onward. Noting Endeavouur is mid-century (ish), it is possible that Endeavour still had Parrels in lieu of Trusses but I would like to be sure if possible. If parrels were in use, they would have been the standing version which I assume, based on the above info, did not have a tye tackle or purchase? So if standing, does this mean they were seized at the yards, with the seizings cut each time the masts had to be lowered, or swayed/braced at the more extreme angles? John, if you revisit this thread, can you recall if the replica uses trusses or parrels please? Can anyone enlighten me please?
Many thanks Pat
Thanks for the feedback guys. John and Mark, that appears to be a solution (faking it ) but, if possible I wish to do them properly and may have conceived a method which I describe below. i will certainly revert to this if i cannot get the real deal to work. Allan, many thanks. I read that info after posting and it gave me a couple of ideas. My rigging actually works, so I intend to lower the temporary 'stub' yard and fit the actual yard to the lifts/slings while in a lowered position to gain more manoeuvre room. I will make up the parrels as described by David in the TFFM and temporarily hold the parrel assembly together with some sacrificial light cotton thread wrapped around the hollow in the ribs. I will then tie/size one end of the parrel ropes (with the eyes) around the yard on one side of the mast, wrap the rope and parrel around the mast then loosely tie the other end of the ropes around the yard on the other side of the mast and haul these as taut as i can allowing some room for the parrel to slide up the mast. I will then raise the yard into position, tighten the parrel and then wrap the ropes as described by David. One further point raised by a member off-line is the handling of the tail ends. Do the tail ends of these parrel ropes tie off on the parrel, or are they led via block to the deck to allow them to be re-tensioned or loosened as required to work the yard? I'll see if this method work for me and advise. Thanks again all for the very helpful info. cheers Pat
Very nice Ulises; that paint effect on the decorations looks very effective. cheers Pat
- 786 replies
- Royal Louis
- Finished
Thanks Mark and S - I did that with the jib etc and intended to do so for the lower yards at least, but my real issue is fitting the parrels. To fit these correctly they need to be threaded on the bottom row first, then a loop taken around the yard and the top row threaded (or vice versa) then around the other side of the yard; then the whole assembly must be pulled taut and several passes of the line made around the parrels and the yard. That is my issue - how to achieve this without damaging anything, as some force is necessary to pull the parrels taut around the mast after threading. Even the threading will be very difficult in such a tight space. i would be very interested in any techniques people have used for this? Sorry guys, my initial question was not specific enough and you have answered my initial question. cheers Pat
Very effective solution to the fuse removal issue Glenn, a tricky job made easier and safer. Your skills are superb mate; the engines and boilers are miniature works of engineering art! Always a pleasure to visit your log (and drool ) cheers Pat
How come I find your logs well after you have started Rusty (my fault for not being diligent enough) - great looking build (again). the deck looks spotless; really nice! cheers Pat
- 310 replies
- cheerful
- Syren Ship Model Company
Hi folks, I am starting the final stages of fitting the spars to my Endeavour and I have finally fully dressed the lower fore yard ready for fitting. The slings are in place on the mast head / trees but I am trying to figure out how to fit the parrels to hold the yard to the mast without damaging the rigging (very little working room). Any suggestions for a method/technique welcomed cheers Pat
Those gallery windows look great Mark; persistence will pay off. A boon that you o not have to program the drawings (a la CNC); it seems the laser cutter is a great tool/asset to have for this type of work. cheers Pat
Greg, she is looking fabulous mate - nice work with all the additional detail. Glad to hear the handle didn't cause much damage. cheers Pat
Well mate, considering you have "thrown" the boats on; they have turned out very great I agree, no use risking breakages in trying to put on the 'gripes' for each boat - you can always say that the ship is prepped rerady for entering/leaving harbour when sea gripes and coverings would have been removed. Nice work! cheers Pat
Cheaper freight??? let us in on the secret mate - things have jumped exorbitantly this side of the ditch cheers Pat
Thanks Druxey, it has been a pleasure to follow-along as well. cheers (and beers) Pat
- 641 replies
- greenwich hospital
- barge
Very nice work Mark, they look like they will form excellent bases for your galleries. cheers Pat
