Gregory
Everything posted by Gregory
  1. Great advice wefalck and YT! I realize now, I should have mentioned the template.. Getting a consistent shape would make it necessary.
  2. Hard to believe it's been over two weeks since an update, because I have been doing some work almost every day, if it has only been to lay a plank or two. As I mentioned, I'm spiling the planks that are curved and it takes some tweaking to get a good fit. The scrap bin has grown considerably. Here is the last plank for the port side ready for gluing. The finish on the bow, while not perfect, is not as lumpy as it appears in the photo. The grain of the wood and lighting create a look that is somewhat unflattering.. But I know you all know how that goes. I'm Satisfied with the fit. I decided to go with one drop plank on the bow. While they usually show up higher on the bow, I said " what the heck " . Being close to finishing the side at this point, my laziness got the better of me and I decided to make one plank instead of three. Port side done. Not a lot left to do on the starboard: ... and I'm looking forward to working on the other aspects of this build, that aren't as repetitious as the planking.
  3. Not an easy challenge for the first time, and YT's method is certainly an option.. Take a look at the Knight heads for Chuck's Winchelsea build. While the project comes with some laser cut starter pieces, imagine cutting out those shapes with small files and chisels. A rotary tool might be useful, but requires a lot of caution because they tend to run away and cause damage. Then it is a matter of fine tuning them.
  4. If it gets the ( your job) job done, that is all that counts.
  5. Great start.. Do you have some square stock that you could shape on the long axis, then slice off pieces? Might go a little faster.. Here is an Image from Anatomy of the Ship - The Ships of Christoper Columbus If you need more info from the book, I will try to find it for you.
  6. Do you have a link for that saw? I would like to see the features. I can't seem to find anything but the blades, which appear to be very competitively priced.
  7. I'm hard pressed to see what the problem is. It looks really good to me.
  8. Hard to imagine since cardboard is made out of..... No, wait! Nevermind... 😁
  9. What are the full size measurements? You are talking about the triangular shape deadeyes? Those would be fairly easy to scratch.
  10. Are you clicking on the little trash can by the image you want to delete at the bottom of your post where it says: " Uploaded images " ?
  11. I refer you to this recent discussion. Making blocks There are others. I will try to put together some more references for you.
  12. What does your rope walk look like? There are different styles out there.. Mine is somewhat traditional but limited by the length of my workbench.. I can only make about 40 inches of rope at a time. The size of the rope is determined by the number of threads I use on each of the whorls. I have made rope with up to 8 threads on each of the 4 whorls, for a total of 24 threads.
  13. How are you using the pencil? If you run it along the edge after it is in place, there is less mess. Just one edge of adjacent planks gets the effect done. Also, how soft a pencil? I think you will find a No. 2 works fine. ( Disclaimer: While I have used pencil to good effect, the above image is of some laser cut planks, so the char provides the lines you see. )
  14. Did I see you have you have the Byrnes saw in your shop? How small a kerf do you have? With an .02 kerf, you can make all the grooves on a long strip before you separate the blocks and fine finish them.
  15. Here is a basic illustration from Mondfeld. I recall seeing this method in more than one model ship building book, so you may already have this.. Another option is to laminate some thin strips together, where the strip in the middle is more narrow than the outer strips, creating the sheeve portion without sawing or milling.
  16. My 550 in '74.. Couple of my buddies had 750's.. I was jealous..
  17. Chuck, just curious about your source for some of the fine images of contemporary models. Are they publicly available, or is it private stuff you have access to?
  18. The difference compared to post #108 is obvious.. looks great!
  19. Chuck says he uses this stuff for his friezes . Avery Glue Stick Good idea to practice with some scrap and find what works best for you..
  20. Minor update to show I'm still working.. Planking above the wales complete. A couple of coats of poly, with more to come. Next up; inboard gunwales and cap rales.
  21. I don't think the Syren is any less complicated, but the kit is better designed and the instructions are much better. I think if you build a Syren you are happy with, the Rattlesnake will be less challenging and you will be better prepared to improve upon the kit and overcome any shortcomings.
  22. Work goes on.. For me, the planking is more than one project. I switch back and forth between above and below the wales. Port side above the wales is almost done. The darker color on the left is where I am seeing how some poly will look. Only three strakes below the wales so far. I'm still doing some planning for tapering at the bow an broadening for the stern. The kit uses 4mm wide planks and calls for 5 stealers at the stern. I'm making my own 5mm planks out of veneer and will shape them to avoid stealers or drop planks. This is my spilling technique that I am still refining. Good thing I have plenty of the veneer I am using. I lay a piece of masking tape over the area where I want to put a plank, and trace it with pencil. I lay it out flat on a piece of paper, which I then scan, and refine the shape in my editing programs. I then use this pattern to cut out the plank with my laser. Needs a little trimming for a tight fit, but it lays flat with no further bending required. No pictures of my scrap bin while I was refining this process..😁 Looking ahead: I won't be using the cast quarter badges that came with the kit. As with the transom, I will try to put together something based on the Chapelle drawings.
  23. Do you have any more context? A broader view of the plans? I found this in Longridge.
