Everything posted by yvesvidal
My sentiments exactly !!! There are two square openings on each side of the main mast. They could have placed the staircase/ladders there.... Yves
Thank you Chris. Yes, that would make sense and on my model, I would either have to remove the staircase or remove the spikes around the Capstan. Yves
Folks, experts, I need your help here. The picture above shows the rear quarterdeck subfloor. The stern is to the right and the bow to the left, with the main mast going into the square cut. The rear capstan is located on the main deck. Apparently, there is a staircase going down from the quarterdeck to the main deck. That staircase is located on the second opening from the right (center of the picture pretty much) and would come in conflict with the spikes of the rear capstan. The staircase would land approximately right before the hatch located to the right of the main mast. How do I solve that impossible equation? How did it work in real? Was the rear capstan never actuated/operated/pushed from the main deck (but only from the gun deck)? Was the staircase foldable or retracted when the main deck capstan was used? That seems unlikely, when looking at the size of it. I could not find any information on the Anatomy book or other plans of Bellona. I suppose, removing the spikes would allow room for the staircase. I am looking forward to reading your comments and suggestions. Yves
It is all Photoshopped..... (Evil grin). Yves
- 488 replies
- Indefatigable
- Vanguard Models
Amazingly beautiful. For the presentation, I would place one on the deck and present the other twos, in the front, separately. Yves
- 857 replies
- Sphinx
- Vanguard Models
Time to install the sub-floors of the Forecastle and Quarter deck. For the Forecastle, CAF proposes two large pieces, which are covering 6 beams: That is not only difficult to size and adjust exactly, but it makes the gluing on the intermediate beams a little challenge. This is mostly due to the curvatures in two directions of these floors. In addition, CAF Model went with a 2mm thick plywood which is on the stiff side. I wish they had use 1.5 mm or even 1 mm thick, instead. So, to get more precision and control about the gluing, I decided to cut these long parts in two: These are a lot easier to install and control. The same is done for the rear quarterdeck: Cutting.... Time to glue all four parts: Overall view: a lot of the main deck details are occulted for ever.... so sad !! I am approaching the Forecastle and Quarterdeck in this way for multiple reasons: I can work on the bow, catheads and rails on the outside of the hull....and use clamps. I can work on the mid-ship railings (see below) It gives me some time before putting together the second gallery, rear balcony and main rooms on the Quarterdeck. Yves
Time to assemble the stove and install it into the kitchen. The stove is entirely made of Photo Etched parts, brass cast part for the socket of the chimney and a brass tube for the chimney. Instructions are detailed, for once: I decided to solder the main body of the stove for added solidity and stiffness. All the other parts are glued with CA: I created a small base and simulated the bricks that are holding the stove and protecting the ship structure from the heat. The CAF kit has no provision for such thing. The stove is painted Tamiya flat black: The insertion of the stove is delicate and the base is glued to the main deck: Unfortunately, not much is visible....oh well, at least, we know it is there..... Yves
Timber-framed outdoor kitchen - Cathead - 1:1 scale
yvesvidal replied to Cathead's topic in Non-ship/categorised builds
I love your property and what you are doing with it. And most of all, that you can live "off the Grid", pretty much. This will come so useful in the coming months..... Yves -
Very nicely done and filmed. Yes, perhaps a tiny amount of weight on the bow and it will be perfect. I love the sounds of the machinery from underwater....very realistic. Yves
- 55 replies
- auguste piccard
- submarine
For the internal arrangement, I am taking some inspirations from this picture: This is from a fantastic web site: https://blenderartists.org/t/hms-pegasus-full-ship-building-in-progress/696956/49 Yves
More on Session #4 - The rear cabins under the rear quarterdeck were already built and I completed the beams structure on top of it: The section around the main mast is delicate and requires some thinking and vision, if you want to make it fit. Of course, the bulwarks must be built before, since the beams are resting against them. At this point, all the beams are in place, all the walls, cabins and guns located under the quarterdecks have been built and glued. Let's take a close look at the overall ship: And a few close-ups: All the above will be covered and most likely very hard to see. Yves
SESSION #4 Although, some work has already been done for Session #4, let's get into more details. Session #4 is covering the front and rear quarterdecks, what goes below them and what goes above as well as the bulwarks, which have been already completed (see instructions below): The kit provides two strips of 4 x 4 mm that must be carved to accommodate the required shape. I wanted to extend these strips all the way to the first rear guns and all the way to the front bulkhead. That can be done, but you have to carve the entire length and be very careful with the cuts. I wish CAF models would provide an additional strip: that would reduce the level of stress on this kit.... In the picture below, you can see what I am talking about: The next phase is the building of the kitchen wall with its two large doors opening on the massive stove. Again, CAF Models does not give you much in term of explanations: I decided to represent one of the two large doors, opened, in order to allow a peak into the kitchen and the stove. Next is the assembly of the beams that will support the front quarterdeck: You can see the additional piece of wood that was added to hold the center part of the large doors. Once the stove is in place, we are now ready to install the floor of the front quarterdeck. Yves
