yvesvidal
Everything posted by yvesvidal
  1. The acrylic resin has been brushed on the inside of the port side: This seals the wood from external agents (humidity mostly) and increases the bonding strength of the wood glue. The resin is permeating the wood fibers and contributing to their resiliency against aging, hygroscopic and temperature changes. It is suggested by CAF and has been used with success by many modelers before. Yves
  2. One side done: Now, I have to brush the resin on the inside and do some sanding to make it silky smooth: Yves
  3. Thank you Mike. Yes, coppering and a second planking in visible parts, are in order. After all, I am also entitled to a second planking.... 🙂 like so many other kits. Yves
  4. The third quadrant has been completed: I know that a lot of experts will see my construction as blasphemy and heresy to what should be done. It is okay and I understand their point of view. I did the best I could, knowing that this hull will be copper tiled and that most of the planking will be hidden. The most important for me was to embrace the shapes and curves of the hull and to make progress in a relatively decent amount of time. The original planks are 8 mm x 3 mm of poplar/limewood strips. To accommodate the sharp curve of the bow in two dimensions/directions, I decided to slice each plank into two 4 mm x 3 mm strakes. It is a lot easier to handle and I built the planking from the whales up to the mid hull, like a stair with enough steps overlap. Once sanded, the hull is very round and still offers a decent level of sturdiness and solidity. A tiny amount of wood paste is necessary in some places to fill up some of the steps, so created. From the keel down, the planking is placed directly against the bulkeads, until the strakes meet as pictured below: The overall results is rather nice (at least in my humble opinion) and replicates quite accurately the external curves of the ship. It is a lot of work as close to 40 small strakes had to be glued one after the other to create the bow: This is where I stand at this moment: I think I will be finishing the port side of the hull, before moving to the other side: Yves
  5. Beautiful results, Moonbug. I wish I can do as good as you did, on my upcoming hull. Yves
  6. Beautiful! Good thing you painted the strakes separately.... Yves
  7. Andrew, Quite often, these furry and wonderful companions are here to help us with karma. It is not uncommon for them to take upon themselves a disease that should have otherwise affected us. We suffer through their loss, but the physical pain in our body is spared by their unconditional love for us. They truly are furry angels of great wisdom and generosity. I have lost quite a few cats (and other animals) during my life and understand very well what you are going through. Yves
  8. I am using Thick & Quick Titebond to glue most of the planks on my Bellona 1/48. It gives you about 2-3 minutes maximum of wiggle time. After that it becomes really thick and unusable. The good thing is that it will allow you to press part for two or three minutes with your fingers, when tying it up with clamps is not possible. A good compromise between CA and regular glue. Yves
  9. John, That is a great build of a very old kit. I cannot believe that they did not design this hull as planked, as that shape would be very easy to plank correctly. I am glad that you managed to "insert" some planking into its building .... 😉 These paddle boats are some of my favorites and I will be following your build with a lot of interests. Yves
  10. Dave, thank you for the thorough answers to my questions. Yes, I think I am going to go with the tape too, as the tiles offered by CAF Model are too small and way too expensive. Yves
  11. Chris, Thank you for correcting my false assumptions. I like brass (the metal...) but agree with you that 3D printed resin is way superior for accuracy and details. Yves
  12. David, This copper tiling is looking fabulous. Could you tell us what kind of copper ribbon did you use (Brand)? Thickness? Backing (clear or black)? Width? How did you prepare the wood of the hull to get a good adhesion? I will have to copper tile my Bellona (1/48th) soon and I am trying to learn the process and follow the recipes of people who had successful results. Thanks in advance. Yves
  13. Very promising kit. I like the details on the gun carriage wheels. The 3D printed guns are very crisp and usually better detailed than brass guns. I understand that brass guns would impact negatively the final price of the kit with so much armament, and 3D printed guns will reduce, weight, cost and already have the right color. Yves
  14. Chris, I am very glad to see the Master of Cruise Liners back on the saddle. Still waiting to see that 1/200 Titanic kit.... 🙂 Yves
  15. Craig, Each session is purchased separately. Yves
  16. Kevin, you may want to organize all these wires as they will not fit inside the hull. Also, the light leaking out of the modules will look ugly, through the openings of the deck. Yves
  17. Mike, Nothing is double planked. The hull is supposed to be copper tiled and that is probably where I am going. Above the water line, I am planning to use the maple planks of 0.4 mm thick (same width as the main limewood planks, 8 mm) and pretend to have a nicer planking arrangement. We will see how it goes. Yves
  18. Well, there is not much I can do at the stern at this stage of the hull building: It is time to move the construction crew to the bow: Yves
  19. Turangi, This is a gorgeous diorama, beautifully executed. The model is stunning and the long wooden planks are perfectly displayed. I would just place a few 4x4 pieces of wood to insulate the planks from the ground. Wood was never placed directly on the ground. Yves
