Everything posted by dvm27
Nice job on the port and sweep linings. Fun? Maybe the first few, but after that a lot of tedium!
- 1,207 replies
- sloop
- kingfisher
Very nice mast step, Danny, and beautiful wood palette you've chosen.
- 268 replies
Pandora by marsalv - FINISHED - 1:52
dvm27 replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Great work and planning Marsalv. The hanging knees are the most difficult to fit but for some reason I usually install the beams and lodging knees first. Your building sequence makes a lot of sense. -
Having a solid wall of timber is probably not the best idea, as I found out on my Speedwell model, Mike. There are gaps between the fillers in the winter. I have filled them with sawdust and glue and they have appeared elsewhere. They'll probably disappear as the humidity rises, as you perdict. I am reminded of the problem Franklin had when building his beautiful model Egmont (which was purchased by the NMM). He noted that his hull shrank almost 1/4" after framing as the humidity decreased. He applied a wet towel overnight and the length of the hull was the full 1/4" longer the following day. He then applied the wales and the problem was solved. if there's one thing I learned after watching This Old House for 30+ years is that wood is a living material that expands and contracts. One must always compensate for this (although I'm not quite sure how this could be done with a full set of filler frames unless the model was kept in an environment with consistant humidity forever).
- 943 replies
- hahn
- oliver cromwell
Eye candy, Remco. The hammock battens make your model unique, I think.
- 1,207 replies
- sloop
- kingfisher
According to Goodwin, The Construction and Fitting of the English Man of War 1650 - 1850, "The most common (scarph) was the butt and coak method and like all the methods used the scarph was set in the vertical". This corresponds to David White's excellent series of articles in Model Shipwright. Perhaps the vertical scarph joint presents less exposed area for water to seep into and promote rot within the keel.
- 943 replies
- hahn
- oliver cromwell
Sweet work Danny. Those inlets fit the recesses perfectly. Are you going to leave part of the pump well unplanked so people can see details like these?
- 268 replies
When using paper to simulate caulking between joints I make numerous pricks throught the paper everywhere but at the edges before gluing. Perhaps this allows better glue adhesion. In addition I use bamboo treenails glued, or brass wire epoxied, to reinforce the joint. As yet, I have had no papered joint faliures. The most perfect joints result from using slightly oversized scantlings and reducing them too finished dimensions on the Byrnes thickness sander.
I've used both pigmented glue and black kraft paper to good effect. Do one further test before you proceed. Liberally apply isopropyl alcohol to a test joint to see if the stain runs during the debonding process. I've had some adjacent pigment bleed during the process. Or, never make a mistake and this won't be an issue.
Frigate Boston by overdale - FINISHED
dvm27 replied to overdale's topic in - Build logs for subjects built 1751 - 1800
Great looking model, Daniel! I also checked out your website and there are some amazing models there! -
Echo by davec - FINISHED - cross-section
dvm27 replied to davec's topic in - Build logs for subjects built 1751 - 1800
Looks terrific, Dave. I fit out just one-half of mine and it makes for a very nice display.- 127 replies
THE 74-GUN SHIP by Jeronimo
dvm27 replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Wonderful work, Karl. What sort of jig do you use to transfer the heights for the platform beams inside the hull? Happy Holidays to you also and we all look forward to 2016 updates fro you!- 194 replies
Holy crap you're good! What secret blackening recipe do you use? It's a source of never-ending frustration for most of us mere mortals.
Fantastic, Nils! Can you sneak one of those little guys into the hold so people can see how cramped it really was?
Echo by Maury S - FINISHED - Cross-Section
dvm27 replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
The planksheer rails, associated moldings and volutes are the icing on the cake and, to me, one of the more difficult projects on the ship. Among violin makers the shape and precision of the carved volute are big factors in their value.- 324 replies
Very nice Mike. Fittingly, you've moved over to the Dark Side - power tools (Star Wars being released this week in case you've been living in a convent). Enjoy your lathe/mill and all the fun things you can do with them. Hopefully you'll get over the "making beautiful wooden pen and pencil sets" phase for relatives and neighbors quickly.
- 943 replies
- hahn
- oliver cromwell
Happy belated Birthday Wishes Remco. May you age as slowly as your progress on Kingfisher!
- 1,207 replies
- sloop
- kingfisher
That's a beautiful hull Mike, even in her rough form. Can't wait to see her filled and sanded and ready for prime time. .
You should donate her to MSW to auction off. You get a million dollar tax deduction, MSW gets a boatload of money selling her and the buyer gets to spend the rest of his/her life rigging her. A win-win-win situation all around!
- 191 replies
- young america
- clipper
I'd never really paid much attention to the Adelaide model when visiting the collection. I can understand how those old timers espoused form over function as the round stern is not aesthetically pleasing compared to those of the prior century. But it is an exceptionally well crafted model and I look forward to spending more time studying her on my next visit to the Academy.
Great job, Toni. I don't believe there's a more difficult job then framing the stern and getting all the curves right (except for the head timbers and rails...and carving...and louvered windows...and...)
- 1,449 replies
Beautiful job on planking and painting your hull, Mike. Looks perfect.
- 452 replies
- cheerful
- Syren Ship Model Company
