Everything posted by dvm27
Just five years? You're obviously on the accelerated program!
- 1,449 replies
Echo by Maury S - FINISHED - Cross-Section
dvm27 replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
They should indeed line up. Maury. The bottom of the cheek block should be 3" above the beam and would sit directly onto the 3" deck planking. Perhaps you placed the sheaves for the main brace bit pins too low?- 324 replies
Spending all the time to properly frame a model in an historically correct manner and then covering it up seems like a crime. There are may strategies to show framing or areas of framing.
Brilliant work, Ed. The time taken to make and install your jig really shows up well here. I can't imagine raising those timbers without it.
- 3,618 replies
- young america
- clipper
Lovely work, Danny. Is the other side left in frame (I forget)? Then you don't have to repeat this difficult task.
Very nice Maury. The bits are an excellent exercise in planning, machining and hand finishing. A lot of though goes into the sequence of construction.- 324 replies
You're a wonder, Remco! That fire hearth fooled everyone in my family who thought it was full size.
- 1,215 replies
- sloop
- kingfisher
I was thinking the same thing as Druxey, Ed. I've had tear outs even when being especially cautious. You make it look easy!
- 3,618 replies
- young america
- clipper
Thanks Mike. That was the problem. You may wish to post this in a general discussion so others may see it (if not already there).
Very sweet work, Maury- 324 replies
Gary - I tried to send you a PM but the error message says you cannot receive PMs. Send me an e-mail at dvm27@comcast.net. Greg
I agree, Mike. I used to live in the Philippines and ship models were amonth their exports. Unfortunately, the "craftsmen" who made them were paid extremely poorly and were exploited just like workers in other third world countries. Stil...it did put food on their table.
I can't remember what I had for breakfast but I do remember obscure references for some reason, Mark. Unfortunately, a search of the usual sources failed to turn up the reference to back up my statement. It might have been in one of the hundreds of journals in my basement. Or, the author could have been mistaken. It'll turn up, no doubt, five minutes after you've completed the beams.
Nice fix, Toni, and a very nice forrest of pumps. I too found those hexagonal openings difficult to get exactly right and actually cut the pump tubes to fit over and under the partners with an alignment pin drilled through to keep them properly oriented.
- 1,449 replies
Perplexing, is it not Mark? I would certainly trust Ed's research but I I have read this is precisely the case. As I recall, each beam progressing aft has a slightly smaller round up as they approach the transom. I don't recall if this is the case in the fore section. I'm sure others can provide a more definitive answer with source references. I suppose one could place 5" round up beams aft then fay the others to a batten connected to the 8 1/2" beam fore. But I suspect you'll develop a table of offsets and do this more scientifically. Gary...Druxey...?
Looking good, Remco! I made a very convincing brick hearth for Druid some time ago but it is hidden in the bows of the model. Long lengths of 2 1/2" x 4 1/2" stock were prepared with vertical "mortar joints" slit in every 8". These lengths were offset and laminated over slightly inset 1" fillers to represent the mortar in between layers. After assembly, the hearth was painted with antique white (making sure to get into all the mortar joints), followed by dry brushing the surface with a brick red color. It's more of an assembly line approach but it worked well for me. I've no doubt, however, that your's will look amazing whatever technique you use.
- 1,215 replies
- sloop
- kingfisher
Great start, Ben. It's all a cakewalk from here on.
- 889 replies
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
dvm27 replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
If I was a teeny tiny person I'd want to live in your ship!- 883 replies
- royal caroline
- ship of the line
I used to feel the same way about painting only with wood, Alexandr. But, in looking at many Navy Board models, I see some were done precisely as Mark is doing and the overall effect is very pleasing. Getting the right shade and texture of red seems problematic but Mark and Druxey have it just right. As you say, it is a matter of taste, and mine has changed a bit recently.
ancre Le Fleuron 1729 by rekon54 - 1:24
dvm27 replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
Bravo!
