Everything posted by dvm27
The disk sander (Byrnes) is the most commonly used power tool in my workshop. It'll save you hours of manual labor.
- 968 replies
- hahn
- oliver cromwell
Echo by Maury S - FINISHED - Cross-Section
dvm27 replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
I omitted those hanging knees, Maury as I felt they would look odd hanging off the end. I do like Druxey's idea of adding it as a thin wafer!- 324 replies
Review of the Admiralty Model Sail-making Workshop, NOTL
dvm27 replied to AON's topic in Masting, rigging and sails
We're glad you had a positive experience Alan. For anyone wishing to take the two day course we are offering it one more time in Baltimore, MD, December 12-13. A few seats are available. Details on our website http://www.admiraltymodels.com. Or you may contact me at dvm27@comcast.net. -
- 17 replies
- pof swan series
- tffm
For what it's worth here is a photo of the main mast partner of Pegasus, based on David Antscherl's illustrations. Yet to be added are the holes for the chain pump return tubes. I did not mast her so the opening is left hexagonal.
- 17 replies
- pof swan series
- tffm
While not directly related to clipper ships the following passage from The Wooden World, by N.A.M. Rodger, proves interesting. "Men at sea, like men on shore, did not drink water, which was unpleasant and unsafe. The ships carried a great deal of water, but if possible it was used only for cooking. On long passages and on foreign stations men drank watered wine (in the proportion of 8 to 1) or watered spirits (in the proportion of 16 to 1) but in home waters they drank beer alone." I highly recommend this paperback for a fascinating look at life in the Georgian Navy.
- 3,618 replies
- young america
- clipper
I've never seen a tabled joint on a model, Remco. Extraordinary work! It's a shame no one willd ever know as you can't see both sides at once.
- 1,215 replies
- sloop
- kingfisher
They look great Remco and I really admire you're doing them at this stage, when you don't have the option of removing the sternpost.
- 1,215 replies
- sloop
- kingfisher
Byrnes Thickness Sander?
dvm27 replied to Stefonroman's topic in Modeling tools and Workshop Equipment
Kevin, Proxon makes a thickness planer which is very good. But you cannot plane the wood below 1/8" without putting it on a sled. Jim's product is well worth the money and you can get planks whisker thin. -
That's a great way to protect and stabilize the hull while planking, Toni. I haven't seen that before.
- 1,449 replies
HMS Naiad 1797 by albert - FINISHED - 1/48
dvm27 replied to albert's topic in - Build logs for subjects built 1751 - 1800
Beautiful work and workshop, Albert. Looks like you've a couple of other framed projects on the shelves. Are you taking a pause from them? -
Beautiful work, Chuck. Love the ease and perfection of the rabbet.
- 1,051 replies
- cheerful
- Syren Ship Model Company
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
dvm27 replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Safe if you don't have cats, Doris! Wonderful to see your progress whenever you find the time to post.- 883 replies
- royal caroline
- ship of the line
Can i live without a BYRNES TABLE SAW
dvm27 replied to shihawk's topic in Modeling tools and Workshop Equipment
Here's a perfect example of tool overkill. Recommended for only the most serious tool-aholic! The piece created is the top of the brake pump, based on the illustration of David Antscherl in The Fully Framed Model (vol. 2). The piece is hexagonal with a tapered cylindrical head, a central bore and a discharge tube. Here's how I made it: 1. The hexagonal shape was laid out using the 7:10:7 technique. 2. The hexagonal shape was created using the Byrnes disk sander with the table top tilted at a 45 degree angle 3. The piece was transferred to the Sherline lathe where a center bit was used to start the bore. 4. A drill bit was used to enlarge the bore to it's final diameter. 5. Thin strips of 180 grit and 320 grit sandpaper were used to taper the head to a cylindrical shape. 6. The piece was transferred to the drill press where a center bit was used to mark the opening of the discharge tube. 8. The discharge tube was drilled using the appropriate bit. 9. The piece was transferred to the Byrnes table saw where the final sloping outboard face was created using the fence set at the correct angle. 10. An over-sized cylinder was created on the Sherline lathe for the discharge tube. 11. A center bit and drill bit were used to create the inner diameter for the discharge tube. 12. The outer diameter was then shaped using a cutting bit on the lathe. 13. The discharge tube was parted at it's correct length and glued into the pump tube. While this is a very small piece there are many angles involved, not to mention a bore which needs to be perfectly centered and a very thin walled discharge tube. Could I have made this piece using only chisels and a Dremel drill? Yes. In fact I did so, but discarded the effort because the machined version was better. Would I buy all the equipment just to make this piece? Certainly not. But I have had these tools for many years and they have paid for themselves many times over. Total time to make this piece using the above method was twenty minutes. The less successful hand produced version took over an hour. Those of you who love their power tools (Is Norm Abrams from This Old House present?) will totally get it. The rest of you will think I've gone off the deep end. I respect all views! -
Unfortunately, Preac is out of business. Perhaps they're still available on the secondary market. I do still have and use a Preac. I'll have to try that blade sharpening trick Kurt, although I can honestly say I never thought the saw was under powered. I do note a Preac video available on eBay. Has anybody seen it and does it cover what Kurt is describing? It's pretty pricey. http://www.ebay.com/itm/Miniature-Table-Saw-Featuring-the-PREAC-Precision-Miniature-Table-Saw-the-DVD-/251222098513?pt=US_DVD_HD_DVD_Blu_ray&hash=item3a7e010251 -
Might you be able to provide a link?
The perfect recipe for a workshop for scratch or semi-scratch builders: 1 part Byrnes table saw 1 part Byrnes thickness sander 1 part Byrnes disk sander After simmering, add in 1 part Sherline Mill and 1 part Proxxon planer Finish with Sherline lathe and mini drill press The above recipe will require a large portion of lettuce (green) but the finished product should last a lifetime -
There's nothing crazy about talking to your dog, Chuck. The problem arises when they answer you!
- 1,051 replies
- cheerful
