captainbob
Gone, but not forgotten
Everything posted by captainbob
  1. We can wait. Your eyes are more important than a tutorial. Bob
  2. I didn't hear anyone offer to pay for wood, and If you're not getting paid, is it really work? Bob
  3. I find it interesting? We look at our own work and say "acceptable" while everyone else says, "WOW!" Bob
  4. In some boats the mast was mounted in such a way that the fore and back stays could be used to move the mast for better handling even while sailing. Bob
  5. The keel and frame setup is looking good. There will be lots of room for the RC equipment. Bob
  6. Thank you all for not adding to the pressure. Carl, please no “thumb screws” I’ll be needing my thumbs. At first I was thinking of a removable top of the cabin to show off the insides but now I’m thinking I’ll do it like Omega did on his Mystic. There’s always that problem of showing as much of the insides as possible and yet still showing the lines and beauty of the boat. Omega and Nils both do a marvelous job of that and with help and suggestions from all my modeling friends, maybe I can come close. Bob
  7. Kevin, the location of the mast depends on the size and shape of the sail. The total sail area should be slightly ahead of the total below waterline area of the hull and keel, for proper balance in sailing. So if the main is a little larger and the jib a little smaller the mast will be forward on the other hand if the jib is a little larger and the main a little smaller the mast will be farther back. So there is no way to say because one boat has the mast at a certain spot all boats of that type must have their mast at the same place. That is only true in “One Design” boats. Bob
  8. After a debate with myself as to whether or not to add the cabin details I decided I would. So here’s a start on the cabin. I’m building it as a separate unit. I plan to put a stove in the recess on the port and a sink in the shelf on the starboard. Now that I’ve told everyone I stand a better chance of doing it. Bob
  9. Nice work on the stabilizer booms. For lead try fishing weights or used tire balancing weights from the local tire shop. Bob
  10. Coming along nicely. I like your creativity in figuring out how to do things. Bob
  11. The planking looks good and the barrels do set off the hold. Bob
  12. It's hard to believe she is not full size until you see the tools on the workbench. Bob
  13. Your MDF clamp is a good idea. Thanks for showing it. I will enjoy watching the steam engine and boiler go together. Glad I found your build. Bob
  14. I showed a picture of the finished cruiser to the admiral. She said, “I know how that is done. You get artistically trained termites to eat away everything that does not look like a boat.” Bob
  15. Elia, as I said, “Everyone is welcome to this party.” Glad you’re here. Bob
  16. I am always amazed at the detail you add to your ships. Then I see your helper in the yellow pants and I understand. I need to find a little guy to help me. Great work. Bob
  17. Everyone is welcome to this party and I want to thank you all for showing up to look over my shoulder and to add your comments. Oh, and Steve, I’m “looking forward to seeing how she progresses” also. Stay tuned, we’ll find out together. Bob
  18. The planking is done. When I made the keel I made it from two pieces of wood so they would join at the rabbet line. The portion that was attached to the bulkheads was 1/16’ thick so that with a 1/32” plank on each side it would be the same as the 1/8” outer portion of the keel. After the planking was finished the rough edges at the keel were sanded down to the keel. The keel was then fitted over the planked hull. With the bulkheads removed you can see the lower portions that were left to be the floors. Since I plan on painting the hull I covered it with filler and sanded it smooth. Now it's ready for the deck framing. Bob
