glbarlow
Posts posted by glbarlow
  1. 1 hour ago, BobG said:
    purchased all the Cheerful materials
    Hi Bob,
    Yes I've purchased everything available from Chuck's site, keeping in mind as Chuck says, it's not a kit. There are a few more things that are commonly available items (like the 1/16th x 1/8th bearding strip I mentioned) you need separately but for the most part all the big stuff I have from his site. Under the Cheerful tab on the Syren Ship Model webpage is a wood list and blocks/rope list showing everything you need.  When the shop is open displayed below that  (still on the Cheerful tab) are all the sub-assemblies (you can get all or none, your choice), the plans, starter kit (keel, bulkheads, and stem), and the wood package. Even with all that there are still things I'll have to build from scratch - I'm looking forward to that challenge.
    While you can get your own wood based on the list, I highly recommend the Alaskan Yellow Cedar. It's a new wood to me but I really like it. While you could also cut your own bulkheads the ones in the starter kit also have reference lines that help in placing gun port sills and other things - plus its in great wood as well. Remember you'll have to cut and rip everything, it's a scratch build.
    Hope that helps, everything from Syren Ship Model Company is great quality and well-made.
    I'm thinking of getting the longboat to store away a future build, my hands are plenty full for now.
  2. Two quick posts to get started, they may come a bit slower from here.
    I’ve cut a lot of bearding lines but never so easily as I did this time.  On the recommendation of another MSWer as part of a discussion about using square stock for masts I ordered this IBEX flat finger plane. It is pricy but well worth it. I’ve tried planes in the past with no luck other than gouging up wood, but this small little tool made short work of creating the bearding line.
    I never toss stands from past models, this one I made for Vanguard is a perfect fit, so yay. A block of wood, some curved shoe molding backed by 1x1 strip covered with felt. Build board done.
    I followed the stern reference mark on one side of the hull and with tracing paper transferred it to the other side. The plane slides easily to make the taper down to the rabbit strip. Maybe too easy. I may have gotten a little too much angle. I’m thinking that will be ok…won’t it…I can’t put it back on….
    I removed the stem pieces from the billet and initially was a little disappointed. I have no experience with Alaska Yellow Cedar. I did some test some WOP on billet scrap and wasn’t seeing it. But I knew there was beautiful wood there somewhere - and there was. There is a Lot of char to remove and sanding to do, a lot of work with 220 and 320 grade sandpaper since I didn’t want to risk taking too much or alter the shape of the stem pieces.
    After a considerable amount of work (not complaining, I’m not on a schedule) there it was - the Alaskan Cedar is better than anything I’ve seen, it is very nice. A bit lighter color than boxwood, it feels almost like a piece of ivory when sanded smooth. I’m looking forward to working more with it as the ship progresses.
    I followed Chuck’s practicum by adding the simulated tree nails using a #76 bit, #2 pencil and natural wood filler, I simulated caulking between the joints of the stem also with the pencil. I have some charcoal pencils I’ve used in the past but I think subtlety here is the name of the game, a little pencil goes a long way. I finished the night putting the first coat of poly on the stem and keel, big impact on color and grain showing up.
    One practice I’ve followed for every model I’ve built is addressing the display mounting very early, no different for Cheerful. I already have the display board, 12" walnut. I’ll figure out the pedestals later, the ones shown are my stock that may not work. However this was a great time to drill the holes through the keel. I use these machine screws, long enough for the board, pedestals, and to go past the keel into the frame, I epoxy them in eventually, no nut needed (other than the builder).
    All I needed to do now is drill the holes in the keel, once its securely mounted to the frame I’ll extend the depth of the holes an inch or more into the frame. Then years from now when I finally finish this epic build it will be simple to complete the display mount. A lot easier than trying to turn over a completed ship. I like my models firmly secured to a display board verses a cradle and if I change my mind the holes aren’t going to show…
    Now on to mounting the stem and installing the bulkheads.
  3.  After much research I am ready to build Chuck Passaro’s  @Chuck  Revenue Cutter Cheerful 1806. And so it begins...
    After completing nine kits over the years I am making my first attempt at scratch building. Well, I say scratch building but Chuck’s Cheerful plans, starter kit, wood package, and sub-assemblies along with his instructions and always gracious guidance make it a much easier transition.
    While I’m a decent kit modeler I’m hesitant to post a build log for Cheerful. There are several outstanding logs already on MSW, some from builders I’ve admired, some I’ve just discovered in searching Cheerful, and of course the master himself, Chuck. I don’t know how I can add anything to what they’ve already done. They do say however every model is unique, I’m pretty sure I’ll prove that...
    One thing is for sure, I’m going to learn a lot along the way. A good reason for a build log is having the council and support of the MSW community. I’m going to build it to the best of my ability, and I’m certain at the end of the build my ability will be a bit better than when I started. I’ll ask questions and share how I do things, hoping there is something useful for the next builder. I’d like to think my log will be a Cheerful read and not a Surly one (see what I did there…).
    For proper motivation I ordered a copy of the British NMM plan for Cheerful. I plan to hang it in my shop (next to the NMM plan of Pegasus) once frame shops are open again, whenever that is (Covid shut down for future readers). These plans are wonderful to look at - the fact these drawings turned into a ship and stood the test of time to become today’s model … very cool.
    We custom built our house, from the very first drawing I had the intent to include room for my model building. The architect didn’t quite get it initially, but the final blueprint has the notation “Ship Room.” We don’t have basements here in Texas due to the soil condition, so it’s fitted into the architecture tucked away on the lower of the three levels. The upside is it’s a nice sized well lit room for building, the down side is that there isn’t a lot of room for machinery, which I don’t have anyway other than the Byrnes saw and sander, so Cheerful, hand tools it is. The tub on the back right is loaded with my Cheerful collection of wood, sub-assemblies, blocks, and rope - ready to become a ship.
    The first thing was to print off Chuck’s instructions from the website and have them bound in a spiral notebook, something that will always be by my side along with my iPad to cross check what I’m doing with other build logs, So thanks in advance for the good ideas and experiences I’ll find and happily steal, I mean learn from. Next I laid out the frame and keel parts from the starter package and thought wow, there are a lot of bulkheads, and felt just a touch better about my first attempt at single planking. Then I remembered fairing and thought, wow, there are a lot of bulkheads…
    The starter package didn’t include the rabbet strip (as Chuck says, welcome to scratch building). For some reason I had the perfect 1/8 x 1/16  boxwood strip in my stock, one of the few remaining bits I had from our retired friend Jeff of HobbyMill fame. Then I wasted no time in stealing a good idea, so from BE’s log I used the waste from the hull billet to shape the rabbet strip at the bow, making it easier to install.
    With the two hull parts joined I glued on the rabbet strip using Tite Bond yellow wood glue, it sets up fast! I pre-positioned my rubber bands but I had to move quickly to center the strip. I have some brass gauges, the 1/16th size allowed me to quickly run the edges to get it centered.
    Next up, the bearding line, the keel and stem...
    Looking forward to comments and feedback. My log has begun.
  4. I don’t copper ships anymore, historical or not. I don’t like the look or the work.
    Don’t quit, remove all the copper, sand it smooth (there’s plenty of wood to do so, wood isn’t plastic. You can get the glue off), and paint it Matt White below the waterline. Check out the photos in my signature for Nelson or Pegasus. I only do white stuff hulls.
    The thing with modeling is rarely does everything go according to plan. Adapt and overcome is what makes it fun.
    Hang in there. We’ve all done our first model ...
  5. Though I’ve rigged 9 models now, I confess I’ve never served a line, at 1/64th scale I just couldn’t get excited about it. Now I’m about to build Chuck’s amazing Cheerful at 1:48 and I want to do it right. I’ll get his Servo-metic to do the serving but I have a couple of dumb, servo-novice questions:
    -What keeps the thread wrapped around the line in neatly in place so that it doesn’t turn into a unraveled mess as I work to install it?
    -is it terminated And run in a different way due to its added thickness and again so it doesn’t turn into a ball of thread.
    -Any suggestions tips or tricks?
    Thanks in advance for any advice offered.
  6. Tie a loop with one semi-loose clove hitch, slide it to get close to the right distance, put the deadeye in the loop, use your jig to set the distance tighten then put on second clove hitch above the first one about 8mm. Definitely use same color. You tie off the deadeye lanyard with its natural color between the two clove hitches using two half hitches. Make whatever adjustments are needed then watered down white glue when everything is set.
    I set the tension about equal to a loose guitar string, tight enough to bounce the string but not so tight I could get a twang. It’s a fine line between too tight and too lose.
     I’m sure others have better ways, but this is mine.  Hope it helps.
  7. Your method produce great results so go with what works for you. I use the drill only for the corners and slice my way there with a #11 blade, finishing with the files. I also do it with each layer of planking both inside and out so the final bulwarks layeyer is just following the previous two. But again, it’s whatever works and yours did.
    I’m with you on the paint. Some acrylics come in a tube and have to be thinned. I use Admiralty paints exclusively, one coat generally does it Except for my white hull, to get that look takes about 10 coats). I may try the thinned method on Cheerful, but for now...  Your paint work looks great as well.
    Maybe paint the gun ports before removing your tape.
  8. Copper patinas over time and it evens out. Both my coppered ships look much better with “aged” copper. In my opinion, bright and shiny becomes the main focal point and detracts from the rest of the ship. I wiped off excess CA with acetone and left it alone other than that.
    Another point is overlapped copper plates may look off up close but are lost viewing on the shelf, gaps stand out. I mentioned this because I see a gap in your photo. Just a thought...
  9. 7 hours ago, ASAT said:
    24x3x3/8” billets on sale
    Thanks Lou, I'll give them a look. Google did not lead me to them so I appreciate the link.  I think I'm going to make my first attempts with some Alaskan Cedar once Chuck re-opens his store.  I'm not going to go nuts, aside from Cheerful I'll try the mast and bowsprit for Speedy/Flirt. But I do need the boxwood  (ok Want the boxwood). I'll do some measuring to see if 3/8th works. 2" is way bigger than I'd ever need, though I may be able to rip it down some.
    I'm going to watch Derek in wonder as he makes his 🙂
  10. 6 hours ago, DelF said:
    what plane have you ordered?
    IBEX 36mm FLAT FINGER PLANE - 12mm BLADE. Ron (hollowneck) suggested this one.
    Thanks for the detailed response, I will make use of it in my prep for Cheerful, and likely the bowsprit for Speedy/Flirt. And here I thought you were just a good modeler, turns out your also a math professor as well 🙂
    I may order more Alaskan yellow cedar from Chuck for practice and perhaps use on Speedy/Flirt and also see if I can find lime wood stock. I have had no luck locating boxwood. There used to be a guy, Jeff with Hobbymill. All of us miss him and clearly don’t realize how good we had it. The boxwood above the Wales on my Nelson was the last I had from him.
  11. 1 hour ago, Vane said:
    basically not looked at all at the plans
    Just a suggestion, look at the plans even if its after you've read Chris' instructions. Chris is unique, seldom will you see instructions as good as his.  I built the model I just finished without ever looking at the instructions. I was able to build the whole model just using the plans.
  12. Nice post, very informative.  I've not converted square stock to mast and spars yet, but its time to learn.  So:
    Between yours and the other couple of posts I can make the jig to hold the wood for planing. I ordered by first planer ever, it will be key to not slice off my thumb.  However I don't have the means to work with metal or the metal to work with - your jig looks like an excellent tool but I don't think I can make it so I'll have to find another way to mark the wood.
    Where did you get the boxwood, it seems like it’s a magical wood that no one can find.
    This is really good work Derek, I'm looking forward to watching your masts and yards progress.  I have to figure this out for Cheerful, I better start slicing some wood for practice.
  13. 1 hour ago, Rustyj said:
    to see how it ages.
    I’ve used pear on the inner bulwarks of several of my models including Pegasus which has cherry above the Wales and on my Fair American which is mostly cherry. So far for me the cherry after 5-7 year takes on a definite sweet color, but the pear looks essentially the same (not that’s at all bad, it’s pretty wood).  I was using Swiss Pear from good ole Jeff, that may be different than your pear.
    Either way that’s one nice looking hull, you’ve always been one of my inspirations for me to ‘do better.’
  14. Those are the longest skinny cannons I’ve ever seen 😂🤣
    Your hull looks great. Not sure what to offer on the painting. The Tamiya tape is usually the answer.  I have a tool I use (hard curved metal end) to run along the edge to ensure a really tight seal.  I’ve had the poly underneath the tape and not had a problem. At any rate you recovered nicely.  Nothing stands out worse on a model more than bad paint lines, sure don’t see any now.
