Everything posted by druxey
Bob: So many folk buy an elaborate first kit and quickly run onto the rocks. You are smart in beginning small and working up. Even a 'simple' model isn't that simple, as you've found out!
- 38 replies
- First Build
- Model Shipways
Through bolts had a slot on the outer end that a forelock - a wedge-shaped piece of iron sheet - was pushed through and bent into an 'S 'to retain it. There was a washer under the forelock to prevent wood from being crushed. As many items as possible on a ship had to be easily replaced in the event. All it needed was a hammer.
Nice result for a first wooden boat build, Bob. Every build is a learning process. You'll find the next model will benefit from your experience building this one. Well done!
- 38 replies
- First Build
- Model Shipways
That sounds like what we call 'sanding sealer', Amalio. Beautifully marked out mast wedges and and so accurately cut by hand!
All I can do is shake my head and keep reminding myself that this model is not at 1:48 or 1:64! Amazing.
Channel bends is an alternate name for the channel wale planks.
Rising wood questions
druxey replied to Don Case's topic in Building, Framing, Planking and plating a ships hull and deck
Once you read Longridge, it will all become clear. To explain everything that you need to know would take a book - and it's already been written! But, briefly the analogous timber to the deadwood amidships is the rising wood. It is usually only a few inches high at the dead flat and about 3" wider than the keel. It seems to be omitted from your cross sectional illustration above. However, it was standard in those days. -
Very neatly done, Siggi! Another way is to glue the blank to a piece of wood using white glue. The advantage is that you can turn the piece in any direction while carving and also keeping your fingers safe. Also, if you slip, it won't harm your model. Soak the piece in rubbing alcohol to free it when you are finished.
I think you'll find that after some time, differences in wood color tend to deepen and even out.
- 969 replies
- hahn
- oliver cromwell
No buttocks
Buttock lines are seldom seen on contemporary draughts. If you have the knowledge, by using waterlines and station sections you can construct these yourself. -
Very nicely realised scrollwork, Marsalv!
- 589 replies
- le gros ventre
- cargo
Question Sherboune 1763 Inventory Rigging and blocks
druxey replied to cotrecerf's topic in Masting, rigging and sails
Source, Mark, is Ch10/65 or CHN 0105 RMG (Royal Museums Greenwich). -
Um.. why not painted paper or card strips instead of brass?
- 740 replies
- Tudor
- restoration
(and 4 more)
The 'fishhooks' are the numeral 1, as are the green circled numerals. -
I only woke up to the benefits of parallel pliers a few years ago when I took a jewelry making course. Wish I'd had a pair decades ago! They are indispensable for miniature 'smithing'. Lovely work there. BTW, my capsquares were built up, not cast. Mind you, I didn't need the quantity of them that you require.
It's probably water content in rubbing alcohol that softens the wood.
- 740 replies
- Tudor
- restoration
(and 4 more)
Some wood springs back more than other species. Basswood has very little spring-back in thin pieces.
- 26 replies
- Model Shipways
- Norwegian sailing pram
