druxey
Everything posted by druxey
  1. Nice deck you ended up with, Martin. Looking good all round.
  2. I have seen sheer poles on a contemporary model of 1752, so they were introduced much earlier than Lees suggests. In this case, the shroud sheer pole is more of a rack as it actually carries belaying pins. See: https://collections.rmg.co.uk/collections/objects/66296.html
  3. Looking good, Tom. Glad the book is working for you.
  4. "Fascinating, complex geometry" you say? Just wait until you get to the head timber geometry - your head will spin! The notches for the head rails get progressively angled as you go forward. It's a challenge. The aft end of the lower rail may need to be a moved little more toward the centerline? Would that solve the discharge tube issue (pun intended)?
  5. Here is a model of Resolution that shows these features:
  6. Looking very nice, Ben. We know nothing about Beam 7.
  7. If you go the chessboard route, I can guarantee that any light colored pieces you drop will land on white, and any dark pieces will land on - yes, you've guessed it!
  8. This has a ZAZ number in the corner, so is part of the Royal Museums Greenwich collection. I don't know whether there are copyright concerns involved here. However, it is a nice illustration.
  9. Again, I should mention that Mr. Friedman has had recent health issues, so please be patient with him! It is a small business catering to the ship model community, not a large publishing house.
  10. Your fairing of the bulkheads looks good. If you look at planking articles on this site, you'll see that planks usually have to be shaped to fit properly. Straight planks are only good for siding a flat surface like a house. You will either need to cut curved planks or edge bend straight ones. (There are tutorials on MSW on both methods.) Then your planks will lie flat.
  11. Avoid contact cement if at all possible! Another thread just mentioned planks springing loose later on....
  12. I was lucky enough to catch the display at Greenwich. It was fascinating to see the 'new' model by Matthew Betts alongside the contemporary Erebus model. See: https://collections.rmg.co.uk/collections/objects/66676.html
  13. Spars are all proportional to each other and to the size of ship. So you should be able to re-size them to 'fit' any other ship-rigged vessel.
  14. Supplement is on sail making. Scale spar and rigging plans are in a pocket at the rear of Volume IV.
  15. A wooden horse? That's interesting. Could be a real impediment forward! Nice work as usual, Maury.
  16. Nicely shown, Mark P! These show all the intricacies of the headwork clearly. I have similar photos that I took years ago, but all on 35mm slides, unfortunately.
  17. Those chutes in your photo seem to be either side of the second head timber, not forward of the third (foremost) one. And yes, the headwork is in the line of 'drop'. However, at sea I'm sure this was washed clean! In harbour it would be a different story....
  18. You make a number of very good observations in your carving tutorial, Marc. You are absolutely correct in that you can't make something unless you can draw it (or have a drawing of it). Two small points one might add: one, directional light to cast shadows and show highlights while carving. Two, make a maquette in modeling clay to work out the piece in 3D first.
  19. I wondered for a moment what the 'Pacmen' were for! Nice progress.
  20. Your secret is safe with us - for a price! It is interesting to see the relationship between all the components making up the headwork. May I suggest that there is no seat of ease that far forward? Any gratings there rise steeply with main rail. There would be one as you have it (or even twinned ones) ahead of the middle head timber and another, as you've drawn it, in the aft outer corner between the roundhouse and main rail. I've even seen a two level two-holer in the corner like stadium seating!
